Question about ASUS Computers & Internet
P5sd2-x motherboard installed, load windows, then continual blue screens. Phil
  • bphil717 Nov 03, 2008
    Hi Douglessd,
    That was the end of a very long saga, had a lot of trouble even getting it to load windows, tried a variation of memory, bios updates, bios reversion to older versions, I have one board that doesn't even get that far, you can open the bios, do your thing, exit, commence to load windows (formatt etc) ... guess what.......blue screen. (Yes I finished up buying another, but that one I at least was able to load windows, but that was all. After the initial loading, it was all over) I'm thinking about binning them, but I thought perhaps I would give them one last try.
    Cheers,
    Phl
  • 284 Answers
Will it boot in safe mode?
It is probably a corrupted system file but that is just a guess, you have not given us much to go on.
Posted on Nov 03, 2008
  • Douglessd
    Douglessd Nov 04, 2008
    One thing I would try is to take out all non esential bits. Remove any cards, leave only one memory chip in, Then swap bits to see if the problem goes away. I know this is time consuming and it sounds like you have done some of this already.
    You have two mother boards with a similar problem?
    Are you using any common bits while trying to get them working?
    The bin might be the way to go but I guess you have to convince yourself that they are stuffed.
My operating system is windows 7 home basic.my mbd is p5sd2-vm.i can't install the audio driver,my pc has no sound.
Please use this link and it will redirect you to the webpage where you can download the right driver for your motherboard.
You need to save the file once you download the driver for you to have a copy for *********** board audio driver.
http://www.dl4all.com/sus/tag/asus+p5sd2+vm+audio+driver+for+windows+7.html
OR
http://ph.asus.com/Motherboards/Intel_Socket_775/P5SD2VM/10_15_2012_2_33_07_pm.jpg
Oct 15, 2012 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Hi, Sir i am using Mother board P5SD2- VM...and in my Pc i am using Windows 7 but in my PC screen resolution is not changing... plz tell me how to change as in screen resolution only 2 options are...
hello csvaibhav22, have u already install the VGA driver? maybe u need to check if your VGA is right installed or not at device manager.
go to start menu then type devmgmt.msc at search box, u will get the link then click it. after device manager window is open then check the display driver. if there is mark (question or exclamation mark) then u need to install the driver. u can find the driver at motherboard CD.
1. insert motherboard CD to CD/DVD drive 2. on device manager window, right click display the mark then choose update driver. 3. when installation window open, then follow the guide (if u don't want to get confuse, then just click next till it finish the installation). your driver will automatically installed.
hope this useful, regards.
Sep 22, 2011 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Asus p5sd2-vm sis 968
Hi, you can download drivers here and a manual:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5SD2-VM&p=1&ft=3&os=29
Please select your windows version.
Select the file you want
and click on global for download.
Unzip the file before installation.
Sep 14, 2011 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Dispay driver not installed for asus p5sd2-vm motherboard for windows 7 plz help me
Usually Windows 7 does a pretty good job with the video drivers.
You can try downloading the driver from the manufacturer's web site at:
http://support.asus.com/download/options.aspx?SLanguage=en
May 20, 2011 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
I have ASUS P5SD2-FM SiS 649DX Socket 775 mATX Motherboard my problem is >> i can't download windows xp on the deskdrive because (as i think ) the motherboard didn't recognise the drive...
XP needs an PATA disk to install, it won't do it on a SATA disk. So just add a small IDE disk besides the present SATA one and install XP on it (and only it). Then load all your files and installed programs and files to the SATA one.
This board is a custom one, made for Fujitsu - there is no new BIOS for it anywhere.
Apr 20, 2011 | ASUS P5SD2-FM SiS 649DX Socket 775 mATX...
Windows 7 drivers for asus p5sd2-vm
Hi supunkkds,
Windows 7 should be able to install the drivers for that motherboard automatically. You don't need to update any drivers except for the updated NIC(network) HERE.
Hope this helps.
Feb 22, 2011 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
I have loaded window 7 an wan to play game ...an it was giving error not enough video memory need vga driver for window 7
hello
try to install external video memory at leas 512 mb, and make sure that the vga driver of your motherboard is installed.
thanks
Dec 23, 2010 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
My audio is not working showing audio deviceonhighdefinationbus
Hi abdulaziz021,
click on the Asus link below. As the site loads, choose your operating system from the drop down menu. Download the audio driver & install. Make sure your AC'97 is set to AUTO/Enable in the bios.
http://support.asus.com/download/download.aspx?modelname=P5SD2-A&SLanguage=en-us
If the audio driver fails to install, check windows control panel, sounds and audio devices. Make sure AC'97 is listed the Audio & Voice tab. If not post here.
Mike
Jan 10, 2009 | Asustek S775 Intel X38 ATX Audio Lan...
Computers & Internet Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
