You must purchase a digital to analog converter to receive over the air broadcasts now, that has been so for about 2 years. Your TV can't receive digital broadcasts directly.
YOU DO NOT NEED ANY TOOLS, SIMPLY SETUP INTERNET TETHERING FOR YOUR MOBILE AND CONNECT A USB CABLE TO THE COMPUTER THEN SHARE YOUR INTERNET CONNECTION.
The dock connector is not connected properly or maybe the ribbon cable was damaged. The guide to re-assemble it properly is here: http://portatronics.com/guide/
1. Make sure that the theme that you have downloaded is compatible with Nokia 5310.
2. Yes, there's a way to connect the phone to the PC without using the PC Suite. Follow the steps below:
* On your phone, go to Menu and then go to Settings. * Go to Connectivity and then select 'USB data cable' * Then connect your phone to the computer
NOTE: The computer should recognize the phone as Mass Storage Device. You may now save any file to your phone and it will be saved directly to the memory card.
Ok, wich USB you are conectting? Cause if you are connectting in the front, it don´t have enought current to recharge the mp3, but wether you connect in the back USB , it will works very good. If you have a Notebook, connect in other USB until you find the correct one. I Think that i Help You, Good Luck.
1, clean the usb cable connections, both out and inside the phone
2. try to replace the usb cable to dku-2 or ca-53
3. make sure u have the latest firmware (6.43) by pressing *#0000# at the main screen.
if u don't i strongly advice to update it from nokia website.
but before u do make sure to clean the usb cable connector
