Question about Dryers
Creda tvr2,water in bottom tray not being pumped up to top emptying tray.
5 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: hi - i have a
The hose may be partially blocked, stopping the air from blowing through properly,check that there is no bend and that the hose is not sagging down as this causes the moisture laden air to condense inside the hose and create water build up.
The water has probably caused the thermostat or heater to fail.
To check the element and stat(s) you need to remove the rear panel of the dryer, and tyest with a meter.
Plz rate my solution.
Thanks.
Posted on Jan 04, 2009
barkencoa
  • 3463 Answers
SOURCE: the belt is broken on my creda tvr2 tumble drier
If you are in the U/K, then got www.hotpoint.co.uk, and follow the links.
Please rate my solution.
Thanks.
Posted on Nov 01, 2009
protek480
  • 1723 Answers
SOURCE: Snapped belt
Watch the video and it will give you the idea, it may be a different model but it's all about the same to replace.
Posted on Nov 06, 2009
  • 40 Answers
SOURCE: My creda tvr2 only spins one way.. does anyone
sounds like a timer fault, the reverse contacts in the timer are not making contact.
Posted on Apr 07, 2010
MY DRIER IS A CREDA TVR2 S/N 51004059. IS IT LECALL?
notify company about recalls since they might need more information such as when and where purchased
Nov 01, 2017 | Creda Washing Machines
Condenser dryer
PULL OUT THE PLUG
on the bottom right on the back is the water pump
it needs cleaning or replacing
not lifting the water to the water draw
Dec 12, 2013 | Creda IWD12 Front Load Washer / Dryer
Why does my creda washing machine stops when it gets to a rinse
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the next cycle with excess water in the drum.
You need to locate and clean the filter. Depending on the model (not familiar which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom)
Jul 05, 2011 | Washing Machines
My creda tvr2 only spins one way.. does anyone know why it won't spin in the opposite direction!!
Apr 06, 2010 | Dryers
Snapped belt
Nov 06, 2009 | Dryers
The belt is broken on my creda tvr2 tumble drier and i dont know where to get to it to replace it
Thanks.
Nov 01, 2009 | Dryers
My washer does not empty
i had the same prob when i had a new kitchen fitted. . all i did was put the pipe that goes to the sink part in the shape of a n , that will solve it.......
Jun 17, 2009 | Creda W100FW Front Load Washer
Hi - i have a creda TVR2 Dryer - the pipe although placed through a window was full of water and now the dryer will not heat
Thanks.
Jan 04, 2009 | Dryers
Washing machine creda front loader
I had the same Problem on a 17112e Creda, I took the top off and using a torch located the red plastic door release mechanism, I then pressed a white button in the centre of it and the door released. I believe that the washing machine was overloaded and auto cut out. I reloaded the machine with fewer items and it is now working.
Mar 20, 2006 | Creda W100FW Front Load Washer
Dryers Logo
20 people viewed this question
Top Dryers Experts
