Question about Kenmore 22422 Top Load Washer
Over flowing it doesn't matter what level my water is set at it over flows!!! how do i fix this problem
  • 5,911 Answers
Read through the following link for advice on overflow problem with a washer:
http://www.fixya.com/support/r762094-washer_overflows
A good majority of the problems I experienced in the field were caused by a simple loose air hose. Start by checking to make sure the air hose is still attached to the pressure switch. If the air hose is intact and NOT leaking, check the electrical connections to the switch for corrosion and or broken/loose wires. If all preliminary indications are good, replace the pressure switch. Read throught the link provided, thoroughly, and let me know if you require addtional assistance. I hope this helps you.
Posted on Nov 03, 2008
Low flow message on balboa 500z system
The low flow message on any Balboa means that you are having an issue with the flow of water through your heating unit. This can be caused by a few things.
  • Low water levels
  • Dirty filters
  • Something is impeding your water flow
Top up your water level and make sure it is where it needs to be, clean your filters or replace them, and check that nothing is impeding your water flow at the skimmer or water intakes.
Here is a link to water flow issues.
F2 Error Code Trouble Shooting
Dec 24, 2013 | Intex 2500 Gal Easy Set Swimming Pool...
Whirlpool washer AWG 305, water doesn't stop.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Jan 24, 2013 | Whirlpool Washing Machines
Doesn't fill
Possible that the water level sensor is faulty as it tends to indicate before the level has reached thereby starting the rinse cycle.
Usually this can be due to faulty level settings or fault in the pressure switch as it can be acting too fast. It will be best to clean the inlet valve and check the flow , test the water level sensor and see if this works by blowing into the diaphragm.
Sep 04, 2012 | Kenmore 2942 400 3.2 cu. ft. Top Load...
When my LG is washing sometimes the FE codes comes up, what does this mean? How can I fix this issue?
This means that the washer is overflowing. This is a built in fault that turns on the drain pump so that the water doesn't get so high that it gets into the floor. If water is continually flowing into the washer you will get this problem. If this is the case the water valve is most likely the problem. To confirm unplug the washer and if the water doesn't stop flowing into the washer the water valve is the problem.
If water isn't continually running into the washer then the problem can be the water level control.
Jun 23, 2011 | LG WM-2277HW Front Load Washer
Wash machine will not stop filling/no matter what setting the level is set.it will spin out. How do I fix this. It is an admiral capacity plus. model # LNC6760B71 serial # 20672581CL
Most probably an inlet valve fault. Could be the water level sensor hose has diconnected, or the drain hose is too low, and is allowing water to flow through into the drain.....Check drain hose......If water flow is not stopped when you unplug the machine, it's probably a valve.....Not a big job........Good luck......Nomess
Mar 24, 2010 | Admiral Washing Machines
Cold water does not stop at set levels. Too much flow.
Blockage in pressure bottle or small hole in pressure bottle tube.
Feb 25, 2010 | Washing Machines
Water dose ot stop when washer is full. It continues to run.
If you disconnected power and water still flowed, replace the water valve. If water stopped flowing when power was disconnected, clean out tube from tub to water level switch.
Jun 07, 2009 | GE WDSR2080D Top Load Washer
Kenmore 22422 Top Load Washer Logo
24 people viewed this question
Sal De
fordexpert
Robert Rankin
