Question about LG VX8100 Cellular Phone
LG 8100 i was making a call and my LG 8100 turned itself off on me and then turned itself back on. It has turned itself off before but i've never seen it turn back on again. Why would it turn off out of the blue for no reason?
  • Imatt015 Nov 03, 2008
    How do i stop this from happening, it does it quiet frequently and i can't imagine that there are than many updates so there must be a problem with the OS right? What can i do with it?
  • Imatt015 Nov 04, 2008
    Thanks j_e_n_n_i if thats all that can be done i guess that i what i'll have to do
  • 51 Answers
Hi Imatt015,
This is called "restarting". The mobile when restarting turns off and turns back on just as it happens to our PC when we restart it. This may happen at times when the OS of the mobile has encountered a problem or if there is some updates to any software in the mobile.
Thanks.
Posted on Nov 03, 2008
  • j_e_n_n_i Nov 04, 2008
    You can take your mobile to repair service person and get the OS of the mobile setup again. That would help.
LG Rumor 2 turning on and off.
First, make sure if this problem appear after you install any APP, if so you can try to brush system to fix it.
Else maybe the following cases:
1, mobile phone motherboard leakage lead the current too large.
2, The inside circuit protection of the lithium battery is too sensitive, so it power off when circuit is large.
3, the battery itself is aging.
4, Battery contacts are dirt-bit, causing bad power supply.
5, The engagement between the battery and the phone is easy to loose bits. (try to remove the back case and press the battery then try to turn on it to see if it also turn off and on). If so, just make a piece of paper to stand the battery up
Of course, don't forget to see if the power button is back to its own place
Apr 08, 2013 | LG Rumor 2 Cell Phone
Light stays blue and it dont turn off
I've seen this happen on a lot of other online forums for this same headset. Even on the Plantronics site itself. It says it is a defective unit and you should take it back to the retailer you purchased it from or contact them directly.
Feb 24, 2012 | Plantronics Explorer 220 Bluetooth Headset...
I have a apex 40 "lcdtv model #ld4088 and the screen cracked inside and i turn it on the cracks can be seen will that be worth to fix
Unless someone is giving away a good lcd panel that is compatible with this model or selling it/auctioning it off for a reasonable price it will cost you 80% of the cost of a new television at the least to repair this. In a lot of cases the panel itself can cost thousands of dollars (I've seen them run as much as $10,000). The labor will add to the cost. The only entities I've seen repair broken panels are the network news stations because the cost is coming from the television station and not out of anyone's pocket.
Apr 15, 2011 | Apex Digital Televison & Video
Dryer won't turn on at all.. There is power to it because it shocked me and the washer runs. Do you have any idea what might be wrong?
Wait a minute, the dryer shocked you? I've seen this happen twice, where I got shocked and the dryer welded itself to the washer. Ok, you may have a electrical issue with house wiring. Or, someone may have wired the dryer cord incorrectly to the dryer. I've seen both. I would address the "shocking" issue and once it's solved it most likely will fix the Dryer operation.
Oct 12, 2010 | Kenmore 98702 Stacked Washer/Dryer
47 Inch LG HD TV -switches itself off and remain off for days
He may be right, LG is used to be called GOLD STAR, which makes junky electronic products, they changed the name to make it sounds better.
You may be able to get parts here: http://www.shopjimmy.com/catalogsearch/result/?q=LG+42LC2D+
Dec 15, 2009 | LG 42LC2D 42 in. LCD HDTV
LG LCD TV model 42LH70YR switches on and off continuously
eduramagli@gmail.comHELP PLEASEEE!! I`VE THE SAME PROBLEM! MY 42LH70YR SI CONTINUOUSLY TURNING ON / OFF !!
PLEASE IF SB KNOWS HOW TO RESOLVE IT SEND ME AN E-MAIL. IM FROM URUGUAY
Oct 06, 2009 | LG Televison & Video
My blackberry pearl pink has suddenly started over the last week to shut itself off, even with a full charge. It never did this before. what is going on, I can't depend on my phone anymore, it shuts off...
Have seen this on the blackberry forums and there is no real consensus on what causes it (other than memory leaks). You can try doing a hardware reset (pulling battery and sim card, letting it sit for a few minutes and putting sim card and batt back and turn on). I have 4.5 on my Blackberry Pearl and have not experienced and weird OS resets my self unless I have too many apps open. You can try updating the OS by going to your respective carrier. Mine is Tmobile and you can find the 4.5 for the 8100 here
Hope this helps,
Bill
Oct 04, 2009 | RIM BlackBerry Pearl 8100
LG Viewty KU990 - mine keeps switching itself off and then won't switch back on - any ideas please??
I think your battery is running out of power so
recharge it and wait for 1 or 2 min.
If not then you've to replace the battery.
I hope this will help.
Best regard:
Henk®Muskita ©2009.
Aug 06, 2009 | LG KU990 Viewty
Our LG 37LB1DA is scrolling through channels
I have seen problems similar to yours in the past. Several causes can make the channels change by themselves. Some corrosion on the main board near the channel up/down switches for one. The next common cause is that the EPROM may be failing or a fault with the main control processor. A good test to see if the EPROM is having a problem is to program in all the channels off the cable and then unplug the TV over night and then plug back in the see if any channels are missing.
Jan 17, 2009 | LG 37LB1DA Television
LG VX8100 Cellular Phone Logo
159 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
