Question about HP Pavilion dv6000z Notebook
I have major probs with both my laptops...
I have a Toshiba satilite, about 5 years old that kept cutting off, so I both a OEM XP disk, and tried reinstalling windows. It won't let me get through the installation before cutting off. I plug it up and tried just with battery, sit still happens. I bought a HP that just recently cuts off before it boots. Tested the battery and plug, but still cuts off before booting. What is my problem or what should I change?
  • 51 Answers
Hi Da Doggi,
I guess there is a problem with your battery. Have you checked your battery charge? How old are your batteries?
Posted on Nov 03, 2008
  • 33 Answers
Hi
I think your problem is with the battery ac/power voltage.
Make sure of the right voltage for your Laptops is selected on the Ac/power device you are using.
In other simple words, the high voltage causes the laptop to cut off as yours, and the soloution is that you try adjusting the voltage into a lower voltage.
I hope this works!
No disk
The issue is that the PC's from Dell, HP, Gateway, etc all have what's called OEM licenses. If you look around on the PC/Laptop, you should find a Windows sticker that says exactly what is to be loaded onto it (Windows XP Service Pack 2, for example). Sometimes the manufacturer will make a partition to load the install to on the hard drive - so the first thing to check is if there is 'boot options' key on startup - see if you have a recovery console or a factory settings area.
If you where to try and install a copy that doesn't match, it will fail outright. If you install it to another PC and image it over - it will need you to repair it, and won't let you do that without the proper disc. Your best bet might be to look on eBay or on the manufacturers site for a match for the OEM sticker - "Dell OEM Windows XP Home SP2" for example.
Hope that helps.
Apr 11, 2013 | Dell LATITUDE Computers & Internet
How do I remove the hard drive in Toshiba SatellitePro A10 EN? (Removing the plastic cover exposes only the end of the hard drive. I'm reluctant to just start pulling on it!
  • The original Toshiba Satellite Pro A10 HDD is fitted into a Toshiba Satellite Pro A10 Hard Disk Drive cradle - Toshiba Satellite Pro A10 HDD caddy.
      • Gently remove the cradle from the laptop, yes pull on it
      • Unscrew the original Toshiba Satellite Pro A10 Hard Disk Drive & remove it from the cradle.
      • Screw the new Toshiba Satellite Pro A10 Hard Disk Drive into the cradle & refit the cradle into the laptop.
      • Re-install XP or Vista
          Aug 21, 2010 | Toshiba Satellite A10 Notebook
          I need to get back in my OEM vista home premium
          If you contact Toshiba, they can send you the original restore disks. If you are really nice to them, they might send them out for free.. I believe normally they do charge but they sent them to me for free a couple of years ago with my Toshiba laptop :)
          Jul 12, 2009 | Microsoft Windows Vista Home Premium with...
          Satilite 1800 3 beeps no boot 1 long 2 short
          That is a memory error. Remove and reseat the memory in your computer. If the error persists and you have more than 1 stick, try each stick separately to find the faulty unit. If you only have one stick, then the memory will need to be replaced.
          Jun 30, 2009 | Toshiba Satellite 1800-S204 Notebook
          My windows xp did not pass genuine license
          If you just reinstalled xp and used a OEM disk to do it instead of the restore disk that came with the laptop Microsoft WILL NOT accept it as a genuine copy if windows since you "stole it" since you did not use the branded version of windows that came with your laptop. They changed this policy a couple of years back and is a major pain.
          If thats what you did you will need to buy a restore disk from the manufacturers website.
          Apr 10, 2009 | HP Compaq Presario C700T
          HOW TO FACTORY RESET TOSHIBA SATELLITE NOTEBOOK
          That model Toshiba does not come with a recovery CD, does not have a restore partition, and does not allow you to creat a recovery disc when working normally, so unfortunatly you have 2 choices.
          1. Call Toshiba and try to get them to mail you a recovery disk, if they have any they will likely charge you for the disk + shipping.
          2. Reinstall windows manually using a clean install, you can use any OEM windows disk as long as it is the same version as your windows product key on the bottom of the laptop (i.e XP Home/XP PRO/ XP MCE/ or VISTA - all vista disks are basically the same and have all 3 versions on them)
          Make sure you have backups of the drivers for your network adapter and other hardware before doing a clean install.
          Jan 22, 2009 | Toshiba Satellite A205-S4617 Notebook
          Wireless not working
          first check whether the wireless switch on ur laptop is turned ON orn't.it should be kept always on
          Nov 22, 2008 | Toshiba Satellite M55-S135 Notebook
          To insatall xp os in toshiba laptop fresh
          make sure you use all the OEM disks with the drivers. if this laptop was not originally XP, use the previous OS that came with the system. and then upgrade to XP
          Aug 16, 2008 | Computers & Internet
          Xp drivers problem
          may you please be specific with the model number of your notebook and the kind of drivers that you are in need of.
          Jan 30, 2008 | Toshiba Satellite A135-S2276 Notebook
          HP Pavilion dv6000z Notebook Logo
          73 people viewed this question
          Top HP Computers & Internet Experts
          pontelemon
          pontelemon
          Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
