Question about KitchenAid KSM150PS Artisan Series Stand Mixer
Kitchenaid Mixer will not lock
The locking mechanism on my kitchenaid mixer has stopped working. It will slide into the locked position, but when alittle upward pressure is applied (like when mixing dough) the head lifts and the switch slides into an unlocked position.
  • 2 more comments
  • maddyn99 Dec 02, 2008
    I have the same problem. Is there a way to replace the locking mechanism? or is it easy to open up and see what the problem might be?
  • Anonymous Dec 23, 2008
    I have a similar problem, my latch will move to the unlocked position, but the mixer head will not push up. It is still locked.
  • Kirsten810 Dec 24, 2008
    I have the same issue. When the tilt head is up, the locking lever in the back is in the downward position.
  • levantades Jan 13, 2009
    I've just buyed two bowls because the three bowl-teeth to rotate for locking are deformed  ... and now? another bowl to buy .. or there is a solution for a better locking of the bowl?
  • 145 Answers
This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
Hope this helps!
Posted on Jul 08, 2009
  • lbirus
    lbirus Dec 09, 2012
    I have the same issue. The lock mechanism is 'wobbly'. I have tried adjusting both the screws (under the mixer and under the base) but the lock is still not holding the top in place enough to keep the mixer from wobbling. Any way to replace or repair the lock?
    Novelist:
    Scholar:
  • KitchenAid Expert
  • 134 Answers
It sounds like the bowl lock lever is damaged or broken. It could be the beater adjustment but sounds more like the bowl lock lever. It requires taking apart the mixer, but is actually a fairly easy repair.
Page 15, figure 6 of the service manual talks specifically about this part, here is a link to the service manual: http://ep.yimg.com/ty/cdn/mendingshed/kitchenaidservicemanual.pdf
Also here is a link to the page where you can purchase the part: http://www.mendingshed.com/24452-2.html
Let me know if you have any questions
Colleen@MendingShed
Posted on Apr 23, 2015
KitchenAid ACCOLADE 400 Mixer.When mixing dough the bowl jumps out of the the bowl lock. How can this problem be resolved?
I know this sounds a bit simple but the bowl cup can sometimes actually wear out and a very fast (# screws) and a new one and the problem is solved. If however there is a problem on the head hold down set screw (under the mixer in the cavity ) it can come loose then the mixer head can bounce all over the place causung the bowl to get loose in the holding cup at the base of the mixer., I hope this helps, let us know if you need more, we can FixYa
Feb 22, 2015 | KitchenAid Food Mixers
How to tighten kitchenaid mixer motor head locking lever?
Adjust the head height first, flat paddle should just clear the bowl. Te head height adjustment can be seen in by the hinge looking from the front when the head is raised. Screw in (clockwise) to lower and out to raise. You cannot get the head lock right when head height is miles out
Jul 10, 2014 | KitchenAid KSM150PS Artisan Series Stand...
Mixer won't turn on after adjusting beater height
The kitchenaid warranty is exactly 365 days from date of registration "No Questions Asked" on day 366 you have no warranty and you gotta pay.
Now the good news; first check the wall socket, I know it works but check it anyway. then check your plug, did you step on it while you were working on the machine? The plug often falls to the floor during work and can get underfoot, you may have broken the plug it'self. next you will need a parts list for your model from Kitchenaid's website.
http://www.kitchenaid.com/customer-service/manuals/
My first suggestion is to try a minor adjustment of the speed control switch, they often get out of sync when you do something to the machine. You can find several videos of this on the youtube site. "Adjusting the speed control switch on kitchenaid mixer"
If the two or one of the top 2 screws on the speed control switch move it can shut the machine down just like an on/off switch. Did you remove the back cover during your adjustments? Did you remove and replace the carbon brushes on the side of the machine while working on the machine? If you did you might have put them back in incorrectly, if you did they will also act a a shutoff switch. If you did not take them out then DON"T as there are four ways to put the brushes back in and only one way is correct and there are two brushes to deal with. Has work ever been performed on the mixer before? Because if all you did was to adjjust the beater height screw then nothing should have effected the normal operation of the mixer. So if there is anything that you did but did not include in your description of work you performed then please let us know. We strive to give accurate solutions but... as I am a KA tech I do not have any other solutions with out the machine in front of me. Just so you know you can fix this yourself.
May 26, 2013 | KitchenAid KSM150PS Artisan Series Stand...
Motor head locking lever is hard to unlock on Kitchenaid mixer after kneading dough.
Hello Flyfishing19,
The problem that you are experiencing is due to the torque that is put on the head while mixing dough. The lock is still working fine, although it is getting wear. You can replace the locking mechanism. However, it will work for a while longer. If you want to change the mechanism post back to this thread and I will be happy to locate you one and explain how to change it.
Mar 06, 2011 | KitchenAid KSM150PS Artisan Series Stand...
My KitchenAid tilt head lock keeps coming loose while beating small amount of dough allowing the head to wobble gradually bad? This is the second mixer with same problem! I've heard some people talking...
In my case the lock was not engaging fully because the internal mechanism was bent too short. I'm not sure if this happened over time or if it is just a manufacturing defect. If your mixer still has some up-and-down play to it when the lock is engaged, then you might have the same problem as me
To fix it, search this site and others for instructions on how to remove the motor cover. I found this video useful: http://www.youtube.com/watch?v=VeCiivPt7hk
With the cover removed you have access to the locking mechanism. In my case, the latch is connected to the locking lever via a bent S-hook. The hook was just slightly too short which kept the latch from engaging completely. If you remove the two screws holding the hook in place and that allows the lock to close completely, then you have the same problem as me. (You'll feel the difference immediately. When fully locked, there is practically no wobble in the mixer head.)
I lengthened the hook by placing it against a flat surface and hammering the bend out a bit.
Jan 05, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
I have a kitchenaid ultra power 5-spped hand mixer model khm5twh. the second beater will not stay in the socket. i'm wondering if i'm doing something wrong or if the locking mechanism has given up.
You're not doing anything wrong, the retaining gear probably has one side that is broken and it will no longer lock the beater in place. I have the same mixer and the same problem.I have searched at least 20 web sites that carry Kitchenaid repair parts and the part is no longer available. My best suggestion would be to try a local small appliance repair shop that might have the part on hand.
Feb 09, 2010 | KitchenAid KHM5DH Ultra Power® Hand...
Unable to turn mixer on
you have to have the bowl installed correctly and all the schields in place before the unit will work
May 20, 2009 | KitchenAid KSM150PS Artisan Series Stand...
The locking pin on the Kitchenaid Artisan mixer (KMS150) will not fully engage. The hinge pin had come out and we put that back in, not the lever will not fully engage.
I had the same issue. I just finished tearing mine apart only to find that the lock just wasn't engaging with a slot in the base of the mixer. Try lifting up the head of the mixer to expose the height adjust screw in the hinge between the base and the head. By tightening mine down a couple of turns, the lock can engage the slot again and the lock works. You may have to do a little tweaking to find the right balance between height adjustment and latch functionality, but at least you won't have to tear your mixer apart like I did!
Dec 14, 2008 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid mixer
Try replacing the moter brushes,if not its probably ether wiring or in the switch board.
Jun 01, 2008 | KitchenAid K45SS Classic Stand Mixer
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
5,759 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
