I have tv panasonic model ct-36hx42fi tihng flyback is bed transistor horz out is bed and two resistor .1 is bed
    Genius:
  • 2,920 Answers
You would want to send it to a shop to make sure it gets repaired propely
Posted on Nov 03, 2008
What causes a blown fuse in tv samsung
Usually in a Cathode Ray Tube Television a blown fuse is either something is wrong in the high voltage power supply section or the flyback transformer is bad, or a bad horozontil output transistor.
Nov 18, 2013 | Panasonic CT-36G34 36" TV
I have a Panasonic CT-36hL43G TV that just turned offf while watching it and now the led by the power button blinks one time. Can anyone tell me what this code means or what the problem might be?
i hope your tv is more than 4years old ....... in all CRT TV's or CRT monitors after 4years a component called flyback transformer (see picture ) becomes weak - its work is to supply voltage to tube............. then following are the signs ...
(1) in some TV's only front LED's blinks - no picture no sound.... (2) in some TV's picture comes slowly after few seconds or after few mins or after few hours......... (3) in some TV's suddenly picture & sound goes temporarly & after some time again it appears ...... etc in case of (2) & (3) only flyback transformer needs to be replaced .....100% GUARANTEE again TV works normallyBUT in case of (1)... --------------- YOUR CASE (a) either only flyback transformer gets deffective or (b) flyback transformer & another component called transister ( will be near flyback transformer & its back portion is attached to aluminium metal ) gets defective or (c) along with flyback & transistor -- 3 or 4 more components (resistors, diodes, some times ICs ) gets deffective so replacing flyback transistor is a must .. & to find whether any other component is deffective or not completemainboard has to be checked ....... so if you are a technical person & having expierence in servicing line then you can do it yourself otherwise approach good tv service engineer ........... your TV is really very good one ... so don't think of buying new TV .... just goahead for repairing it it is worth & it works for atleast 2 more yrs....... try this & tell me what happened switch off your TV ... remove power cord from socket ,,,,.ware some mat or chapples to your feet ..... remove your TV's back side cover ......... observe carefully for any physically damaged components .... if you find then don't do anything ... close tv cover & approach tv service engineer ............. but if no physically damaged components are visible then take a suitable screew driver & rotate 2 (or 3) Knobs on flyback transformer in clockwise or anticlockwise direction - very little ( 4 or 5 degrees ) - you have to do this without touching any cable or any part of your tv .......... then fix..... back side TV cover ........connect power cord - stay at a distance & switch on your tv ......... if you get picture atleast for few seconds then in your case only flyback transformer needs to be replaced otherwise complete mainboard has to be checked. to find other deffective component ............. so your tv problem is a harware problem - it cannot be solved using remote control or any buttons on your tv ..... if you are finding difficult to get it repaired then you can remove your tv mainboard with the help of some technician & send to me ...... i will replace deffective components .... & send back to you ....you only have to bare the shipping charges .....it will take maximum 12days (5days - to recieve + 2 days servicing + 5 days to send back to you )....
Aug 16, 2011 | Panasonic CT-36HL43 36" TV
Hour glaas figure onpanasonic tv
maybe it is a defective yoke...
May 07, 2010 | Panasonic CT-32D31 32" TV
MY VSIO FLAT SCREEN TV DOES NOT POWER UP ONLY BLINKS TEN TIMES THEN GOES TO STANDBY...I'm an experienced CRT TECH but not flat screens...!
dont know what make or model it is, but sounds like it is the horz.output transistor,or stk,s or the flyback transformer.call MATS ELECTRONICS FOR PARTS AT #1-800-628-1118
Feb 15, 2010 | Televison & Video
Panasonic TV - no picture, but sound is ok
resolder flyback transformer contacts on the board, if doesn't help, replace flyback and horizontal output transistor
Oct 06, 2009 | Panasonic Televison & Video
TRYING TO FIND A REPLACEMENT FLYBACK FOR MY PANASONIC CT20G13W TV
Call union electronics at 1 800 648 6657. Have your model # and possibly a chassis # or board #. Are you sure this is the problem? A bad flyback is kind of rare but they do happen. Good Luck!
Sep 04, 2009 | Panasonic CT-20G21 TV
Keeps blowing fuse
It has a short circuit somewhere...
Not sure if this is a CRT, LCD or Plasma TV but the two common causes of shorts for CRT's are the Horizontal Output Transistor (HOT) and/or the Flyback Transformer (Could be both). As a general rule if the flyback has visible cracks in the case they should be replaced. It is also a good idea to replace the HOT if you're replacing the flyback as it could be weakened and may not last much longer itself.
Other areas to check for all types would be any Diodes in the Power Supply Circuit. If a diode is open it can cause the fuse to blow. Note that a diode itself will not short, but an open diode can cause a fuse to blow.
Mar 11, 2008 | Panasonic CT-32HL43 32" TV
Panasonic tv help
my tv screen just turned brown. sound and everything else works fine?????
Panosonic HD tv
Jan 24, 2008 | Sony KV-27S65 27" TV
Tv controls respond erraticaly
most of these rca models have bad flybacks. also check horz output transistor, if flyback is relaced the screen voltage has to be at or close to 295 volts or set will shut down after on 5 seconds
clintstv
Jan 18, 2008 | RCA 32V420T 32" TV
Televison & Video Logo
Top Televison & Video Experts
