Question about Sony Playstation 3 (PS3) Console
Ps3 all black when i turn it on
I turned the ps3 on. all lights are on the playstion..everything is working but nothing will come up on the tv..(just an all black screen) i pushed the eject button it (beeped) showing that it is indeed on..i wiggled the video output on the back of the ps3 still nothing..i swithed the input (red, white, yellow) to another input on the tv..still nothing...so i unpluged it for 5 min or soo.. pluged it back in still nothing (black)..i pulled the hard-drive out for a few minutes put it back in still nothing (black)? the only thing to show me that it is on are the lights and the beep nothing else? not exactly sure what it may be? any ideas!?
thanks
Chad
  • 1 more comment
  • zunigac76 Nov 03, 2008
    Same thing with mine, using the HDMI cable
  • Anonymous Nov 05, 2008
    same thing screen all black
  • Daniel Bates Nov 06, 2008
    my display was garbled before the video went out, then would not come on. Tried resetting holding down the button through an entire cycle. Changed environment. Changed video connection type (resetting each time). Removed the CMOS battery and put back in to reset system.
    Problem Solver:
  • 10 Answers
Ok a long shot but i did read somewere that if u hold down the power button for 10 seconds it detects or calibrates to the current TV that is connected its worth a try if nothing else, if this didnt help sorry but if it did enjoy :)
P.S. i dont know if the console needs to already be running to do this.
Posted on Nov 03, 2008
Remove your hdd and put into another ps3.The screen will say format...you say yes.Then you put the hdd back into your ps3 and it will format again.hopefully that works for you.I have the same problem and am about to attempt this now.
Posted on Nov 05, 2008
Ok so my playstion 3 will turn on but it won't display anything including audio, i tried to solution of holding down the front power button until you get the double beep but still nothing it's just a blank...
PS3 forzen when playing games and remain blinking red light : You need to repair your console. Learn the step-by-step way to fix your PS3 inner parts is best way for you. I suggest a secret repair kit for you to fix the PS3 errors. This is an all-in-one style guide that help you to fix many cases of PS3 problems. The author is really kind and helpful to his customers. Learn the D.I.Y. way to fix PS3 issues can save you much money. You will receive much more than you spend on it. Because you can help your friends to fix their PS3 too! Please consider to buy it and share what you have learned !
PS3 Red Light and Yellow Light Fixing Guide : http://bit.ly/fixya-ps3
Oct 03, 2010 | Sony PlayStation® 3 (80GB) Console
Why does the playstion 3 dose not work on standard tv
Have you tried holding down the power button for 5 seconds to revert back to standard definition?
Jul 23, 2010 | Sony Playstation 3 (PS3) Console
Hi I have playstion 3 slim and when i turn it on it powers up but there is no picture and it sounds like the machine is not working like normal like
Have you set the video mode on the machine or plugged it up to a different TV? if so try this >>>
Make sure all leads are connected to the TV.
Next, turn the PS3 off so the red light is on. Hold down the power button on the PS3 until you hear a beep. Release the power button and press it again.
That should have reset the video settings so you will be able to set the video settings again and access the PS3 menu.
Post back if you get no luck.
Regards.
Jun 22, 2010 | Sony Playstation 3 (PS3) Console
PS3 can turn on, but T.V screen is black
turn power switch on in the back. red light on in the front, hold the power button until system turns back off. this resets all hardware settings. if this doesn't work and the system is ok (green light) then you have a connection problem to the tv
Jul 14, 2009 | Sony Playstation 3 (PS3) Console
My PS3 turns off when turned on.
you have the red light of death on a ps3 wich means your ps3 is completely stuffed it cannot be fixed id get onto playstion support and send it back for a new one
Jul 03, 2009 | Sony Playstation 3 (PS3) Console
Can not get HDMI to work on PLAYSTION 3 on my Philips 42' Plasma
I had the same thing with my PS3 on a samsung 40". Try pressing the power button down on the PS3 for 5 secs or more, until it beeps (Not sure if it's one beep or a series of). I think this is how you reset the system and it should automatically recognise and reset the resolution size to HD on you're screen. Hope this helps,
Andy.
Jan 21, 2009 | Sony Playstation 3 (PS3) Console
When i turned on my ps3 today nothing displays on tv at all..........just a black screen
Check EVERY! cable, TV too, EVERYTHING.
Especially if it's HDMI, they come out EASILY.
Make sure TV is working properly with other things, it could be your TV.
If all cables are correct remove the game and whatnot and try different things.
Jan 10, 2009 | Sony Playstation 3 (PS3) Console
PS3 will play on AV but will not in HDMI
  1. Connect via AV and turn on the system.
  2. Go to Setting and then Display setting
  3. Select the connector type on your TV.
  4. After you selected connector your TV screen may go staid black. Try to hook your HD cable while the system is still on. (This step should be done in 30 sec. If not, will go back to previous screen)
  5. Your TV Screen should be on via HD cable
Dec 09, 2008 | Sony Playstation 3 (PS3) Console
Powers on, Controller wont connect, nothing shows up
switch the hard switch off in the back of the ps3. unplug power cord... press and hold power button located on the front f the ps3 for approx 10 secs, then let it sit for a few, then hook it back up and turn the hard switch back on and try to power it back up.
I have had this happen once before but it did return to normal.
Nov 14, 2008 | Sony Playstation 3 (PS3) Console
Playstion 3
I understand how frustrating that must be. How big is the hard-drive that came with your unit? Did you buy it brand-spanking new or used? Update to version 2.2. It came out last night. Then, once that is complete, shut down your PS3. Unplug everything from your memory card ports and usb slots. Unplug the power cable at both ends (from the wall and the ps3). Then switch the PS3 hard switch (on off, lever, not the soft method of turning it on by a mere touch). Leave it that way for 10 minutes. Plug power cable back in at the PS3 and then at the surge protector/power-strip (wall). Turn in on with the switch and then use the soft method (described above) on the front. That should fix it. If not, send it back for a warranty exchange. Good luck.
Mar 22, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
159 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
