Question about Sharp AJ-5030 InkJet Printer
Clean up scanner error
I get this error message. Have cleaned the scanner carefully about 8 times, including using alchohol. I've even reset the machine and cleared all data.
Any suggestions. Can't fax or scan.
Thanks for you help.
Drivers
Posted on Jun 13, 2009
Unable to print 48
Clean the plastic encoder strip thoroughly
In order to access both ends please follow these steps
1. After the error message is displayed on the LCD or display, open the scanner cover, so the print head is visible.
2. Press and hold the Stop/Exit key for 5 seconds. The print head will move to the middle.
3. Unplug the power cord from the power outlet.
4. Use a clean lint free cloth dampend with a bit of alchohol and clean both sides of the encoder strip thoroughly. Move the print head from side to side to allow access for cleaning of the entire encoder strip.
Feb 25, 2014 | Brother MFC 6490CW InkJet Printer
Paper out error
Have you tried a full media calibration from the menu (removing 8" of label from the backing)? Also if a label has left any pieces behind on the rollers, strike plate, etc it can cause this problem. I use a solvent like Goo Gone to make it clean, but be careful not to wipe the sensors with it. Also I have seen this when my users miss a roller when loading the ribbon. Make it clean, load it carefully and usually it works.
Jul 25, 2012 | Zebra 170XiIIIPlus Thermal Label Printer
"clean and reset filter" alert is displayed even
You can reset the "Filter Time" on your projector and it will clear this error out of the system.
1) Clean Filter
2) Turn the power on
3) Hit the Menu button
4) Once the menu appears choose "Options"
5) Choose "Filter Time"
7) While the time is displayed hold the "Reset" button on the remote for 3 seconds
8) The "Reset" menu will pop-up and choose reset.
That should take care of it.
Mar 14, 2011 | ViewSonic PJ501 Multimedia Projector
"Warning Clean Roller"
Well, If you get this message you should reset the cleaning counter.
When this message occures, push both arrow buttons below the display at the same time to reset the counter.
Happy scanning !
Jul 21, 2008 | Kodak Digital Science 2500D Path-Through...
RE: SENDING FAX
The scanner glass is dirty or needs replacement. lift up the scanner door where you put original in. See the glass strip 1/2 inch by about 8 inches. clean with alchohol good. dry. test. Lawrence
Jul 18, 2008 | Sharp FO 77 Roll paper Thermal Fax
Cleaning it out with rubbing alchohol?
the outside and under the cap for the joystick :) e-mail me at fixya (at) whypayforhelp.org
Jun 19, 2008 | C-Technologies C-Pen 600C Handheld Scanner
HP LaserJet 2840 Scanner Error
when poering on this HP 2840 it says" Scanner Error 5"
what does it mean? How to get a solution?
Apr 16, 2008 | HP LaserJet 2840 All-In-One Printer
Need to reset purge counter due to error 46
MFC-5440CN saved from the tip!
"Unable to Clean" message - found TrickyDicky's sltn 4 for various printers.
Went into maint mode as per sltn 4 - verified error 46.
"The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed."
Keyed in 80 - stepped through the items with "down" key and located Purge Counter.
"Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero
Press the Stop/Exit key to return to the initial stage of the maintenance mode.
Press the 9 key twice to return to the standby state."
This worked brilliantly - no need to tamper with any parts of the printer. Purge Counter reset did it all. Fully functional printer.
Thanks TrickyDicky for info on verifying the error code and purge reset
Mar 27, 2007 | Brother MFC 210C All-In-One InkJet Printer
Sharp AJ-5030 InkJet Printer Logo
98 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
