Question about HP Pavilion dv6000z Notebook
Laptop wirless connection
I cant not connect to my router I was chatting with masterx
  • rdgb17 Nov 03, 2008
    I have tried all the basics and need some advance help and no I do not need to spend any more money when I did not even get help in the first plan. if I choose another plan I should get a refund first.
  • 51 Answers
On the bottom right corner, click on the network icon and then chose the "connect to a network". then choose the wireless network you want to connect to. If it still does not connect, then switch off the router and plug it back again. If it stil does not work, then check if the wireless button or switch in the laptop is switched on or off. Sometimes this button switches off unknowingly.
Thanks.
Posted on Nov 03, 2008
I cant access wirless connection to my computer,there is wire conn ,but not wirless
Some later model wireless routers have the Password(ie.Encryption key) and the SSID already configured in the wireless router andthis information is printed on a label on the bottom of the router.
These settings can be used to configure the wireless card and wireless adaptersin your computer/laptop.
If these settings do not suit you, then it can be changed to suit yourrequirements.
The encryption key secures your data and wireless connection from unauthorizedaccess.To configure the wireless settings in the router, connect a LAN cablefrom your computer to the wireless router, then open a Browser on your computerand enter the router's configuration IP address, then enter the admin login andpassword and then go to the wireless settings and configure the SSID andEncryption key.
The router's encryption key can be a Passphrase or the WEP or WPA or WPA2key.If you use the Passphrase method select either WEP or WPA or WPA2 togenerate the encryption key. You can enter the WEP or WPA or WPA2 key with 8 to63 ASCII characters or 64 Hex digits.
Most people use Passphrase which is easier to remember eg. I was born inJanuary 1988.
The strongest and latest security is WPA2, the weakest and oldest is WEP. Toconnect to your wireless router from the computer/laptop, configure thewireless card in your computer/laptop with the router's wireless settings ieSSID, plus the WPA or WPA2 encryption key. Then computer/laptops cancommunicate with your wireless router.http://www.fixya.com/support/r10267861-network_security_key
Feb 28, 2012 | NetGear DG834G Router
Sylvania 7 inch netbook isnt picking up my wifi connection.. i called the sylvania tech guy and he couldnt help me.. router is working fine but netbook cant pick up the router what do i need to do
1.Go to the run option, type in services.msc
2. Click on wireless zero configuration, click stop and start..if its on start, just on start.
3. Check your network and internet connect, or network connection in the control. see can you find the wirless network.
4. Make sure you have the ssid displaying in your router.
Jun 07, 2011 | Computers & Internet
I cant use my wifi i didnt connect..there are memo's that telling me i should update my wifi to a new version..how can i do that?tnx and more power
Plug the laptop in to the router using the eithernet cable that came with the router, get all the updates then you should be able to connect wirlessly.
May 23, 2011 | Computers & Internet
I have a Westell 327w My companies laptop connects fine but my daughters laptop will not. Her computer can connect to other wireless just not ours. Any help greatly appreciated
hi
may your wirless is prodected by password
just folow the setp
click on wirless icon on screen try to connect it will ask you password
if you don't know the pass then
in explorer type your IP e.c. http://192.168.1.1
then it will ask router password just apply then you will able to see your wireless password from the router setting
May 30, 2010 | Westell Wirespeed VersaLink...
Phone co installed COMTREND wireloess ADSL2+Router
I cant solve your trouble based on what you are telling me ... but I would make the phone company fix it if I were you. If they cant accomodate the paying customer, there is always the cable company as an alternative.
Nov 14, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Can't get my wireless router to work
FIRST OF ALL YOU CAN ATTACH ROUTER TO ANY PC WITH LAN CABLE
AND CHECK IT IS WORKING OR NOT
IF IT IS WORKING THEN
REMOVE THE LAN CABLE
IF YOUR WINDOW IS XP THEN GO TO START SETTING CONTROL PANEL AND NETWORK CONNECTINON AND CHECK THE WIRLESS CONNECTION AND FOUND THE WIRLESS NETWORK
THEN WIRLESS NETWORK FOUND
AND CLICK THE CONNECT
IT IS WORKING
Aug 26, 2009 | Toshiba Computers & Internet
When I secure my wirless network xbox live wont connect
If your xbox is also connecting wirelessly, you have to input also the wireless security key on your xbox to be able to connect.
Jun 29, 2009 | NetGear RangeMax WPN824 Wireless Router...
Cant connect to linksys
try goin in to the settings for the router it self. ip addres 192.168.0.1 make sure you got the right security key.
Jun 28, 2009 | Linksys Wireless-G WRT54G Router
Tiscali wirless connection issue
Sounds like the router may need a firmware update as the DHCP service is failing to run correctly.
You can however just use a static ip address.
First of all find out the network address in use.
eg. 192.168.0.1 - 192.168.1.1 - 192.168.2.1
to find out, - start menu - run - cmd - ok - ipconfig
1. Log on to the client computer as Administrator or as Owner. 2. Click Start, and then click Control Panel. 3. Click Network and Internet Connections. 4. Click Network Connections. 5. Right-click Wireless Network Connection, and then click Properties. 6. Click the General tab, click Internet Protocol (TCP/IP) in the This connection uses the following items list, and then click Properties. 7. In the Internet Protocol (TCP/IP) Properties dialog box, click Obtain an IP address automatically (if it is not already selected), and then click OK.
Note You can also assign a unique static IP address in the range of 192.168.0.2 to 192.168.0.254. For example, you can assign the following static IP address, subnet mask, and default gateway:
IP Address 192.168.0.2
Subnet mask 255.255.255.0
Default gateway 192.168.0.1
Jun 20, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
HP Pavilion dv6000z Notebook Logo
52 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
