Brother MFC-7820N Drum Reset
Hello, how do I reset this machine to accept a non-oem drum? Someone was saying something about turning the gears but I wish someone could be more clear about this process? Thanks in advance. -Ian
  • Anonymous Mar 06, 2009
    dust on the drum, clean cord
  • 14 Answers
There is no clear buttom as mention abovee.
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
Posted on Oct 02, 2009
  • 318 Answers
Drum reset-Open front cover of the machine,hold down clear button,when it ask you if you replaced the drum you select yes.Then it will reconise the new drum.
Please rate me!
Posted on Nov 04, 2008
How to Reset the page drum count on Brother MFC-8860DN
Open door
remove drum and toner unit
remove toner from drum push on blue tab on side to release
reinsert new toner in drum
reinsert unit in machine
leave door open
hit clear/back on panel --- says new drum-- hit yes
says accepted
close door
Dec 11, 2012 | Brother MFC-8860DN Printer
Brother MFC-9440CN Laser Printer is saying toner life end and I just put a new cartridge in.
If you want to reset your Brother MFC 9440N machine so you no longer have the error message: Toner End of Life, do the following:
1. Open the front cover of the 7820N, that is, the cover that allows you to pull out the toner and drum, but don't pull out the drum/toner.
2. Push the button: Options (located on the left of the control pad).
3. Type: *00 on the keypad.
The Brother MFC 9440N should be reset and the Toner End of Life message should disappear. Warning, this may void your warranty and ultimately damage your machine if you are reusing or refilling your cartridges, but you should already know that. Hope this helps.
Nov 11, 2010 | Brother MFC-9440CN Laser Printer
We've tried 2 new toners in the Brother 7820n and still get the same error...Change Drum Soon. We've turned it off, slid the blue arrow to clean the drum wires, etc....it still won't work...please advise....
Open front cover where drum/toner goes in
Press "Options" key on control panel
LCD will display "Replace Drum 1. Yes 2. No"
Press 1 to reset drum
Close front cover
Nov 09, 2010 | Brother MFC-7820N All-In-One Laser Printer
Brother MFC 7820N Toner life end with new toner
I found the following post on another site. It appears to work. If you want to reset your Brother MFC 7820N machine so you no longer have the error message: Toner End of Life, do the following:
The Brother MFC 7820N should be reset and the Toner End of Life message should disappear. WARNING: This may void your warranty and ultimately damage your machine if you are reusing or refilling your cartridges, but you should already know that. Hope this helps.
Sep 07, 2010 | Brother MFC-7820N Printer
Replace drum and reset
try this
Oct 06, 2009 | Brother MFC-7820N Printer
How do i reset the drum
To reset the drum, please try opening front cover of the machine,hold down clear button,when it ask you if you replaced the drum you select yes.Then you're done!
Regards,
Jeep Brainy
Sep 17, 2009 | Brother MFC-7820N Printer
Replaced Drum still says "Replace Drum Soon". How do I reset on a Brother 7420?
Reinstall the new drum unit, keeping the front cover open. Press OPTIONS. Press 1 when the display shows REPLACE DRUM? 1.YES 2.NO ACCEPTED. Close the front cover.
May 28, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother 7820N, printing image repeats?
have you tried changing the drum unit for a brother oem unoit and oem toner? generic toner and drum will always mess the machine up!!!!!!! good luck brother sr tech
Dec 22, 2008 | Brother MFC-7820N Printer
"Change Drum Soon" Message; not change when we changed the drum.
Description:
This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
Aug 07, 2008 | Brother MFC-7820N Laser Printer
10,946 people viewed this question
jasbo
jasbo
