Question about Maytag Performa PAV2200
Washing machine my maytag machine will spin only when there is water in it but if it has clothes it will not spin at all what could be the problem
  • 4 Answers
It has a vacuum sensor inside the control panel, connected to the water level selector, have it checked.
Posted on Nov 12, 2008
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Cloths still very wet after final spin cycle
Use spin ccyle again for proper operation and to help remove water.
Apr 29, 2010 | Maytag Neptune MAH5500B Front Load Washer
When i spin wash tub wigth my hand i can hear lots of water still in the machine under neath the wash basin
That is becouse most washing machines are made up of an inside drum where your clothes are washed and an outside durm that catches the water when the washer spins the water out of the washed clothes. A pump is connected to the bottom of the outside drum. If the pump fails, the water would not get pumped to the drain and would collect in the outside drum.
Aug 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag frontloader washer, seems to wash ok but won't spin water
madam some times the timer of the washer may go wrong and it wont makes the machine to spin so please check it once without loading the machine.
Aug 07, 2009 | Washing Machines
Water in clothes
Check the door switch for damage. Use a small jumper wire across the switch, if it spins the water out, you need to get a new door switch
Jun 24, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Washer spins but not enough to extract water from clothes or tub.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Dec 31, 2007 | Washing Machines
Maytag atlantis washing machine
It will not spin out all of the water out of clothes, spins VERY slow
Dec 07, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
43 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
