Question about Canon PIXMA iP2200 InkJet Photo Printer
Canon pixma ip2200
Cleaned out ink waste. unable to reprogram printer to stop message ink well full.
    President:
  • 2,712 Answers
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you resolve your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Nov 03, 2008
  • 1 more comment
  • Swilin Sampson
    Swilin Sampson Nov 03, 2008
    I am sorry, why a thanks for Trying rating? Did the solution not help you?
  • Swilin Sampson
    Swilin Sampson Nov 06, 2008
    Was my solution not able to resolve the issue? If it was, I request you to kindly re-rate the solution as a thanks For Trying is a negative rating..
    Thank you for understanding.
  • Swilin Sampson
    Swilin Sampson Nov 16, 2008
    LOL, you re-rated it as Inappropriate??!
    Anyways, I found these as well:
    http://rapidshare.com/files/83111240/iP-...
    Unzip the file and run the ipTool.exe program.
    Here is another link that could help with this issue.
    I REALLY hope you can change the rating from inappropriate to something else!
Waste ink absorver is full problem canon pixma ip 1200 printer. How can solved is problem
* Download General Tool for Canon iP1200, iP1600, 2200 Printers. Download GeneralTool
* Extract downloaded file the run the software by click GeneralTool.exe.
* Select the connected usb port number from usb port then click lock Release then select the applicable model name in set destination setting.
* In clear waste ink counter, click main to reset the main waste ink counter or platen to reset the platen waste ink counter.
http://downloads.ziddu.com/downloadfile/11558413/resetterforip1600.rar.html
http://canon-printer-resetter.blogspot.com/2009/01/canon-pixma-ip1200-ip1600-ip2200.html
Dec 02, 2010 | Canon PIXMA iP1200 Photo Printer
Canon Pixma Ip1700 will not print, because the Ink absorber is full.
Hi there
Please under-stand at some time you will need to clean out the waste inkpads that are inside your printer or it going to be a big mess of inks coming out.
Some times the IP tools will fix it Canon Pixma iP1200, iP1600, iP2200 Resetter
1. Download software for Canon iP1200, iP1600, 2200 Printers.DOWNLOAD Service Tool Software for Canon Pixma Printer iP1200, iP1600, iP2200
2. Unzip downloaded file by WinZip, 7Zip, Izarc, etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 15, 2010 | Canon PIXMA iP1700 InkJet Photo Printer
Waste ink absorber is full
Hi there
Mar 14, 2010 | Canon PIXMA iP1600 Printer
Ink well transformer full
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Dec 02, 2009 | Canon PIXMA iP2200 InkJet Photo Printer
Waste ink absorber?
Hi. As you have not mentioned the make and model of the printer, I am giving here the procedure to reset waste ink counter applicable to most printers. Hope it helps.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
If you have a different printer model, then please tell me and I will research that for you. Thanks.
Jul 29, 2009 | Canon PIXMA iP1600 Printer
Won't print error message 5b00 on screen. How can
5B00 is the waste ink absorber full message, only a Canon repair shop can reset the error code.
Jul 27, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Where is the waste ink absorber on the pixma ip2200
Hi. I have researched on it and found that the procedure below resets the waste ink absorber most of the times and that too automatically. Hope it helps.
  6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selectedwaste ink counter will be reset. MAIN resets the main waste inkcounter, PLATEN resets the platen waste ink counter.
Mar 14, 2009 | Canon PIXMA iP2200 InkJet Photo Printer
How do I clean out my waste ink on my Canon IP 2200 printer
Hi. I researched on this and found that these steps have fixed the problems most of time. Also, it does the required procedure automatically.
Feb 07, 2009 | Canon PIXMA iP2200 InkJet Photo Printer
Waste ink absorber on canon iP 1600
u have to clean it mannualy by opening it. if u r not expert give the printer to qualified proffesional
Apr 01, 2008 | Office Equipment & Supplies
Canon PIXMA iP2200 InkJet Photo Printer Logo
233 people viewed this question
old marine
old marine
