Question about Electric Bumpfeed Trimmer, 12"
Strimmer line I have a weedeater twist n' edge trimer. Line broke and I can't take a loose to fix line. How do you get to the line?
2 Suggested Answers
SOURCE: Trying to replace the line in weedeater Twist/Edgs
search youtube "change line on a weed eater" there are several videos there maybe one is similer to yours
Posted on Oct 25, 2009
Line on crafstman weedeater
wind it in the other direction.
Aug 10, 2017 | Weedeater Garden
Hoe does the automatic line feed work on a line trimer
Richard the auto line feed works by bumping the head when the strimmer is running. If it's wound right the line comes out when you tap the head on the ground when on full running.
Jan 12, 2014 | Garden
Just got a Worx GT151 trimmer. For trimming grass has worked fine. Problem is in edging the sidewalk. I start edging and it takes littleraly 2 seconds to wear the string to half it's length, needing to...
Hi Dave.
When you are using a strimmer against stone or concrete you have to just barely allow the tip of the line to touch the ground. If too much of the line slaps off the concrete, any sharp edges or roughness on the concrete will tend to snap it. What you could try is heavier gauge strimmer line which might last longer. I used to use petrol strimmer line on my Black and Decker strimmer which was 350 watt rated. I'm not sure what effect it would have in the long term though and may wear the bearings due to the extra weight.
Jul 04, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
I need to know how to restring my Twist & Edge RTE weedeater. I've looked everywhere & can't find an answer that makes sense. PLEASE Help.
I found this solution on the net. I hope it helps.
Unscrew cap and remove. Remove line guide ring. Note which way to put line guide ring back on, slot to outer edge. Remove the empty spool.
Don't take spool apart unless you need to get inside to remove string. The outer half should be yellow. Cut 25 ft. of .065 line. Start pushing the line inside the spool from the center making sure the string is winding inside in a counter clock direction which should be shown on the spool. Keep pushing until there is about only 6 in. left.
Replace spool. Then the line guide ring, making sure to pull the string through the middle of it. Then hold the string on the slot in the ring while replacing the cap.
Oct 07, 2010 | Poulan Weed Eater Rte115 4.5 Amp Electric...
Weed Eater Straight Grass Trimmer, 25 CC, 17-in. The trimmer line releases too easily and wastes most of the line.
Some of the weedeater heads are known to be ineffective and quite troublesome. Try Home Depot maybe for a universal type head that will hold and feed line the way you want. They have strimmer parts.
Aug 30, 2010 | Garden
Trying to replace the line in weedeater Twist/Edgs RTE 115c. I can not get the line to feed into the spool. How is this done?
Oct 25, 2009 | Electric Garden
Can't get weedeater spool head loose to change the line.
there is three types of heads push, screw, and snap. The screw type have a big ball looking thing on the bottom that when pressed lets the line out. the snap kind are verry distinctive they slid in and two tongs snap in to place you will be able to see them on the out side. the push head just push in and turn.
Jul 23, 2009 | Garden
Weedeater quits working/button no longer activates weedeater
try this get a good extension cord test it plug it in now with the trigger pulled wiggle the cord going into the weeder i have in the past moved the cord till i got working and taped it to the handle, if that dosent work get a new one
Mar 07, 2009 | Poulan Genuine Weedeater Part # 36006-128
Replace line in poulan electric weedeater model xt110 twist'n plu
Dear FixYa Fan, Friday 2-20-2009 10:44pm EST (USA)
RE: Poulan Lawn Trimmers
Poulan Lawn Trimmer FAQ @
Dear fitzknight: You will find instructions for putting line on your trimmer at this link click on the http line preceding but please rate me 1st or come back and rate me before you close this or the Poulan Site!
Thank You,
Feb 21, 2009 | Poulan 12" Electric Twist N Edge Plus...
Electric Bumpfeed Trimmer, 12" Logo
132 people viewed this question
Top Electric Garden Experts
Steve Oakes
JohnPaul Robertson
Are you an Electric Garden Expert? Answer questions, earn points and help others
