My canon BJC-4300 will not print. It feeds the paper through and sounds like it is printing but there aren't any marks on the paper when it finishes. I have just replaced the ink
SOURCE: canon bjc-80 - no print appears but cartridge & paper move normally
I had this problem too. It turned out there was old dry ink in there clogging up the printerhead and it was fixed after I ran the cleaning programme several times. However I can't for the lifeof me remember how to do that now. I know I found it online but it has since vanished. Maybe check your manual?
Posted on Jan 05, 2007
  • 1113 Answers
SOURCE: Error light & 7 beeps
geez, going back in time,but it is a print position fault, head is not traveling correctly , make sure rail is lubed and carriage can move back and forth without obstruction,
Posted on Oct 26, 2007
  • 3587 Answers
SOURCE: Canon BJC 3010 Ink Jet Printer Problem
does it do a test print job?
Posted on Mar 30, 2008
SOURCE: Canon BJC-2110 Printer
Try cleaning the nozzle using the software that came with the printer, if it's been a while since you have printed, try cleaning the head with a cotton swab and some isopropyl alcohol.
Posted on Aug 25, 2008
  • 56 Answers
SOURCE: Canon MP190 not printing using only black ink, color ink finished
hai try press the reset and colour button in the same time...the printer will back to normallyl
Posted on Mar 01, 2010
Canon bjc-4300 error message no paper
You will need to clear the "print queue" of those failed print attempts.
goto START--->Control Panel--->Printers and Faxes
at the top, click on View, in the second section, choose -Tiles-.
Locate your printer's Icon, and see if the number below the pic is greater than 0. If it IS, then double-click it, a new window will open.
Click on the -Printer- drop-down list, choose "Cancel all Documents" (this can take up to a min.) If the docs do not clear after a min, then do it again. Once they're all gone close that window.
Sometimes the plastic "guides" in a paper-tray, (which report the paper type to the printer,) become slightly out of place and report the absence of paper, though it really means -paper of the correct type-; because it thinks the wrong-sized paper is loaded. This can happen when a good-sized chunk of paper is dropped into that space and the paper pushes on the -guides-.
Move the length, (if any,) and width paper guides away, then back to their proper positions and see if that helps.
Sep 17, 2012 | Canon BJC 4300 InkJet Printer
Canon Bubble Jet printer won't feed paper and print properly.
Hello sir; You need to clean up paper pick up roller and feed roller with alcohol, if still have problem then replace it.
Nov 07, 2009 | Canon BJC-85 InkJet Printer
Can I use only a black BJ cartridge on a Canon 620 printer?
Nope. You can use Cyan, Magenta and Yellow as well as Black.
Specifications (BJC 620):
  • Form Factor: Desktop
  • Connectivity Technology: Cable
  • Language Simulation: EPSON LQ • IBM Proprinter X24E
  • Media Type: Coated Paper • Envelopes • Glossy Paper • Labels • Photo Paper • Plain Paper • Transparencies
  • Max Media Size: A4 (210 x 297 mm) • Legal (216 x 356 mm, 8.5 x 14")
  • Total Media Capacity: 100 Sheets
  • Media Path Type: Straight
  • Operating System: Microsoft Windows 3.x
  • Product ID: 20152942
  • Exterior Color: White Product Description for Canon BJC 620 (From the Manufacturer, Canon)
    Simply a piece of printing marvel, with high definition printing, superior ink technology, innovative waste-free ink system and user-friendly Windows printing system. The BJC-620, simply a must buy for those who seriously considers printing in superior, high quality color. It comes with an Internet kit.
    This printer model is not being manufactured by Canon any more
    Related links for Canon BJC 620:
    Canon BJC 620 printer ink cartridges at's site
    Canon printer ink cartridges
    Canon BJC 620 Driver
  • Apr 18, 2009 | Canon BJC 6200 / CanoScan N650U InkJet...
    I have a canon bjc 80 connected via usb to acer laptop with vista on says hardware successfully installed & sounds like it is printing but will not feed paper or print !! have not used a disc to install...
    Purchase a PCMCIA parallel port adapter. the USB to parallel adapters are a pain to set up and are flakey at best. The PC card adapter provides a native parallel port to laptops without one, and works perfectly in ALL cases, even with the scanner cartridge.
    Feb 19, 2009 | Canon BJC 80 InkJet Printer
    Canon bjc-4300 cartridge insists on staying in middleofprintfield
    Normal 0 Driver could be corrupt.
    Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
    Hope this helps. Bud
    Jan 06, 2009 | Canon BJC 4300 InkJet Printer
    Not printing from one computer
    If the CHARGE/ERROR light is remain on orange with beep 1 times, it mean the paper is not properly set in the feed slot, just remove the paper and reload it properly.
    If the POWER light is flashing green, that mean your print job is not finish yet.
    YBC (/\)
    Dec 15, 2008 | Canon BJC 55 InkJet Printer
    Aug 25, 2008 | Canon BJC 2100 InkJet Printer
    Paper feed fault
    Check the printer lens and make sure the paper is probely inserted. Hope this helps...
    Jan 28, 2008 | Canon BJC 3000 InkJet Printer
    Oct 26, 2007 | Canon BJC 80 InkJet Printer
    i assume the cleaning method that you perform is offline (taking the cartridge our and clean them). I suggest you clean the head during the printer on.. try to perform below steps per the manual Cleaning the printer Printing the test pages Cleaning the print head I assume you do not have the manual anymore (no DVD) i list down the step below Its a bit long manual I suggest you download them from the canon website.. if you still have problem I can send to you the BJC 4300 manual Cleanning printer Make sure the printer is turned off before cleaning it. It is a good idea to unplug the AC adapter also. Do not clean the exterior of the printer with volatile liquids such as thinners, benzine, or any spray-type or chemical cleaners; doing so will damage the surface of the printer. When cleaning the printer, avoid the area near the print head on the BJ cartridge. Do not touch the print head. Ink may leak out and cause stains. Clean the printer regularly to avoid printing problems. Remove any ink mist or paper debris from the interior of the printer using a soft cloth moistened with water. Clean especially well around the platen area. If the rollers become dirty, you can clean them using a small soft brush. Clean the exterior of the printer with a soft cloth moistened with water. Clean away smudges and dust. Do not use paper products (such as paper towels or tissues) to clean the inside of the printer. Printing the Test Pages You can print these test pages to check the operation of your printer and your print quality. Test A This test prints a repeating pattern of characters. Demonstration This test prints a sample page describing the printer's features. Printing the Test Page From Windows You use the Test option on the Control tab in your BJC-4300 Printer Driver for Windows to print a self test, demonstration page, or a nozzle test pattern. Before selecting a Test option, make sure paper is properly loaded in the sheet feeder (see Automatically Feeding Paper starting on page 3-7). Click on the Test option and then click on the Print button. Printing the Test Pages Using the Operators Panel To print a test page, make sure the printer is turned off and paper is loaded. Press and hold the POWER button until you hear the number of beeps that correspond to the test page you want to print. Test Page Number of Beeps Pages Printed Demonstration 1 Continuous Printing Status Information 2 1 Page Test A 3 Continuous Printing Nozzle Test 4 1 Page When you release the POWER button, the test page starts to print. *All self-test prints require Letter or A4 size paper. Using a smallersize paper for a self-test print will result in parts of the printoutbeing printed directly on the platen. All self-test prints are printed in accordance with the current printing settings (font, printing mode, etc.) *Red- Information for technician not included in the user manual Cleaning the Print Head Your printer is equipped with a print head cleaning function to ensure constant high quality printing. Cleaning the Print Head From Windows If you are using Windows, you can execute print head cleaning from the Control sheet in the printer driver. Simply click on Clean Ink Head. 4300 Chapter 4 Page 6 Cleaning the Print Head Using the Operators Panel If you want to clean the print head from the operator panel, follow these steps: 1 Make sure the printer is turned on. Make sure the green POWER light is on. 2 Press and hold the RESUME button for at least two seconds until the printer beeps twice. The POWER light will blink for several seconds while the print head is being cleaned. Perform the print head cleaning only when you encounter a print quality problem. Unnecessary and repetitious cleaning will waste ink. If you execute the print head cleaning while paper is manually loaded, the printer will eject the paper and then perform the cleaning. 4300 Chapter 4 Page 7
    Aug 24, 2007 | Canon BJC 4300 InkJet Printer
    46 people viewed this question
