Question about Canon Speedlite 430EX TTL Flash
Flash will not power on
Hi, I have a Canon Speedlite 430EX TTL that I thought I lost on a trip. I found it in my closet last week after being stored for about 1 year... :) I went to power on the flash and it will not work.
I had rechargeable batteries stored in the flash but it doesn't appeared that they leaked at all.
I purchased new rechargeable batteries just in case the old one's were no longer good but it still will not power on.
There appears to be a little substance on the metal connector within the battery housing but very very little.
Help
  • 62 Answers
YOU NEED TO REPLACE THE CONTACTS ORT USE SOME AMONIA AND WATER TO REMOVE THE CORROSION.
Posted on Nov 28, 2008
Tip
Use good quality battery's!
When I first bought this flash I thought mid range battery's and lots of them would do the trick, my flash arrived hours before the event I needed it for and I thought it was faulty until at the last seconds I bought some high quality more expensive battery's and the problem was solved :)
on Mar 12, 2015 | Canon Speedlite 430EX TTL Flash
New batteries still no power-up
Check the contact in the batt compartment for obstructions or corrosion etc. No power means broken circuitry - either physical dislodgement of electronic/ electrical parts or damaged electronic components.
Apr 01, 2013 | Canon Speedlite 430EX TTL Flash
Speedlite 430EX II pilot red light wont turn off wont fire
Try mounting the flash on your camera, turn both on and reset your camera to factory default settings in your camera menu settings.
Feb 13, 2013 | Canon Speedlite 430EX TTL Flash
My canon speedlite 430ex does not charge up, batteries are new and rear screen works/lights up any ideas?
Sounds like an internal wiring circuit problem. It's strange that the screen lights up but the flash doesn't charge. You should probably get it checked by Canon.
Feb 11, 2013 | Canon Speedlite 430EX TTL Flash
Canon 50D doesn't recognize new Speedlite 430EX II. Flash power is on and pilot releases flash.
Check the contacts on both the camer and the lens. I usually clean mine with methylated spirits or isopropyl alcohol. I have to do this every 3 months or so as dirt or even oils from your hands can stop the contacts from working properly.
Oct 30, 2010 | Canon Speedlite 430EX TTL Flash
Only get one flash when using slave
Yeah you should go into the menu on your camera and see if there is anything you need to change!!
Apr 02, 2010 | Canon Speedlite 430EX TTL Flash
Can't find the serial number on my 430EX speedlite. where is it located?
This is where I found mine:
It's a 6 digit number located on the top half of the flash (the bit that tilts backwards and forwards). On one side it says Speedlite 430EX II, on the other side there are a few symbols and underneath is the serial number engraved on the plastic.
I also found it printed on the warranty card that came inside the box.
Mar 22, 2009 | Canon Speedlite 430EX TTL Flash
Canon Speedlite 430EX TTL internal corrosion.
U are to be commended on your industry. Those cameras are a bit-- to take apart. Try a google search for the operation described. You might get lucky with a utube video!
Sep 04, 2017 | Canon Speedlite 430EX TTL Flash
Canon Speedlite 580EX
if u set the 580ex on master and the 430 EX on slave it works :) u dont need STE2 for this simple task.
Oct 18, 2007 | Canon SPEEDLITE 580EX TTL Flash
Canon Speedlite 430EX TTL Flash Logo
266 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
