Question about Sony Cyber-shot DSC-W80 Digital Camera
Grainy pictures at night
When I take pictures at night outside, or inside with low light, my pictures look grainy. Do you know what causes this?
Thanks,
Debbie
  • 489 Answers
Hi
Low light without a flash will always cause grainy pictures unless you have a very high end camera that can shoot at very high ISO speeds like 6400 and up.
Try changing the camera from the green camera 'auto' setting to "P" and then press the Menu button (I think it's Menu) and look for the different mode settings. There should be one for Night or Night Portrait or similar, I can't recall Sony terms and I don't have one here to check sorry.
Your other option is to use the flash, try it with Red Eye turned on if possible.
Hope this helps.
Thomas D.
Owner, Darntoothysam com
Posted on Nov 11, 2008
Why are most of my photos grainy? I have read all about my settings but I can't find what I am doing wrong please help
Graininess can be caused by a high ISO setting while taking pictures in low light situations. You could also have the picture quality set to a low megapixel setting.
Sep 16, 2011 | Canon PowerShot S5 IS Digital Camera
Grainy photos. Blur in low light. I have tried all the settings and nothing is helping.
Grainy photos is due to high ISO that is needed to capture photos in low light. The solution to that problem is to use flash.
Blur in low light would be due to a long shutter speed in an attempt to capture enough light to get a properly exposed photo. Again, the solution here is to use flash.
Auto mode with flash on is just fine in this situation-- you could also try night mode if you wish.
Mar 11, 2011 | Nikon COOLPIX S230 Digital Camera
Grainy pictures
If you are taking pictures in low-lighting conditions without flash, then the pictures will appear grainy. Set the ISO to a lower number (try ISO-100 to start with) and use the flash to compensate for low-light conditions.
This should improve the grainy appearance of your photos.
Dec 29, 2010 | Nikon D100 Digital Camera
Polaroid i1035: Bad quality pictures, appear grainy and fuzzy
The grainy effect has to do do with the ISO setting, try adjusting that. A higher ISO is generally better for darker conditions. I have noticed that this camera frequently takes grainy images.
Jan 29, 2009 | Polaroid i1035 Digital Camera
Grainy, image
You might have changed the settings; ISO setting too high or something else, just reset it to factory settings if you can't figure out ISO.
Aug 21, 2008 | Ricoh Caplio GX Digital Camera
LP600 - Grainy picture, very poor quality
Single chip DLP projectors use a spinning color wheel between the lamp and the DMD (mirror chip) to produce colors. If the wheel rotation/synchronization is disturbed, colors will not be displayed correctly.
In my case it looks like the wheel became un-synchronized, probably because the projector was dusty/dirty inside (a light senor is used to detect the wheel position), resulting in a grainy, slightly flickering image.
I simply blew out the components with a can of 'Dust-off' and, using a small tool, rotated the color wheel by hand to make sue it wasn't rubbing or jammed.
I reassembled & started the projector and the image was back to normal.
Jul 19, 2008 | InFocus LP 600 Multimedia Projector
Very grainy pictures indoors at night
If you can adjust the ISO sensitivity to a lower number then the graininess will be reduced.
However, by reducing the ISO, you will need a slower shutter speed and a larger aperture. A tripod, table or other support may be necessary.
The "noise reduction" setting on the camera can also be adjusted a step up.
Taking pictures at full resolution and fine compression will also help.
Overall, at least try lowering the ISO, and using the flash brighter.
Jul 01, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Grainy pictures
grainy pictures are possibly casued by a very high ISO (sensativity) setting, you should be on 100 or lower for best normal shots. Higher settings are for low light and custom shooting in strange lighting or aperature/shutter speeds. Try full auto setting.
Mar 03, 2008 | Canon PowerShot S3 IS Digital Camera
KV-XJ29M50 29" TV-Loud thumping sound on startup
Symptoms are not related,what you hear is the high voltage turning on and that is normal if it only does it for less than a second,the grainy picture might be intermitant,dont turn it off,when the picture is grainy tap the side of the set to see if it racts and if it does you know you have a loose conection.This could be outside because of a loose ground on tha cable or inside in the tuner.
Sep 22, 2006 | Sony KV-XJ29M50 29" TV
Sony Cyber-shot  DSC-W80 Digital Camera Logo
221 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
