HDMI port not working. No picture or sound on my HD TV
SOURCE: unable to play back sound on my tv when connected
Follow the procedure below to resolve the issue:
Step 1:
1. Click the Start button and then click Control Panel.
2. In the Control Panel window, click Hardware and Sound.
3. In the Hardware and Sound window, click Sound.
4. In the Sound Properties window, on the Playback tab, click to select HDMI and then click the Properties button.
5. In the HDMI Properties window, click on the Advanced tab.
6. On the Advanced tab, in the Default Format
section, click the down-arrow next to the text-box and then click to
select a sample rate and bit depth supported by the external HMDI audio
device.
Step 2 :
Try installing the Updated version of the Video Driver.
Good Luck!!!!!!!!!!!!!!
SOURCE: HDMI into sony bravia
plug in hdmi cable turn ps3 off then on wait and a message will apera click yes then another message appers then click yes then it should work if not connect with the red white yellow plug and then change the settings to hdmi and plug the hdmi cable in
SOURCE: Sony Bravia KDL52XBR5 picture blanks out using HDMI port
I think this has to do with the cable box not liking the encryption thing going on with the sony tv. The cable boxes probably don't understand it fully and therefore you have intermittant problems. I would just use component inputs. Which are analog and no encryption problems. I hope this was helpful. I bet it doesn't happen using a sony DVD Player or a blue ray DVD Player either. Sony, Sony, Sony.....Good stuff...but they have their moments. Let me know if u come up with a fix for this and then i will post it on my fix it list.. Thank you again..GURU JAY
SOURCE: sound not loud Sony DAV-IS10
I think its the fact that the speakers are pretty tiny, even tho BOSE has proved that size doesnt matter. i will agree i have a descent size home and i have to max it out all the time to watch a movie
just a design flaw IMHO.
If you need further help, reach me via phone at https://www.6ya.com/expert/abdouramane_7b3aaa187339b631
SOURCE: Sony KDF-46E2000 hd picture problems
MY Sony (same model) has OUTstanding picture resolution and quality., I never have blockiness on any of the sports channels. I would say, give Comcast a call and complain about their signal.. they have a tech come over for free diagnostics on your wiring..
