Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Side by side frame
The fridge frame in between the two doors is very warm, and wanted to know if there's a problem with it?
  • 59 Answers
It is normal for that panel to get warm while the fridge is running. There is a hot gas tube from the compressor running through it to prevent frost built up. If it's feeling a little too hot try cleaning the coils under the fridge. This will allow the gasses to cool a little more efficiently thus allowing the fridge to cool quicker.
Posted on Nov 03, 2008
Whirlpool double door fridge. Door wont stay closed. Have to push extra hard to keep it closed
Take out the shelves and drawers. check the rear is clear of ice before putting them back in place, and ensure they are not stopping the door closing. Next check the top and bottom of the door. Is it hitting the frame when closing? If so, straighten it up by tapping the hinge side of the door to make it square to the frame.
Jul 04, 2015 | Whirlpool Refrigerators
LG gn253sqa electro cool- temp. control lights in fridge keep flashing and fridge not cooling so good, help?
This has happened to me a couple of times.The problem is that when the fridge door is opened too may times the warm air of summer will block the cold outlets in the fridge with ice.The cold air comes direct from the freezer and the chamber connecting to the fridge clogs up with ice.What one has to do is completely empty the fridge and freezer,leave open both doors so the the ice build-up can melt.Then after about at least 4-5 hours (very important to stick by this time-frame as I tried a less time,but it did not work.),close both the freezer and fridge doors and switch it on.After about 1/2 hour replace your goods in the fridge.The down-side of this is that you will need the kindness of a neighbor or two to use their fridge to store your food whilst this fix is underway..
Feb 28, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
Door frame warm
Nearly all modern fridges are self defrosting. Additionally, some models offer the option to minimize moisture on the cabinet. To do both the defrosting and controlling moisture build up, small heaters are used. Defrost heaters are located in the freezer compartment.
Typically, the other heaters are installed in the frame on the front of the fridge cabinet, near the freezer opening. This is where sub-freezing cold air would escape and contact the warmer (room temperature) outer cabinet. This causes condensation much the same way a glass of cold water "sweats" sitting on a counter or table. The warmer and more humid the room is, the more quickly the condensation will form. The heater is used to quickly evaporate any moisture that collects on the cabinet. This heater is operated at the same time as the defrost heater, and they are turned on by a timer, 2 or 3 times a day for about 20 to 30 minutes each time. When they are powered, it is expected that the cabinet will be warm to the touch. You may smell plastic, as the door seals adjacent to and in contact with the heated parts of the freezer opening are warmed, and is normal - particularly if new. The heaters should never be hot to the touch nor should smoke be seen.
I hope this helps!
Feb 14, 2012 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Refrigerator door will open slightly (sometimes imperceptually) when freezer door is shut, causing refrigerator to get warm. Cleaning door seal has not helped
Please check that the door is not twisted, have you got children that could have possibly been hanging on the door, most fridges have a plate that is adjustable that is on the bottom R/hand or L/hand door, but it will mean to pull the fridge clear of any work surfaces disconnect the power supply first tilt it back as far as possible but do not lay it down as this my cause any particles in the system to get into the small pipe work and block rendering useless, slacken off the screws or bolts just enough for the door to move locate the door equally around the fridge and retighten bolts, if this does not cure the problem then stand fridge up right and put a small block of wood or something similar in between the door and frame in the area that does touch the fridge then gently push the door in not to much just a bit at a time until the magnetic strip locks against the fridge to give a good seal.
Good luck
Sep 25, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
I have a bar size danby designer and want to know how to change which side it opens on. It currently hinges from the left side and I want to open opposite of that.
IT SHOULD HAVE THE HOLES IN THE DOOR AND DOOR FRAME, IT SHOULD BE AS EASY AS TAKING THE SCREWS OUT AND MOVING THE HARDWARE OVER TO THE OTHER SIDE, MOST ALL FRIDGES YOU CAN CHANGE ENTRY SIDE .. LOOK CLOSE AT THE TOP I THINK YOU WILL SEE WHAT LOOKS LIKE LITTLE PLUGS .. HOPE I WAS OF HELP..JAY
Jun 24, 2011 | Refrigerators
I have a Maytag Stainless Steel Fridge side by side 10 month old, freezer works fine fridge warm as death! Freezing lower cold air vent between the two drawers. Model MSD 225 8AE SO1 Serial...
i couldn't look up your machine,maybe bad model number,i would call the factory,it's under waranty for the first year,you either left the door open or you have a defrost problem,let me know if you're gonna call the factory or if you want to fix it yourself,if you want to repair it let me know and check the model number inside the fridge section on the right hand wall up near the ceiling
Sep 22, 2010 | Refrigerators
Refrigerator 50degrees; freezer 10degrees suspect fan outage/ge
I bought a wine cooler but I want to change the door I would prefare the door frame to be black
May 26, 2009 | GE Refrigerators
Side by side refrigerator is not cold. Bottom freezer is.
if the freezer is cold and the fridge is not then it can be several things. The freezer could have a bunrt out defrost heater, defrost timer faulty, fan not working in the freezer??. all of these things will stop your fridge getting cold, but your freezer will still be around minus 9 deg c. you wont get any air into the fridge as the coil in the freezer is prob all iced over. Dont worry about the heat on the door frame as it is only the anti sweat heater
May 01, 2009 | Maytag Freezers
Freezer is working good but the fresh food side is warm.
I will need to get a little more information to help you better. Sounds like the defrost timer is bad but I will need a number like for example 915.125869
Let me know, Thanks Sea Breeze
Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
Feb 27, 2009 | Kenmore 53642 / 53644 Side by Side...
Fridge cycling cool to warm
yes, you should not have a gap. It is allowing warm air to circulate in ref.
Jan 17, 2008 | GE GSS20IEM Side by Side Refrigerator
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
79 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
