My laptop keeps switchin of on its own and it gets hot quite quick
  • 284 Answers
Your cooling fan may be broken.
Posted on Nov 03, 2008
My screen keeps going black
A quick screen shutdown > power settings
Or your processor freeze if its getting to hot make clean the laptop processor cooling blow it out of fine dust its oft full in a little time if it is oft used that note book.
May 18, 2016 | Computers & Internet
Tip
How to Prevent Laptop Overheating
There are some laptops that get hotter than other laptops. Laptops get hot due to many factors such as capacity of the processor, cooling fans,ventilation, extra items such as modem, video cards. They all produce heat due to which laptop gets hot.
You'll find many examples on the Internet for the laptops which get hot. There are particular laptop models which produce excessive heat. For example, IMB T60,Apple Mac Book Aeros, Compaq 610, Dell D400 etc.
But you don't need to worry now because there are certain methods by which you can stop overheating of your laptop. These methods are discussed below.
Place your laptop on a cool flat surface while working. It will allow the air to enter your laptop. Some laptops have cooling fan underneath and blocking this will make your laptop hot quickly.
Buy a laptop stand from a laptop seller. It lifts your laptop few inches from surface of the table making a reasonable space for air to enter your laptop freely.
Dust your laptop regularly; it will keep your laptop's fan functioning properly for a long period. The fan needs to do an extra work when there is dust inside the laptop. If you dust regularly, the fan will not experience any difficulty.
Shut down your laptop before putting it in the bag. The atmosphere inside the bag may be too hot for your laptop, and it can damage your laptop.
When the battery is full, unplug the charger. People make a common mistake leaving the laptop plugged in. Due to the constant supply of electricity to the laptop will heat its battery as a result it will overheat your laptop.
You can find certain kinds of items in many electronic stores for keeping your laptop cool. Cooling pad is a most common equipment to keep your laptop cool that sits beneath your laptop and is powered on with the help of USB port. It increases the airflow inside the laptop. So, cooling pad is the best you can take to keep your laptop cool and maximize its performance.
Give your laptop a little break if it is getting hot. It can shut down itself to protect any kind of damage due to overheating. This is an indication that your laptop needs a little break.
Do not expose your laptop to the sunlight for a long span of time.
on Dec 18, 2010 | Computers & Internet
What would cause my speakers to just quit. I had them running through my receiver.
there could be a problem with the audio inputs on your receiver but just in case try switchin the speacker wire if that dose not work then try switching the input cables from the aux in to the tape or cd input jax if that dont work then the problem is in your curciut board and is probly ruined what can cause this problem is there are to many speackers hooked up and the receiver got to hot or the positive wire and the negative wire brobly gat crossed some where and shorted out your receiver input jax try the solutions i recamended and hope for the best i hope it works for you good luck
Sep 19, 2014 | Audio Players & Recorders
Acer Aspire 4930 heats up very quickly
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Mar 28, 2012 | Acer Aspire 4930-6862 Laptop
USB port getting HOT
These ports can get quite hot & things attached can draw up to 1 Amp of current, and this can make things quite warm over time... as it draws heat away from the device. Keep an eye on it though.
Jan 30, 2010 | HP Compaq Presario V2000 Notebook
It heats up and shuts down after about an hour of use.
Don't know anything about that particular type of laptop but laptops and notebooks heat quickly and can burn out permanently if they get too hot. Are you keeping the bottom vents clear so it won't heat up?
What length of time does your manual tell you your batter will run without needing another recharge?
How old is your battery?
Sep 24, 2009 | MPC Computers TransPort X1000 Notebook
Daytona 955i running hot
That is quite normal - these bikes run very hot and will typically reach temp where fan kicks in (103 deg C) while bike is sitting at idle, even if not particularly hot weather. Needs good airflow through the rad to keep the temp down.
Fortunately, when fan comes on it lowers the temp quite quickly.
Jan 07, 2009 | 2006 Triumph Daytona 955i
Dell laptop gets hot quickly
Get some compressed air from Radio Shack or other place that sells it (unless you have a small compressor) and blow out the laptop. My laptop gets dusty very quickly since I live in the desert and I blow it out at least once a week to keep it from overheating. You will be amazed at how much dust will come out. Let me know if this helps.
May 23, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
