Visio VM60P HDTV10A audio fails after warm up, crackles, distorts, hisses. Source for technical manual? Common problem? Expensive to fix?
  • wheeler7676 Dec 04, 2008
    Thanks, turned out to be the audio board, $17.00 (+$8.00 shipping).
    Only required removing/installing four screws and four connectors to replace (not counting ~20 screws securing the immense back cover).
    (My son will be more careful from now on when connecting inputs and outputs of stereo receiver... ;^)
Do you have insurance?
It may be the power supply..
Posted on Dec 04, 2008
I bought a used Luxman Stereo Receiver r113 and now my one Cerwin Vega speaker is crackling and distorted after 10 minutes of playing for the first time
As it's a stereo receiver and you specify one CV speaker, hook the speaker to the other side of the receiver and see if it still has the same problem. If so, hook it to any other audio source you may have. If it has a problem on only one side of the receiver, the receiver has a blown channel. If the speaker distorts on both sides of the receiver and on a separate audio source, the speaker is blown.
Jan 25, 2015 | Cars & Trucks
Vizo VM60P HDTV10A will not power up. Logo Dark
the unit needs to be examined by someone able to do so---first place is to look at the power supply for the set......
Aug 26, 2012 | Vizio VM60P 60 in. Plasma TV
Sound from my speakers is crackled or distorted. when I play music, at start it's working well..then afterwards there is a crackled or distorted sound...then return to normal...
Try updating your sound card audio driver and that would fix the issue.
Also install the KLite Codec pack which will enhance your audio and Video quality and also will allow you to play any video and audio formats
You can download KLite codec pack by simply searching it on google.
If you need online technical support, you may very well contact TheBestPcDoctor. I get my all issues fixed by them and it is a reliable support according to my experience. If you want you can also get in touch with them @
www.thebestpcdoctor.com or via 877-407-9229
Please Rate if you find it useful
Sep 04, 2011 | Acer Audio Driver Realtek.exe
My PS3 was working for 10mon, one day the audio over HDMI started to crackle. On dolby encoded media it would crackle and skip with an odd distortion. If I use any audio output other than HDMI on the PS3,...
sound like ur speakers are failing lol im a genious right... u probabily figured that out try playing something else through ur system not ps3 if it still crackles u should think about changing your sound system
Nov 13, 2009 | Sony Playstation 3 (PS3) Console
Technics amp crackle and ''hiss'' noise
in my car when I press the accelerator there is hissing sound,did check the air filter by disconnecting the plumbing but still the sound is present any idea what could be causing this sound.
May 25, 2009 | Audio Players & Recorders
How do you hook up the audio from Visio flat panel to SA EX 300
Wild guess. Is the TV volume turned down and its output set to variable instead of fixed?
May 17, 2009 | Technics SA-EX300 Receiver
Visio file association
- in windows explorer right click over the file and choose Open with... and then browse for and choose the viewer program
Apr 03, 2009 | Visio Technical 4.5 Full Version for PC
My reciever volume cuts in and out and crackles when adjusting
You can CLEAN / LUBRICATEthe volume control know with a CONTACT/CONTROL cleaner, I use a product from Radio Shack, this works wonders on drum type electo mechanical devices which are basically volume control knobs, easy to do, just remove the round knob and spray into the openings with the small tube attached, and rotate in both directions, be sure to unplug the unit first, on a few occasions it is best to remove the front panel to acheive better coverage to the rheostat type volume body, anyway it always cures the crackling and distorting sound, I would give this a try before replacing the part.
Feb 14, 2009 | Technics Audio Players & Recorders
Channel 2 crackles
Make sure your speaker wiring does not come close to the 12v power cable running for your amplifier. If your amplifier's 12v power cable runs on the drivers side of the vehicle, run your speaker cables on the passengers side and make sure your tweeters have a high pass filter to stop any pickup of engine sound (When you are driving you *WILL* notice it at high RPM. a HPF (High Pass Filter) will also stop those nasty hissing sounds on S's.
Feb 11, 2009 | Alpine PDX-4.100 Car Audio Amplifier
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
Electro Med Services...
