Question about Brother DCP-8045D (Bundle) All-In-One Laser Printer
PAPER JAMMED IN BROTHER DCP-8045D
Hi there, i have a problem with my BROTHER DCP-8045D.
I get the paper jammed error message with the biiiiip sound.
I looked everywhere and can't find anything...
Is there anything i can do to resolve this problem?
Is there anywhere in particular to look for?
Thanks
Remi
  • saki2515 Mar 15, 2009
    The same as you, but mine is 8065dn..... The problems may be the sensor. I will go to the shop again to claim.
  • 3 Answers
SOURCE: Brother DCP-7020 Drum problems
Open the front of the printer by pulling on both tabs at the finger grips on both sides of the front panel. The front panel will flip down. The drum and toner cartridge comes out as a single unit. It is black plastic within gray plastic and has a handle like grip in the middle. Grasp this grip and pull the unit up and out. It feels kinda funny the first time you do it and you may feel like it will break, but it won't. Pull it up and out in a kinda circular arc. Do not touch the drum. If you ever need to replace the toner cartridge, press on the blue tap and separate the drum from the toner cartridge. You will have to replace the drum after every five toner cartridge replacements so practice doing it now. Note the tabs and slots on the sides before separating the drum and cartridge. Align the cartridge into the drum carriage and slide it in until it clicks. To replace the cartridge assembly into the printer, angle the cartridge at about 45 degrees and rotate in while pushing. It should click into place. If the front door then closes properly, you should have it in properly. Practice a few times and you should be an expert. For paper jams, there are many places to check and they may not all give warnings. First pull out the paper tray and check for and remove misfeeds. Remove the drum cartridge assembly and described here and check for and remove any paper. Open the back cover and check for and remove any paper. Open the automatic feed and check there as well as lifting the cover where the scanning surface is. Look in the rollers for the automatic feed for paper pieces. The last place almost never gives you a warning. Reach into the slot where the paper exits after being printed and grasp the whole top cover. Lift upward and it will open about 4 inches. This is a good place where small pieces of paper or even whole sheets may get stuck. Clean out any dust while you are there.
Posted on Oct 04, 2007
SOURCE: paper jam, open back cover, then remove paper jam
Remove the paper tray. Check that the paper length adjustment is set correctly for the paper you are using. It's the small blue dam at the center 'back' of the paper tray.
Posted on Jun 25, 2008
SOURCE: automatic Document Feeder on my Brother DCP-8045D
are you on Mac or PC.  I know h2 do it on Mac
Posted on Jan 21, 2009
SOURCE: Duplexing on Brother DCP 8045d
I do on Mac,  any use?
  • 133 Answers
SOURCE: message on brother MFC7420 "back door open" when it's not
Actually, you need to double check the back cover and front cover, open them all to check all paper jam.
Besure to check the back cover, normally all paper jam is from the back.
be sure to close the front cover at the last cover to close.
Posted on May 29, 2009
Paper jam on screen will not reset
To clear the error message Paper Jam after you removed the jammed paper, open and close the scanner cover.
If you still receive the error message, a small piece of paper may be stuck inside your Brother machine.
Refer the below link for the steps to remove any ripped paper remaining inside your Brother machine:
still receive the error message Paper Jam after removed the jammed paper...
Apr 22, 2014 | Brother International Brother MFC-J4510DW
May printer brother dcp-150c is always paper jammed
When you removed the jammed paper, did the paper come out inone piece, if not did all the pieces that were removed make up the entire sheetof paper?
Otherwise there may be still a small piece/s of paper still in the printer,which is causing this error message.
May 30, 2011 | Office Equipment & Supplies
Says paper jam but is not does'nt feed paper
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Oct 27, 2010 | Brother DCP 115C All-In-One InkJet Printer
My printer says that there is paper jam,i already removed the back cover to check if theres paper,but theres nothing into it..i shut it down and on it again and its also again that theres paper jam...how...
Oct 27, 2010 | Brother DCP 130C All-In-One InkJet Printer
UNIT KEEPS ASKING FOR NEW DRUM EVEN AFTER I INSTALL. ALSO PAPER JAM MESSAGE KEEPS COMING UP
The drum error can be cleared by opening the front door and pressing either the options or menu button. It will ask if it's a new drum and you press 1 for yes. Your paper jam error you will have to look where it's jamming and remove scraps, without seeing it myself I can't tell you what to do to fix it.
Jan 28, 2010 | Brother DCP-8045D All-In-One Laser Printer
Brother dcp 8045d paper jammed - there's no paper!!
you can replaced scratched part at authorized service)))
If you have error "paper jam" and cannot find paper in your DCP, you must manually recheck all (!) (4 items) paper sensors ))))
I think that a paper sensor at fuser section damaged))))
Nov 07, 2008 | Office Equipment & Supplies
I have a brother photocopier DCP-8040/8045D Series. We have a error 7a come up on copier, It started when paper got jammed at ther back of machine and weas pulled out from the back, ever since then when...
Turn off the unit and remove the toner cartridge to visually inspect for more paper. Replace cartridge if necessary. Also the problem may be in the fuser. Good luck and God bless.
Jun 16, 2008 | Brother Office Equipment & Supplies
Brother DCP-8045D (Bundle) All-In-One Laser Printer Logo
44 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
