Question about LaCie Design by F. A. Porsche 160 GB Hard Drive
Maximizing life of external HD
I use these 250 Gig drives to archive photos and only need to access them once or twice a month. What is the on/off cycle life rating of these drives? That is, how many on/off cycles are these rated for? If left running constantly, what is their expected/rated runtime life? My reason for asking is that many suggest leaving externals run all the time and I'm just curious to know if, in MY case, they will last longer if I only turn them on as needed (about 2 times a month) or leave them running all the time.
    Novelist:
    Scholar:
  • 158 Answers
Keeping hard drives running will cost more on electric and heat generated from drives as I've found out on of my 160gig sata drives burnt out because I was using pc 24hrs aday and night if I had put a cooler on the bottom it would have lasted 5 years but I only lasted 8 months you can give your hard drives 2 twice or even 5 times life span if kept at room temperature listen to you own advice it's your data and hard drives do what you wish I'm only her for advive you can tak itor leave it
Posted on Aug 14, 2007
SOURCE:
File size limit for Buffalo HD 250 GB Hard Drive backup
The file is too large meaning that the size of that SINGLE file is too large. Your hard disk is probably formatted to a FAT32 file system, this results in a maximum of 4gb PER FILE maximum transfer. What you could do is archive it into a few parts using winrar and then moving it onto the disk, and when you need the file just extract the archive. Your problem isn't the total free space, it's the size of that file chunk.
Nov 03, 2012 | Buffalo Technology 250GB USB SATA 2.0 HD...
I have an iomega 250 gig external hd. went to plug it in one day and my pc said it couldn't read any of the files. i can still see thumbnails and view photos but can't transfer any data at all. please help...
i have an iomega 320 gig external hd. went to plug it in one day and my pc said it couldn\'t read any of the files. i can still see thumbnails and view photos but can\'t transfer any data at all. please help as i stupidly put all my files on this drive. about 10 years worth of work.
Dec 02, 2010 | Iomega 33089 250 GB Hard Drive
I have an acomdata external HD enclosure with an 80 gig seagate HD. I plug it in to my dell inspiron 1300 laptop running windows xp pro and it recognized the hardware the first time I hooked it up but I...
Have you been able to access the drive in the past? If so it might have become corrupt so do a reformat of the drive and format it to NTFS. You can also uninstall and reinstall the drive for your HD before doing this. Pretty much a last resort.
Dec 15, 2009 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
Simpletech 500 GB external hard drive - unresponsive
If you really can not get it to work anymore, you could try opening it up and connecting the hdd directly on a IDE/SATA port in your computer. This will only work if you have a desktop, for a laptop you would need all kinds of converters.
May 03, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Upgrading from 250 gig hard to a 500 gig hard and says mismatch. my first hard drive is dead
hi pete,
changing the bios will do the trick, find one that is most compatible with aspire 1640 for a 500gig hd, once you have this replaced, it will work.
for more laptop troubleshooting tispd, you may also check the link below.
http://www.laptoprepair101.com/
hope this helps.
regards,
voodoo
Apr 12, 2009 | Acer Aspire L100 PC Desktop
Convert internal hard drive to external back-up drive
Greetings
use the cd installer that comes with "Master Cooler"
after successful installation, u can now use the Hard drive.
Jan 12, 2009 | Western Digital WD2500JS 250GB SATA2...
Simple tech 500 gig external drive
the interface has gone out, these portable drive are horrible i have 2 go bad withing months of each other.
theres not much you can do beside taking out the drive and buying another enclosure and putting it in the drive in that enclosure.
so replacing the enclosure is the only option, since the device is out of warranty. just pry open the enclosure and remove the HD, and then buy another enclosure, add the HD to it. the problem is solved.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Jul 20, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Moving files
just go to All programs<Accessories<System Tools<Backup. and choose the option you want.Once you have choosen what all you want to backup than you can choose the option for the place where you want to back it up.
Hope that works!
Dec 27, 2007 | Computers & Internet
La Cie External Hard Drive 160 gig
sounds like hd is getting hot via firewire try and use the usb lead if same problem then get your files off quick and repace drive any thing above 80 gig will get hot in use that's why I use harddrive coolers on my large 300gig 400gig internal and only use my 250 gigs and 160 gig only when i need the files off they are turned off all time
Jun 07, 2007 | LaCie (300740) 160 GB Hard Drive
LaCie Design by F. A. Porsche 160 GB Hard Drive Logo
85 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Marvin
Marvin
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
