Lost volume possible blown fuse - Televison & Video
    Genius:
  • 2,920 Answers
It could be your amplifier went out,,,i dont think it runs on a separate fuse
Posted on Nov 03, 2008
Something blew during a loud performance and now it produces continual high-freq feedback that can't be controlled.
The speaker may be blown, but if you're getting continual Hi-freq feedback that is not resolved by lowering the volume know, you need to take this to the repair shop.
Apr 28, 2015 | Behringer Ultratone K3000fx 300w Keyboard...
Hartke vx115 lost significant volume
If you've tried different heads with the same result, the most likely problem is a blown speaker. Check it with an ohm meter, and if it's blown, you can either replace it or get it re-coned.
Apr 24, 2015 | Hartke VX115 - 1 x 15 Bass Guitar Cabinet...
All of the lights are not working except the head lights I had all them working until i installed a different radio i have checked the fuses and the plug on the steering column
Check the wiring on the radio again ,now iam not sure about this as its an older vehicle but some vehicles use self volume adjusting and light feed for panel lights and its possible you have connected to a light feed or wired this to earth and blown the fuses .Look under the bonnet in the power distribution box in case you have blown a fuse in here that feeds it all .
Jan 21, 2011 | 1987 Dodge Ram Wagon B350
A friend owns a Mirage LF 150 subwoofer a few years now. Someone had left the volume setting very high on the preamplifier and turned if off. When the preamp was turned on, there was a loud...
You would have blown the fuse. There was a reason why the fuse had blown the first time. Being that this unit is self powered. I would look into the power supply board and look for blown caps. Hopefully you didn't burn the board. Most times a problem like this is a bad Capacitor. Look for blown Capacitors on the board. They will Look like little soda cans. They would be buldging on the top of the cap and possibly leaking yellow or white if bad. Capacitors should be FLAT not having buldge at all. Replace Caps with exact uf EXACT on the Volts you can go over what is printed on the bad Capacitor but never go under. Caps can hold a wallop of a shock and possibly kill you. So either you or a pro discharge the caps. They can hold a punch and knock you on your but. Even unplugged. So Discharge them and proceed.
Dec 26, 2010 | Audio Players & Recorders
Hello, after plugging on Ipod through my preamp hooked through my krell kav 300 integrated amp I heard a super loud noise and lost power. I examined the fuse and it looks fine. What do I do?
Sounds like the volume was way up when the iPod turned on. iPods are DC and cause a sudden thump through the speakers when they power on.
If the fuse is not blown, there may be another fuse you have not seen. Most amps have three to five fuses especially a 150watt/channel like the Krell.
Apr 17, 2010 | Krell KAV-300i 2-Channel Amplifier
Cannot take unit out of standby mode. Brand new unit. . Was playing at relatively high volume and then it bounced to standby and now won't budge. Originally switched it by using "selector" button as I was...
It sounds like you've either cooked the output stage or blown a fuse or two. Some amps use relays to protect speakers whilst others use old fashioned fuses. Check the rear of the amp to see if there are fuse holders. If there are then unplug the unit and check each fuse. If they are marked as mains or power leave that alone it's for the 120volt input. the ones you want are usually marked left and right or just speaker. If the speaker fuses are cooked then make sure you use the same rating when replacing. Also check your speakers, they could be cooked too. Unlikely but possible. Some makers hide the fuses internally which can make things dangerous for anyone poking around. If in doubt leave it to a tech. If the fuses are blown replace them. check your speakers and plug in and swich on. If the fuses blow again go looking for a repair shop as you've possibly blown the output stage.
Apr 10, 2010 | Harman Kardon AVR 235 Receiver
96 goldwing radio no volume
Had the same problem, there is a fuse on the left side, way down under all that stuff, it is just a line fuse to the radio, it has blown, it is not in the book, and it hides real good. Drove us nuts looking for it. And when we were ready to buy a new radio, we found the fuse. Took 8 hours to totally dismantle bike to find it. Will take you 10 minutes, good luck.
Jul 24, 2009 | Honda GL 1500 Aspencade Gold Wing...
No volume
bEFORE i CAN HELP YOU I NEED TO KNOW WHAT 'UNIT' MEANS. IS IT A STEREO RECEIVER OR WHAT. WHENEVER I TURN ON A STEREO RECEIVER AND HAVE NO SOUND ITS USUALLY POINTS TO THE FUSES IN THE BACK. ONE OF THEM IS BLOWN. IT COULD BE THE SPEAKER CONNECTION BUT I DON'T KNOW WHAT KIND OF UNIT IT IS.
Apr 10, 2009 | Denon DRA-685 Receiver
Bloon Fuses!
You don't need schematics to replace the fuses.
Open the speaker unit by unscrewing the back. The fuses are located near the on/off switch assembly. Replace them and screw the the unit back together.
To avoid blown fuses, try lowering the volume.
Aug 18, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Electro Med Services...
