Question about British Telecom Response 15 Digital Answering Machine
Missing outgoing answerphone message
Folk can't hear the outgoing message on my answerphone, although it sounds fine to me! Otherwise it's working perfectly so I'd rather not bin it. Suggestions please!
  • 945 Answers
SOURCE: When testing the outgoing message the volume seems
If you click on the above , go to p.11,12 on setting the volume .
I agree with everything you say the only thing I can add is you may not be setting the volume correctly see note on p12.
Hope i`ve helped.
Posted on Dec 10, 2009
0 characters
1 Points
How do i get messages from remote location
To use your system from a remote telephone, you must first enter a 3-digit remote operation security code. The security code label is located on the bottom of the system.
1. Dial your phone number.
2. When your outgoing message is playing, enter your remote operation security code. Bd appears on the display to indicate the system is in remote mode.
If there are no new messages, you hear three beeps.
These are the remote codes available to you:
2 # Play all messages.
2 5 Play new messages.
3 # Delete all old messages.
7 # Record new outgoing message.
7 # Stop recording outgoing message.
8 # Record memo.
8 # Stop recording memo.
9 # Turn system off/on.
0 # Monitor the room..
Jun 12, 2011 | Radio Shack 3822 Digital Answering Machine
I have a Radio Shack digital answering machine 43-3808A. It is supposed to allow me to check message remotely but I cannot get it to work. I noticed another message at this website saying the same thing...
Looking at the manual
The code is NOT changeable as near as I can tell. It is written on a label on your unit.
When it answers, after it plays the message, you should type in that 3 digit code. Suppose it is 123.
You should type in 123 and then immediately enter the command you want.
Try 9# to record a memo, and see if it records. That is, type 1239#, and you should be able to record a memo I think the two tones is a misprint. Most of the time you enter the code either while the outgoing message is playing, or immediately after the outgoing message finishes.
Mar 23, 2011 | Radio Shack 3808 Digital Answering Machine
Hope i`ve helped.
Dec 10, 2009 | British Telecom Response 75 Digital...
Cannot set up voicemail on a Binatone 1210 DECT
Please follow the below mentioned process:
1)press menu
2)press up/down to tam
3)press ok
4)It will say play(press ok to play messages), or press up/down till delete all
5)press ok it will say confirm
6)press ok this will delete all messages. If you want to record your own message follow steps 1 to 3 then 4)up/down till ANS MODE press ok,
7)scroll up/down it will say, ANS ONLY or ANS + REC,
8)select ANS + REC, press ok,
9)it will now say PERSONALIS(your own personal message) or PREDIFINED(standard answerphone message), select PERSONALIS press ok 8)now it will say PLAY MSG scroll up/down it will also say RECORD MSG, press ok hold phone to your ear till you hear a beep, record your personal message then press ok, if you go back to step
10) you can hear your message.
In normal mode, Press and hold 0 key to turn on/off answerphone and your personal message will be on.
To delete messages press 2 key for 2 seconds as messages are played press 6 to delete, you can delete messages before or as they are playing without listening to whole message.
Please let me know if the provided information has been helpful.
Please rate me if the information provided was able to help you.
Sep 17, 2009 | Answering Machines
Creating an Outgoing message that tells a caller to leave a messa
To Create Your Personal Greeting:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
Please let us know if that was helpful enough.
Good Luck & Thanks
Aug 13, 2009 | NorStar Flash Voicemail Power Supply Only...
Nseed to reset message on answering machine
There are two models - The TRU8885 and the TRU8885-2 -
For the TRU8885 the manual PDF form >>>Click Here<<<
The solution is on page 24 + 57 It starts on Pg 24 as...
Record Greeting allows you to record a personal outgoing message (greeting) which
the answering system automatically plays when you receive a call.
1) Enter the Answring Setup menu, and then the
Record Greeting sub-menu (see "Entering the
Menu" on page 16). To record greeting press
[STA RT] appears.
2) Press the START soft key. You will hear “Record Greeting.“ The message counter
displays 30 and then begins to count down.
3) Position yourself near the base microphone and record your greeting.
4) When you are finished recording, press the STOP soft key. Your greeting will
playback for confirmation.
Selecting Your Greeting (Base only)
Select Greeting allows you to choose between the two outgoing messages, a prerecorded
message or your own greeting.
1) Enter the Answ. Setup menu, and then the
Select Greeting submenu (see "Entering the
Menu” on page 16). P lay back greetin g
appears, and the current outgoing message is
played. LCD is an example if you recorded your greeting.
2) Once you have recorded a personal greeting, press the CHANGE soft key to
choose the greeting. The selected outgoing message is played. Each time you
press the CHANGE soft key, the phone switches the outgoing message between
the prerecorded and the personal outgoing message.
There is more on the PDF - Just ask if you need more
For the TRU8885-2 is essentially the same. The manual PDF form >>>Click Here<<<
If we need to dig further, just ask! :) We are just a mouse click away!
Mar 07, 2009 | Uniden TRU8885 Digital Answering Machine
One tel magma 300 - can't change message on answerphone
1) Press the 'tape' symbol to access the answering machine mode.
2) Press 9 then 1 for 'answer and record'.
3) Whe you hear a 'beep' speak your message. Whilst recording the display shows REC OGM1 or REC OGM2
4) Press 5 to stop recording. Your message is played back to you
5) Press 'tape' symbol to exit.
To check your Out Going Message (OGM)
1) Press 'tape' symbol
2) Press 6 then 2 and the message is played back.
Jan 26, 2009 | GE 29888GE1 Digital Answering Machine
Greeting message
To Record Outgoing Message on Radio Shack’s Answering Machine [Model 43-3829]:
Press and Hold the ANNC/DAY/<< button. You’ll hear a beep; continue to hold down the ANNC/DAY/<< button and record your message. When recording of your [outgoing] message is complete, release the ANNC/DAY/<< button. Your message will automatically play back for you.
Please let me know if you have additional questions. Thanks!
Take care,
Gail :-)
Sep 17, 2008 | Radio Shack (43-3829) Digital Answering...
Outgoing greeting
Press and hold down the "greeting A" button. You will be instructed as to when to start your message. When you are done recording, release the button. To hear your recorded greeting, press the "greeting A" button again.
Jul 15, 2008 | GE 29869GE2 Digital Answering Machine
British Telecom Response 15 Digital Answering Machine Logo
22 people viewed this question
Top British Telecom Answering Machines Experts
Are you a British Telecom Answering Machine Expert? Answer questions, earn points and help others
