Question about Zanussi ZHQ575 Electric Double Oven
Llike to clean the grill of the oven without any chemicals
How to clean oven grill without chemical
  • Anonymous Nov 27, 2008
    just put baking soda add a bit of water and scrub, mot of it should come off
  • Anonymous Mar 21, 2014
    the glass on the inside needs a clean but I cannot get to it
I have an Zanussi oven with grill. The model is zbf360x and I would like to know the best and most effective way to clean it.
Posted on Nov 26, 2008
Can I use the Whirlplpool oven cleaning feature to remove blobs of black burnt on blueberries from the bottom of my oven? They do not respond to scraping, vinegar, water, baking soda, hot water
Hi Dixie, you can most definitely run the cleaning cycle. Make sure you remove any cleaner that may have been used to remove the blueberries. We do not advise to use any chemicals on the inside of the Oven.
Apr 11, 2017 | Whirlpool Ovens
Tip
Save time and money on Cooker Cleaning
After cleaning your oven - do you want to ever do that again ?
Well, to cut oven cleaning down to a few minutes, just mix Sodium Bicarbonate (Bicarb) with a little water to make a thick paste, then spread it evenly on the base of the oven just using rubber gloves - it doesn't need to be too precise.
Put the oven on warm for a few minutes just to dry it out.
That's it !
Leaving it on the base of the oven prevents any dribbles or spills from sticking, and it doesn't leave any odours or harsh chemicals in there.
Next time you clean the oven - just use warm water and you will be amazed how it just lifts off - leaving your oven clean with no other chemicals needed.
Add another batch when you're done and it will continue to lift any areas you thought were impossible to get off.
on Feb 20, 2010 | Ovens
If I used chemical cleaner and rinsed it out well - can I chance on self cleaning
I use easyoff oven cleaner all the time on our self cleaning oven , never had a problem.as I do not like self cleaning systems as they waste lots of electric . getting as hot as they do .
Aug 01, 2016 | Ovens
Oven ( with combined grill) is very smokey and smelly
Your oven is one of the most-used appliances in your home, and when you use it for preparing strong-smelling meals, like fish or for curing jerky for instance (I speak from experience on the latter), you can be left with an oven that emits bad smells into the rest of your food for weeks on end. You have a spill in the oven. Wait until the burners are cool to clean them only with warm soapy water (no chemicals) and clean inside the oven. Like a self cleaning oven, it's only at high degrees it will "burn" off the food spills and will cause smoke. Shop Appliances and Furniture for your home from Appliances connection online store.
Jan 07, 2014 | Hotpoint Ovens
The is food stuck on the grill element
clean it after cold the element,carefully by using any steel or scotch brite,or buy an spray liquid for dirty removal and clean it again to remove chemical.
Dec 24, 2010 | Ovens
I just used the self cleaning option for the first time and the entire house filled with hazy smoke and a very strong , almost chemical odor - what is wrong?
The self cleaning setting goes to a very high temperature ,it is this high temperature that cleans the oven ,the remains that was left in the oven.during the cleaning cycle would have likely caused the hazy smoke and strong odour . Recomendation : use your vent fan , remove heavy residue from the oven before starting the cleaning cycle.
Dec 03, 2010 | Frigidaire Ovens
What type of oven cleaner can be used on the ge profile self cleaning ovens.
No chemical cleaners should be used on self cleaning ovens. Scrape the heavy soil with a plastic spatula and use the self clean feature. Once chemicals are used it will not clean satisfactorily again. Sorry..... Eric
Aug 17, 2010 | GE Ovens
SMEG A21X-5 Freestanding Cooker: Main oven has smoke/fumes everytime its used!
usual cause of fumes is if the grill is in the oven, when for example a roast is done, fat spits onto the grill element and the circular element and smokes. if you leave it on, the smoke will clear. some ovens have a fat guard which clips over the grill in the centre of the back panel to prevent this.
to clean glass, just use scouring pads - glass is virtually impossible to scratch
Oct 01, 2008 | Smeg Ovens
Excess amounts of Smoke coming out when in use
Locate where the smoke is coming from first. Run a dry test with just the stove. Many times excess smoke can be either oven cleaning chemicals burning off, or debris on the elements.
Jul 11, 2008 | Whirlpool AKZ159IX Oven
Red won't come off
Oven cleaners contain chemical solvents that will damage painted surfaces. The only solution to your dilemma is to replace the handle.
Jun 08, 2008 | GE JKP15 Electric Single Oven
Zanussi ZHQ575 Electric Double Oven Logo
191 people viewed this question
Top Zanussi Ovens Experts
ashburton
Charles T Nevin
Charles T Nevin
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
