Question about Toshiba e-Studio 232 Black and White Copier
Toshiba e studio 232 screen shows
Screen shows:" join finisher to copier" what is this? this machine was moved to new office and now will not work
  • 24 Answers
Is the finisher tray atach and connector plug in? it's possible that the connector was unplugged while the machine was on and an memory error apeared! if so, unplug the copier from power source, plug in the finisher, and plug in the power corde . if it won't work you shall check also if all doors of finisher are closed and if wasn't broken one of the sensors!
Posted on Nov 03, 2008
Signal f103
You have a corrupted hdd promblem on you toshiba. You should find another hdd and the firmware and make them using usb stick
Jan 03, 2014 | Toshiba e-Studio 232 Black and White...
Toshiba e-studio 28 copier
Check that all the door are well closed and in place.
Jul 15, 2008 | Toshiba e-Studio65 Copier
E-studio-232 adding toner problem
change the developer with the new one and change the sensor toner.
May 24, 2012 | Toshiba e-Studio 232 Black and White...
Error codes and their meaning for Toshiba e-studio 181 copier
toshiba e-studio 181 is not working. It shows that cover is open symbol and tells the same and the printer is woken up. what to do to rectify it.pls
Apr 27, 2012 | Toshiba e-Studio 232 Black and White...
Thermistor fuse Toshiba e-studio 232
There are only themostat and themistor on the fuser unit.
If C440 sign on frequently, probably the themistor is deformed, which need to be replaced.
For 1st C440 sign on, try to reset it by entering 08-400, change the value appear on screen to "0", then reboot machine, if the machine is working, just leave it.
If not, C440 will sign on again, then only u replace the themistor.
To replace it very simple, take out the fuser unit, reverse it, and u will see a black plastic compartment, open it up, and u will see the themistor.
Nov 14, 2011 | Toshiba e-Studio 232 Black and White...
How make printout from a toshiba e studio 232 photocopier without using a original dongle, need a permanent solution
It cannot be done without the dongle.
But u can try the trial period, once the trial period is almost reach, u can try update the machine firmware. But not sure whether it can work or not...
Oct 05, 2011 | Toshiba e-Studio 232 Black and White...
Toshiba estudio 232 screen freez?
Hi how are you this is jack..
Dear you copier screen freez..
you press 0 and 8 key Simantenesly and other and on the copier.
when copier show CHECK TOTAL COUNTER.
WHEN you press 690 and start key. copier show 2 2
then you press ENTER AND when copier show REBORT THE MACHINE THEN OFF THE COPIER.. AND Simple ON.
Please vote me.
Thanks
Best Regards,
Aug 12, 2010 | Toshiba e-Studio 232 Black and White...
Toshiba e-Studio 232 is showing error message CF60 after I resetted system after a problem How can I remove the error message CF60? Please help.
CF60 indicates Recycle Toner Transport area lock. U need to take out the process unit, remove developer unit, remove drum, drum blade & recovery blade, disposed all waste toner, make sure the gear can turn properly. Then reassembly back everything.
Jun 06, 2009 | Toshiba e-Studio 232 Black and White...
Toshiba e-studio 232 code C970
C970: HVT or charge corona.
Remove main charge and trans/sep. coratron units and check --- make sure wires are not broke, clean grid, clean canals of units.
Replace and part needed.
If coratron units are fine --- replace HVT ( high voltage transformer).
Jan 31, 2009 | Toshiba e-Studio 232 Black and White...
TOSHIBA E STUDIO 351 C
check the bottom door on the right, I beleive there are three doors on the right, if not there is a door sensor loose.
Oct 01, 2008 | Toshiba e-Studio 232 Black and White...
Toshiba e-Studio 232 Black and White Copier Logo
573 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
