Question about Xerox DocuColor 12 Printer
Xerox Docucolor 12 : Four colors ( CMYK) dots printed each time on paper on 3 separate area
I Have a xerox DC 12 and each time I print a color page I found 4 dots in CMYK in 3 different areas on the printed page.
Any help will be much appreciated.
Thanks !
  • starmedia Dec 04, 2008
    4 dots on separate area
  • 62 Answers
Print cartridge is past its best. If you get a new one and the same thing happens, its the developers that need changing
Posted on Nov 19, 2008
    Problem Solver:
  • 5 Answers
Your Problem is the cartridge printer Mx, In spanish algun balero de las developers units esta dañado pudiera estar golpeando el cilindro de imagen
Posted on Nov 17, 2008
Problem with color alignment on DocuColor 1632
Below is a link to the user manual, the aligment procedure should be in there. Xerox DocuColor 1632 User Manual
Jun 16, 2017 | Xerox DocuColor 1632 Laser Printer
What is the solution of black bars on paper while printing on xerox dc 12 printer
Most likely a drum cleaning blade. If the streaks are verticle, up and down the page and if they get worse as you run multiple copies. So on a 10 page copy run the last copy out will be worse than the first. Cleaner blades are cheap at around $40.00
Good Luck and Thank You for using Fixya.
Sep 10, 2010 | Xerox DocuColor 12 Color Copier
Error 3-380 dc 12 xerox
its problem of IBT belt sensors
two silver colour patchs held on ibt belt check that patches its has any dust
or damage
replace that patches
Mar 06, 2010 | Xerox DocuColor 12 Color Copier
DOTS pattern and WHITE LINE along the page
The Problem is your Copy Print Module it has a scracht on it if you replace the module it will desapear the dots and lines.
Nov 26, 2009 | Xerox DocuColor 12 Printer
XEROX Docucolor 12 Color Developer PN needed HELP
DEVELOPERS:black 5R616 ; yellow 5R 619 ;magenta 5R 618;cyan 5R617
TONER : magenta 6R1051 ; cyan 6R1050 ;yellow 6R1052
Sep 14, 2009 | Xerox DocuColor 12 Color Copier
CMYK dot problem
can be solves by changing whole drum unit because problem with bias grid (black strip on chager)
Jul 02, 2009 | Xerox DocuColor 12 Color Copier
Docucolor 12 no print color & B/W
the only thing apart from software corruption is that you could try printing a configuration sheet. If this prints then black printing is working. If it won't then print a test page then you need composite patch 1-7QU5B.ps from the xerox "drivers and downloads" site. If none of this works it is a software reload.
Jan 16, 2009 | Xerox DocuColor 12 Color Copier
CMYK spots on print
each dots comes .5mm gape in one by one at different places pls check and replace a new drum.
Jul 27, 2008 | Xerox DocuColor 12 Color Copier
Cmyk dots on the print
There are several causes of those.
So go to Xerox.com
Click "support and drives"
then in the product name box, Type DC12
Then any line click support
IN the search box type "spots" and read the relevant solution.
May 05, 2008 | Xerox DocuColor 12 Printer
Xerox DocuColor 12 Printer Logo
344 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
