No power to wall control panel for ducted heating
  • 31 Answers
Either a tripped breaker,blown fuse or bad transformer
Posted on Nov 17, 2008
F1/08 vulcan fault code
Hi Geoff,
Is your heater a ducted gas heater how old is it and what does the wall control look like.
May 10, 2014 | Heating & Cooling
Tip
Free heat from your own furnace
to greatly increase the efficiency of all forced air heating systems use aluminum duct tape and tape all joints in the ductwork The hot air ducting from the furnace right to the register in the floor or walls should be air tight to keep heat from escaping .Also the cold air returns and all associated ducting should be taped at all joints to ensure maximum air flow . Taping all ducting will not only provide more heat to all rooms of your house it will also produce less dust from leaking cold air ducting which sucks in air and dust from areas typically not cleaned (wall and floor cavities) . I did this in my older home and found I had to close off some registers because of the huge increases of volume which provided extra heat volume for the rooms that needed it.The house is now consistantly warm in all parts
on May 07, 2010 | Heating & Cooling
Where is the heater core located
printer.png View & Print Options 30_vwcd9804passat-001.png&width=469&height=540&displaytype=display&imgrotation=&links=
LEGEND
1 Clip
2 Dust and Pollen Filter
3 Air intake housing
4 Defroster air outlet
5 Side window air outlet
6 Heating and A/C controls
7 Air outlets
8 Instrument panel cross member
9 Defroster duct
10 Servo motor for fresh/recirculating air door -V154-
11 Ambient temperature switch -F38-
12 Gasket
13 Evaporator water drain guide
14 Heating and A/C unit
- Heater core
- Evaporator
15 Fresh air blower -V2-
16 Fresh air blower series resistance with fuse -N24-
17 Center air outlet
18 Control panel trim
19 Center trim
20 Heating and A/C cables
21 Heater core
22 Left rear duct
23 Lower duct
24 Upper duct
25 Footwell air outlet
26 Instrument panel cross member, left side member securing bolt
27 Relay
28 A/C cut-off control module -J314-
29 Instrument panel
var classElements = new Array(); var node = document; var tag = 'a'; var els = node.getElementsByTagName(tag); var elsLen = els.length; var pattern = new RegExp("(^'\\s)specs_note(\\s'$)"); for (i = 0, j = 0; i
Jun 03, 2011 | 2000 Volkswagen Passat 4Motion
Model LEQ6000ES Affinity Frigidaire electric dyer purchased 5-29-06: tumbles but won't heat. Cleaned all air ducts and lint trap and still won't heat. Error codes not obvious. What else can we check?
you will need to check the main power and make sure there is 220 volts at the termianl block if that is goor then you will need to check the heating element an all thermal fuses.
remove the small panel in the back of the dryer so you can get the belt loose.
then remove the lid.Take out the four screws that hold the control panel in place.
then remove the screws that hold the front panel on and then remove the drum lift up on the back of the drum to get it loos e from the carrier bearing holder thenyou can get to the heating element and thermal fuse on the back wall of the dryer and the side wall of the heating element can.
Jan 08, 2011 | Frigidaire Electric Dryer
Heat does not come out passenger side of the car but comes out drivers side
There is a blend door problem.
prev.gif next.gif HEATING AND AIR CONDITIONING Refer to Section 1 for discharging and charging of the air conditioning system. The heating system provides heating, ventilation and defrosting for the windshield and side windows. The heater core is a heat exchanger supplied with coolant from the engine cooling system. Temperature is controlled by the temperature valve which moves an air door that directs air flow through the heater core for more heat or bypasses the heater core for less heat. Vacuum actuators control the mode doors which direct air flow to the outlet ducts. The mode selector on the control panel directs engine vacuum to the actuators. The position of the mode doors determines whether air flows from the floor, panel, defrost or panel and defrost ducts (bi-level mode).
Oct 28, 2010 | 1998 Oldsmobile Regency
No heat/// blower works
First, check the duct work! The most common "no heat" problems with dryers are caused by duct work blockage. If your duct is blocked, it will overheat the unit, causing it to shut down the heat source (gas or electric, it doesn't matter). Most units will continue to "blow" without the heat. Remove the duct work, remove all lint from the duct and "exit" port of the unit. Then, check the wall duct, both inside and outside the house.
Feb 14, 2010 | Dryers
Converting a ceiling control unit to a thermostat on the wall.
Unless the new unit is 24 volt thermostat convertible inside the unit, you will have to use a line voltage(120v) wall thermostat.
Mar 25, 2009 | Coleman Heating & Cooling
Vulcan CX Central ducted heating. RE: Following a power outage the control panel does not respond, I have checked the pilot light and it is still on. I need to know how to reset the time and get it to...
The control panel gets its power from the central heating unit's power point. Try turning the power off outside at the powerpoint next to the ducted heating unit and try turning it on again after a few seconds, see if it resets
Jul 06, 2008 | Heating & Cooling
Vulcan ducted heating not working
How many wires for the thermostat do you have? If you tell me I can help. The green flashing, instead of red, in my experience, means a thermostat problem.
Feb 24, 2008 | Heating & Cooling
Heating & Cooling Logo
111 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
