Question about Zanussi Washing Machines
Zanussi XC1200 washer - I need the button sequence to reset the electronics unit
2 Suggested Answers
  • 118 Answers
SOURCE: filter was blocked so now washer needs resetting
Have u unpluged it for 3 mins and plugged back in to see if that works hope this helps
Posted on Sep 13, 2009
I have a zanussi lindo500 washer, a lock symbol appeared but when I press the temp button and spin button together is still doesn't disappear so I can't set my machine to wash, can you help please?
Unplug the washer from the wall socket for 5 minutes and see if the system resets, if not then you need a service call most likely or help from a friend who knows washing machine repair.
Sep 22, 2016 | Zanussi Washing Machines
How to reset Zanussi zdt6252 dish washer
To reset a programme in progress, open the door and press the push button of the programme under way for more then 1 second, until the corresponding indicator light goes out. The dishwasher is now reset and you can select a new programme.
Dado
Mar 03, 2015 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Fault code 9 fisher and paykel
With the board replacement, did you program this board for this unit? If not, thats the problem you have now. Good Luck
Aug 04, 2014 | Fisher and Paykel WL26CW1 Top Load Washer
What does e60 mean on a zanussi
E60 - Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
Pressed the reset button in for 5 seconds and it stopped . The computer board needed resetting. Checked the electrical installation already twice to ensure adequate voltage and grounding.
Hope helps (remember to rate and comment this answer).
May 31, 2011 | Zanussi ZWF1440 Front Load Washer
I'd like to know the key sequence I need to press to be able to self-diagnose the problem I've got with my zanussi washing machine. ZWF1640.
To display Error Code:
Move Programme Selector to the Off postion.
Press the 2 buttons on the right and turn the selector 1 position clockwise and hold the 2 buttons for about 5 seconds until all the lights are flashing. Release buttons and turn the selector to the 10th position. The Error Code will be displayed.
Note the code then turn the selector to off ,then on,then off again.
Feb 28, 2010 | Zanussi ZWF1440 Front Load Washer
How do i reset zanussi washing machine ZJD12191?
There is ne reset button in the washer to reset, I suspect that when you tipped the washer over, water has got onto the electronics,, more so since you can here it hissing,could prove to be expensive.
Hope this helps.
Jan 17, 2010 | Washing Machines
How to reset the control unit?
press heated Dry , Nornal, Heated dry Normal: The machine will go into diagnostic mode. this may reset your control.
If not clear the fault, unplug the power cord,open up the electronic control panel again and check your connection, maybe the wire harness to the drain relay pin is not connected correctly.
Jul 26, 2008 | Dishwashers
Error code e60
Hi I had this on my zanussi not long ago I pressed the reset button in for 5 seconds and it stopped . The computer board needed resetting. Hope this helps
Jul 07, 2008 | Zanussi ZWF1440 Front Load Washer
Zwf1430w display problem
My Zanussi ZWG1120m is displaying fault code E60 and E62
I have ben told that the machine needs to be reset. lease can anybody tell me how to reset the machine.
Feb 08, 2008 | Zanussi ZWF1430W Front Load Washer
Washer will not work
Possible drain fault, check filter. Regards Advisor
Jan 28, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
73 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
