Question about Honeywell SureSet HZ-339BW Ceramic Compact Heater
Similar model compact heater will not "power up" after storage
I purchased a Honeywell SureSet HZ-341BW Ceramic Compact Heater during last winter (January). I stopped using it after the beginning of the Spring. The heater was placed in storage from June until now (3 full months). The heater was attempted to turned on, but would not. The power button was pressed, but nothing happened. Is there an internal reset button in the heater that needs to be reset?
  • 2 more comments
  • Anonymous Nov 05, 2007
    My problem is exactly the same.
  • Anonymous Oct 27, 2008
    I have the same problem I just wnet to use mine today and it will not turn on!
  • Anonymous Nov 27, 2008
    An expensive heater that quit on me today 11/26/08.
    It's products like this that make me never buy Honeywell products again.
    I store this product carefully and take very good care of it.
  • bullit98 Nov 30, 2008
    I purchased (2) of these by mistake, and now neither of my Honeywell HZ-341BW heater units will turn on. I will never again purchase another Honeywell product........:-(
They is no reset internal the electronic circuit is deferctive some electronics parts need no be changed. i have fixed one and modify it to be more reliable.
Posted on May 28, 2007
Honeywell HZ-338 thermostat problem
See if there is a little brass-looking bulb on a wire (sensing bulb) inside that can be moved away from the heat. My other thought would be maybe there is supposed to be some insulation between the control unit and the heating element that was inadvertently discarded?
Nov 27, 2013 | Honeywell HZ-338 Ceramic Compact Heater
I'm searching for a Honeywell HZ365 ceramic compact heater to purchase
this one is similar...
http://www.amazon.com/Honeywell-50250-S-99-97%25-Round-Purifier/dp/B00007E7RY/ref=sr_1_fkmr0_1?ie=UTF8&qid=1354484907&sr=8-1-fkmr0&keywords=Honeywell+HZ365
Dec 02, 2012 | Honeywell HZ365 Ceramic Compact Heater
Honeywell HZ 338 is turning on by itself
I have never heard of a heater coming on if its unplugged?? I could say if its plugged in and the control is faulty, it could come on by itself? Can you tell me more?
Shastalaker7
Mar 19, 2012 | Honeywell HZ-338 Ceramic Compact Heater
How many amps is the Honeywell HWLHZ370
Your heater is a 1500 watt model. Based on a house voltage of 110 Volts AC you should have about a 13.64 amp load. You might consider it a 15 amp unit to play it safe.
Mar 30, 2011 | Honeywell HWLHZ370 Ceramic Electric...
THE HEATER RUNS FOR 2-3 MINUTES AND AUTOMATICALLY
Thermal safety is tripping, clean it out , no repairs viable for theses units,
May 23, 2010 | Honeywell HZ365 Ceramic Compact Heater
Need set of instructions
Fixya can't send instructions but you can try Googling (Honeywell)(HZ-7020)(manual) without parens.
Dec 23, 2017 | Honeywell HZ-7020 Compact Heater
Honeywell Compact Quick Heat Ceramic heater with tilt feature - HZ 325
Your prob is their is a thermostatic solinode that is trigger the unit to go off--because it thinks itself as too hot and unsafe to be on--this trigger was defective or damaged by disuse and/or fatigue------give it a shake-- better yet, when cool and unplugged-vacuum or blow out with compressed air-with out disturbing integrity of workmanship on device--if that no worky--time for new one---thermostatic element is dirty, device being of differing Mghz than outlet, if fairly new device--amperage of outlet is too small for device to work properly. If it is a 240 volt or a 120 volt device and your attempiting to use the wrong voltage outlet--STOP USING THE DEVICE
Jan 21, 2008 | Honeywell HZ-325 KAZ Ceramic Compact...
Ceramic heaters
  1. I am thinking of purchasing thhz341bl heater to keep the pipes under mobile home warm for winter. Also can the osilitating be turned off?
Dec 10, 2007 | Honeywell (HZ-341BL) Ceramic Heater
Honeywell ceramic heater hz341bl
Like most heaters, this Honeywell ceramic heater has a tip switch designed to turn the heater off if it falls over. Unfortunately, all you need to do is bump the heater and the switch can open. Sometimes the switch will stick and the heater won't come on even when it is upright—sticking during storage could easily happen, particularly if not stored upright. When the switch is stuck on my heater, when I try to tturn it on the yellow and green pilot lamps flash once but nothing happens.
The solution is to rattle it, shake it, and invert it a few times to unsitck the switch. It always works for me. Something probably best done before you get frustrated to the point of shoving it through the floor. Also, if the heater was running when the switch sticks, be sure it cools down so the thermal switch has a chance to come back on.
Nov 23, 2007 | Honeywell (HZ-341BL) Ceramic Heater
Portable honeywell wont turn on
the thermostat is a variable rotation type. turning it in one direction varies a gap on a set of contacts mounted on the inside of the front panel. take the heater apart by taking out the four screws in back. the front panel should come off and you'll see the thermostat contacts. rotate the knob and see what the contacts do. if they make up, your element might be shot.
Nov 04, 2007 | Honeywell Electronic Ceramic Heater
Honeywell SureSet HZ-339BW Ceramic Compact Heater Logo
466 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
