Question about LG 24 in. LDS 5811 Built-in Dishwasher
Water is leaking onto the floor from the front of the unit.
It seems that the front door seal is shot allthough the unit is just over a year old...the problem is that I can't seem to constrict my torso enough to fit in there to servey the damage and or pin point the problem. and Ideas?
  • 1 more comment
  • cmcnulty4 Nov 06, 2008
    Thank you MNTECH for taking the time to answer my issue, I took the time to remove the outer door skin to survey the problem and whitness the leakage from the outside of the unit and saw where the seal was leaking I will now use the part number you listed and purchase that seal.
  • pjjjj Jan 04, 2009
    leaking from the front door
  • Report
    Report Jan 31, 2009
    i have the same problem. i called lg and they said that they dont sell parts because a customer does not know how to put it in, so they require the service guys to be involved. where's the best place for some instructions? they said even if they send a part, there are no instructions included at all...LG LDS 5811 WW
  • 1,543 Answers
You might try a part number 3920DD3005A door gasket, which is a bit thicker than the old ones and should help with this issue for many LG dishwashers.
Posted on Nov 03, 2008
Maytag dishwasher leak
If it's leaking from the door, a new gasket may fix this. If it's leaking from the pump, the seal is worn out, and the repair may be too costly or difficult. If the unit is 5 years old, consider a replacement.
Aug 29, 2015 | Maytag Dishwashers
Whirlpool GX2SHBXVY05 refrigerator leaking from bottom freezer onto floor.
if it has an ice maker check the water feed hose for leaks.
also I have a freezer that ices up twice a year. poor design. have to defrost every now and then.
Jun 09, 2015 | Refrigerators
LG 1814CW washing machine leaking water
It may be time to replace that door seal again
May 07, 2014 | Washing Machines
Whirlpool refrigerator--water freezing in floor of bottom freezer then leaking onto floor
whirlpool bottom freezers with ice forming on the freezer floor is nothing new. It is formed most likely by an ongoing issue with the design of the defrost drain becoming clogged and there is a revised kit for it part# W10619951.
Whirlpool has extended the warranty of this issue only to two years from the date of purchase and will usually give you the part but charge for install.
It can be put in in less then 10minutes using just a 1/4" hex bit and a small flat blade screwdriver to release the clip on the old "slide" style drain.
Once installed,it is best to defrost the fridge for at least 24 hours (doors open and unplugged) to make sure all ice is melted from inside the unit.
If your drawer was not closing,you would have frost.. If your defrost timer (which virtually no newer units have since digital controls are the norm with adaptive defrost) then you would have frost,not ice.
The fact that you have water is telling me it is defrosting and re freezing.
List a model# for further support if needed please
Feb 08, 2018 | Whirlpool Refrigerators
Hoover optima washing machine is leaking very badly . I have stripped the machine down and cannot find the leak . Inlet pipes clear. Cleaned soap drawer and two feeder rubber pipes don't seem to be a...
Hi,maybe the draw dispencer is damaged,I wouldnt think it is the drum seal,what I would do is tilt the washing machine so that the top of the machine is leaning against the wall so that the front of the machine is of the ground,then while you get underneath the front on the floor with a torch get someone to put water in the dispencer and see if you can see where the water is leaking from,I hope this was some help,all the best.
Mar 21, 2017 | Washing Machines
I have a Neff built-in dishwasher and sometimes there is a heavy leakage of water from the front right-hand side. The unit is 3-years old and there is a build up of scale around the rubber seals. The long...
Check the rubber seal in the bottom of the door has not perished or split,also check the bottom spray arm has not split on the ends as this will direct the spray directly onto the door,causing it to leak.
Hope this helps
Sep 19, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
Dishwasher is leaking in front onto floor. Water level during washing seems too high. Float is not obstructed by any object. What can I do next?
if it seems to be coming from the front it may be the rubber door seal they are not to expensive and not very hard to change if it is leaking under machine it may be the seal that sits on top of motor if water is leaking around motor the seal in the bottom of the washer is damaged
Dec 17, 2009 | Washing Machines
Sub zero 550 (14 years old) has a small but steady leak onto floor from freezer compartment. Small amount of frost buildup on inside of door. Food is frozen and the door "appears" to seal we
Right hand side wall in the freezer - take a look- any frozen water or moisture? Need check a drain line, usually defrost heater inside the freezer wall getting bad and draining water just freezing inside of it.
May 10, 2009 | Sub-Zero Bottom Freezer Refrigerator
Water runs out of freezer door overnight ,at times
Have a look at this link:
or this one:
Apr 17, 2009 | Westinghouse Refrigerators
My AEG 6200 Digitronic washing machine is leaking from the front door seal down the front and onto the floor. Is this a common problem and can it be fixed? - for example by replacing the opening rubber...
Peace BeeSuit,
Happy to be of assistance,
You asked:
Your, AEG 6200 Digitronic washing machine is leaking from the front door seal down the front and onto the floor.
- for example by replacing the opening rubber seal?
Yes I believe that replacing the rubber seal is usually the answer.
How old is the unit? And is the washer working well other wise?
Is it draining and not smelling like mold in side?
Some times in an old machine the pump does not completely dran out and it could smell like moldy water! Then if it's aged. I would consider not fixing both of these to problems in a washer 10 years or older not to put good money in to bad!
But if the leak is the only problem, go for the seal!
Happy to of assisted and made a different s in your life!
Bless you,
Please give me a good rating for my sound advice before you sigan off.
Thank You
Sep 12, 2008 | AEG Washing Machines
LG 24 in. LDS 5811 Built-in Dishwasher Logo
303 people viewed this question
Top LG Dishwashers Experts
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
