Question about Sony FD Trinitron WEGA KD-27FS170 TV
Set-up screen keeps popping up
The Set-up screen asking if I want to Auto-Program keeps poping up on the screen in the middle of a show. If I hit the Channel up button to Yes auto-program it stops the auto-program preocess in the middle adn I get all snow, Hit + or + a couple of times adn the pix comes back but the screen pops up again in a few minutes or less. If I hit channel down to exit it comes back even faster. I don't want to throw it out as the pix is still very good, but this is real annoying.
    Sergeant:
  • 337 Answers
This might not be a solution but it is a suggestion,your set by now has many loose conections this is as true as your name Less,I would suggest to go in looking for loose conections and overheated ares,while you are looking check the horizontal driver transformer and make sure all 4 legs are solid,this is only as a preventive maintenace,as far as the reason why is doing what is doing I got a feeling you will find an intermitant conection.If you are not familiar with tv service be safe and call for assistance.It should not be expensive.
Posted on Oct 02, 2006
SOURCE:
How do i get the flash off
Most cameras, when set to automatic, will pop up the flash, when the lights are to low. As soon as you switch to a manual setting, with Aperture or shutter priority, the flash should stay where you put it. Down and if should not give any light. So check your settings and don't use Automatic or P(program)
Jan 24, 2015 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
How do I remove volume icon from the middle of my iPad screen?
You might try this...you can set your side button on upper left corner edge of ipad to either mute volume or lock screen (stop it from rotating). Check how yours is set...Go into settings>general>Use side switch to:
see if it is set on mute. If it is switch it to Lock Rotation. Now that side switch will lock or unlock screen rotation.
See if that might stop your volume icon from popping up. Good luck!
Apr 30, 2014 | Apple iPad 64 GB 3G Tablet PC
I have a utilitech 0192773 self adjusting timer that will not program. Only works with manual on / off switch. How do you adjust to dusk to dawn
Do not go to Utilitech.com; it's a different company. It's actually at place called TheNCC and is in tiny, tiny print at the bottom of the instructions.
Instead, go to:
http://thencc.com/ncc/support_results.asp?criteria=192773&Submit=Go&SearchRun=RunGo
You should find a PDF for the product and then zoom in to be able to read the instructions. I was not able to read instructions that came in packaging.
Jan 27, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Main control screen keeps popping up on my windows xp computer while im on other sites..please help!!!!!!!!
Is this your monitor menu screen that keep on poping up. the monitor or the screen is not set properly. unlpug the monitor wait 10 seconds and replug back in. if you have video driver install it. 95% this will solve your problem. If you have samsung lcd flat screen press auto button.
Jul 27, 2009 | Dell Optiplex GX270
Error keeps popping up
PROBLEM
CAUSE
SOLUTION
3 beeps sound and E:rr flashes on LCD display (31)
prog (24) was pressed before clock time was set
auto (23) was pressed while no program was stored
TSB was pressed (25) before brew cycle was complete
Set clock time, then set the program
Set the program first.
Wait until brew cycle is complete and 2 beeps sound
Mar 05, 2009 | GE 106591 Coffee Maker
Black box keeps poping up in the middle of the tv
your closed captions are turned on and in the text mode. turn them off or select cc1 to view that captions
Jan 06, 2009 | Insignia IS-LCDTV32 32 in. Television
Adjustment pop up's in middle of screen
You should have a p0rogram installed that can do it. It might be listed under samsung in your programs. If not there, look in your video settings.
May 18, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
"Processing Auto Configuration" keeps showing up on my screen.
It solved by fixing 1024X786 pixel solution.if it not possible by fixing it..
Then look over the VGA driver is correctly support or not
if not then you have to update the VGA (Display) by drivers
By
Murugeshkumar.k
Dec 24, 2007 | Gateway FPD1530 15" Flat Panel LCD Monitor
Intitial set-up process and auto program
get a samsoung they are the best money can buy
Nov 08, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony FD Trinitron WEGA KD-27FS170 TV Logo
87 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
