Question about Frigidaire Ovens
How do I adjust the flame on my Frigidaire model FGS383BADK stove?
We just moved and I'm switching the stove from natural gas to propane. WHat all do I have to change? How do I adjust the flame. Right now the flame on the burners is about 4-5 inches! Please help as the manual says nothing about this. Thanks
  • Anonymous Mar 18, 2014
    converting from propane to natural gas
    President:
  • Frigidaire Master
  • 2,651 Answers
Its going to be listed in the installation manual ,not use and care, youre going to need to convert oven for lp gas. i would call the manufacture with the modelk number and ask for hte coorect conversin kit, for such a thing
Posted on Nov 04, 2008
Tip
Propane, LP, or Natural Gas Regulator Problems
There are many questions involving problems with gas regulators. Most any gas fired appliances will have a regulator somewhere in the system to regulate the gas pressure to the appliance. On natural gas the pressure regulator is often outside, but many stoves and ranges still have a pressure regulator at the inlet also.
On LP or Propane appliances there is a pressure regulator at the source but then also at the appliance. On outdoor grills the regulator is the silver round thing at the tank.
They often look like this.
The function of the pressure regulator is to keep the gas pressure even so that the flame does not vary much when the usage is increased or decreased. The regulator does this by using a small spring and diaphragm assembly. The counteracting pressures work to keep the pressure even. The regulator fails when it gets stuck. They are designed intentionally to fail in the safest mode or in a low pressure state rather then a high pressure. Therefore many problems involve not enough gas rather then too much.
On outdoor gas grills the regulator can sometimes get stuck if the tank valve is opened too rapidly. Or it will just become stiff from the outdoor environment. If the regulator is not letting enough gas through, try shutting the valve and then opening it again slowly. This will help sometimes. If that does not help and the valve is sticking, do not try to adjust the regulator. Replace it with a new one. Trying to adjust it could cause serious safety hazards. I have seen some web sites telling people to adjust the regulator by watching the flame…this can be a good way to get yourself and others hurt.
If you have a range, stove, or oven that is not working right because the flame varies as you turn burners on and off or when the oven goes on, then the regulator is at fault. Once again, do not try to adjust this to make it work, replace it and get it adjusted with the proper instruments to make sure that the gas pressure is right for the appliance.
Pressure regulators come in many shapes and sizes. They can look like any one of these here.
Gas appliances work at extremely low gas pressure. Natural gas appliances often run at 4” Water Column. Lp or Propane at around 10” WC. That means that the pressure of the gas will only raise the water in a tube 4” or 10 “. That is NOT much pressure and you can get that much by gently blowing in a tube.
So, if you are having trouble with not getting enough heat or the flame running very low, the pressure regulator should be one of the first places that you look.
on Sep 03, 2010 | Ovens
Oven flame is to high. How do I fix it?
You have selected an electric range, what is your true gas range model number?
Aug 26, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Broiler flame on hotpoint stove needs adjustment
as in height of flame? if its too large a flame and you have switched from natural gas to propane gas you must turn the orfice spud down onto the orfice face to adjust it,just land it lightly,do not turn it down overly tight
May 05, 2012 | Hotpoint Ovens
Propane stove burns yellow & creates soot
clean the orfices and tubes and then if possible adjust your air mixture setting also
Sep 21, 2009 | Frigidaire FGB24S5A Gas Single Oven
I have a gas oven. The flame burns yellow and leaves too much soot on the wall near the flame. Is there a way to clean the element thing? Dave
I am not sure. However, people in our area of sc, have had burner problems because a local utility added propane to their natural gas because they got it a bargain. guy
Jun 10, 2009 | Frigidaire FGB24S5A Gas Single Oven
Problem gas cooker
Go on line to westing house.com and look up your model, go to the help page and ask for their assistance, gas is not something to fool around with, I suspect it is the orifice that have not been converted to propane, I had a similar problenm with the stove top burners, and the orifices needed to be changed to (converted ) to run on propane gas.Some times manufactures send the converter orfices but most of the time you have to ask for them if you are running on propane, most stoves are set up for natural gas not propane.Most of the time the store clerks don't ask you if you will be running on propane , you have to tell them and the professional who installs the unit needs to install the orifices. Please be careful! If you installed the stove your self, you need to contact a professional installer to correctly adjust these .
Jan 05, 2009 | Frigidaire FGB24S5A Gas Single Oven
Oven burner flame is low
0000000.jpgOn top of that safety valve is a nut. Get a good fitting wrench. Turn on the oven and use that good fitting wrench on that nut. Turn it counterclockwise till the flame comes up about midways of the flame spreader. Don't get the flames too high. Midways of the spreader now. LOL
Jan 02, 2009 | Ovens
Gas oven that cooks unevenly
clean your orifaces.
Also make sure that it's the correct stove for your gas type. If you're using a NG stove on Propane, you're wrong. It's making a lot of soot, and could potentially blow up your house. Stop using it until you're sure.
Dec 05, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
How to check to see if gas stove has been converted to propane
The only thing you can do is look for a little (usually gold) nozzle connected to the orfice
propane burns blue and natural gas has the yellow tint to it
May 01, 2008 | Ovens
Ovens Logo
494 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
