Question about Sharp Office Equipment & Supplies
Sharp MX4501N keeps jamming and giving Error Code E7-06. Can't clear code without turning off the machine. Any ideas??? Thanks!
  • 2072 Answers
SOURCE: Hard reset to clear paper jam error
Most likely you need to carefully go through the paper path and look for the locations of all the paper path sensors.
You probably have one stuck on the frame or a spring came off the flag and its not actuating properly.
Follow the paper path carefully from the feed rolls out to the exit. I am sure you will find a sensor not operating properly.
Actuate every one and make sure they have no resistance and that they return to the proper position.
Posted on Mar 01, 2008
  • 33 Answers
SOURCE: UF-8000 J43 Jam (Not There)
turn it around and have a look in the back panel that opens, open all other covers and check that any of the small black sensor levers are not stuck down they shoul all spring back
Posted on Apr 24, 2008
leroyal
  • 2120 Answers
SOURCE: hp j6400 fax over voip line error code 388
Fax machines are ANALOG devices, VOIP, Vonage etc are DIGITAL devices.. It won't work reliably
Posted on Oct 29, 2008
PORRATEC
  • 25 Answers
SOURCE: error code 1300
THIS ERROR IS CAUSED BY POLIGON MOTOR OF THE LASER SISTEM. IF YOU CAN GET TO IT, JUST OPEN IT , LUBRICATE DE SHAFT AND YOUR PROBLEM WILL BE SOLVED. GOOD LUCK.
Posted on Oct 30, 2008
jtuminaro
  • 56 Answers
SOURCE: machine error. no error code.
Go into maint. mode.
With-in 2 seconds hit Menu,*,2,8,6,4
Then hit 82 when in maint mode.
This will give you a machine error code.
Let me know what that number is and I will help you with a solution.
Posted on Jan 15, 2009
ERROR CODE H5-01
Make sure you get all of the paper out of the machine that's jammed in it. Then you have to clear the H5-01 by doing the following at the machine's control panel:
touch P * C *
14 - then the black and white start button
Execute
Yes
the machine will reboot and it should clear the code as long as the jammed paper was removed!
How To Sharp Copier Printer Scanner Instructions Troubleshooting...
Feb 05, 2014 | Sharp Mx-3501n Color Copier Printer...
Hello, I have (had) a paper jam on a Sharp MX2700N. I have removed all copies but am now advised to call for service Code H5-01. Any ideas?
after call for service, the machine will indicate an error code like H4, F2,etc. if you can give me the code i will know what to do
Feb 03, 2011 | Sharp MX-2700N Color Copier
Machine diplays "paper jammed" with no paper in
Hello
This the method to clear paper jam, follow these steps:-
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Turn off the printer.
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Open any other doors that give access to the printer's paper path and to the ink cartridge. 5 If necessary, remove the ink cartridge. Place it in a bag or away from light to avoid damaging it.
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though.
Replace the ink cartridge and paper trays, close any doors you opened and turn the printer back on.
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Good Luck
Dec 18, 2010 | Sharp UX-B20 Plain Paper Inkjet Fax
What does an error code H4-01 mean on a Sharp MX4501N copier? The machine no longer copies, simply displays: Call for service Code H4-01.
Fuser Heater failure. The fuser is the part of your machine that heats up and "fuses" the toner onto the paper. It is located right near where the paper exits the copier. This error code means that the fusing unit is not heating up as it should. The most common failures in order of ocurance are thermal fuse, thermister and heater lamp. In any case you are going to need a service person to come out and diagnoe which part has failed, replace the part and reset the code for you. Should not be more than say $200 to repair.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 13, 2010 | Sharp Copier Cabinet Printer
How do i clear error code on AR BC-260 H5-01
I don't have that error code specifically but any error code that starts with an H has to do with the fuser section of the machine. It could be the thermistor, rollers, or the heat lamps.
It should be looked at by a Sharp technician to determine the correct problem.
Oct 01, 2008 | Sharp AR-M237 Copier
Service Mode On Sharp SF2530
A little rusty on this machine, but try this.
This code means you have had to many paper jams in the fuser without removal. Make sure all is clear in the fuser and exit sections.
Then on the control panel you will press a series of buttons as follows.
Press the Clear, Press interrupt, Press Zero, Press interrupt, Enter # 14, Press start, That should reset the machine...
Hope that helps...
Lbcoaster
Jul 02, 2008 | Sharp SF 2020 Copier
Service code H2-01
Press "#" "Interrupt" "Clear" "Interrupt" then hit "14" "Start" then go to sub code "0" or it may ask to clear code.... Good Luck..
May 13, 2008 | Sharp AR-M237 Digital Copier
WHAT DOES THE CODE BELOW MEAN
H5-01 means the machine has had a jam in the same place 5 times in a row.
Mar 13, 2008 | Sharp AR-M350N Copier
Error code H5 01
It means you have had 5 jams in a row in the fusing unit. Open the left side door of the copier (roll the finisher out of the way if you have one). Open the green handle on the top of the fusing unit and carefully remove all of the pages stuck in there. You can use the green wheel at the back to turn the rollers if need be. If you have no jam, then someone already removed it and you just need to reset the code. to reset the code, push P * Clear * on the numeric pad. when it says enter simulation number, enter 14 and push the Start button for black and white copies. The machine will reboot and your code should be gone.
If you keep getting jams, you may have knocked the Fuser exit sensor arm out of place.
Please don't forget to rate your answers.
Dec 22, 2007 | Sharp AR-BC260 Color Copier
Ar-c160
Make sure there is no paper jammed in machine, H5-01 means 5 jams same location. Use quality paper not recycled and make sure it is fresh not old stock
PROGRAM INTERUPT CLEAR INTERRUPT must be SUPER FAST then 14....WILL RESET CODE
Dec 16, 2007 | Sharp AR-C160 Color Copier
153 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
