Question about Sharp Office Equipment & Supplies
Sharp fo-4470 high voltage error - Sharp Office Equipment & Supplies
3 Suggested Answers
SOURCE: Sharp FO-4470: Error message is: "check cover or drum"
I'm assuming you already replaced the drum, and are still getting this error? Sometimes the chip in the drum that resets the counter is bad. This is esp. true if you get a reman drum. You should replace the drum and try again to see if this fixes the problem. Go back to the place you bought the new drum from and tell them the chip didn't reset the counter and if it's still under warranty they should replace it.
Posted on Jun 17, 2010
  • 628 Answers
SOURCE: Our office uses a Sharp FO-4470 fax machine. this
It probably means that the high voltage driver board is blown. You'll have to take it to a service center for repair.
Posted on Feb 18, 2011
Sharp FO-2081 clear memory error
I service Sharps for a living.
Enter simulation mode using # * c * after you are in run test command 66-10 This problem happens from you getting a bad fax mostly from noise or interference to the line. if it happens a lot to you then try getting a power filter with network and fax ports.
Jan 17, 2013 | Sharp FO-2081 Copier
Our office uses a Sharp FO-4470 fax machine. this morning it is flashing an error on the display of High Voltage Error. Can anyone help with this?
Feb 18, 2011 | Sharp FO-4400 Fax
Apr 23, 2010 | Sharp AR-F152 Fax
Sharp FO-3150 polygon error
You have a bad laser unit that can't be replaced.
Jan 16, 2010 | Sharp FO 2950M Plain Paper Laser Fax
I Have a Sharp FO-4450, there is an error reading as follow's "High Voltage Reading", can you help?
Most likely you will need a high voltage power board. Or a drum or toner contact was damaged. Call a sharp dealership.
Nov 16, 2009 | Sharp FO 4450 Laser Fax
Sharp ar M451N F2 02
1.Improper cartridge(destination error,life cycle error)
2.Identification error
3.model error
4.type error
5.destination error
6.data abnormality
7misc error
Jul 14, 2009 | Sharp FO 4970 Fax
Sharp fo 4700 display error ( polygon )
You have a bad printhead unit(laser unit) . The polygon mirror is not rotating within a specific amount of time. I recommend you to replace your fax unless your willing to spend between 200 to 500 dollars.
May 03, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Sharp FO-4650 fax machine
You have a bad printhead unit(laser unit) only if the problem persist. The polygon mirror is not rotating within a specific amount of time.
Feb 10, 2009 | Sharp FO 4450 Laser Fax
Sharp FO5700
I have never seen this error code on a sharp FO 5700 are you sure that is the right model # or error code. I even did a search in the FO5700 service manual(no luck). I believe I have seen this code before on a sharp copier.
Sep 05, 2008 | Sharp FO 5700 Plain Paper Laser Fax
194 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
