Question about Sony CPD E220 17" CRT Monitor
CPD-E220 : Brighter than normal and....
I've a problem with my Sony CPD-E220.The screen is brighter than normal (setting of bright and contrast are normal and it's still too bright even I decreased both to zero). Right now it goes standby by itself in 30 sec and orange light is blinking. It've a small rainbow line on the corner (about 5 cm long). How to fix this problem? Thanks you.
  • 124 Answers
SOURCE: sony kv-32xbr400
Hi The problem is dry joints on the vertical output ic for sure(commen fault with sony),ime in the uk and 99% of the time i get a call about sony tv its allways switches itself off, caused by dry joints.
Posted on Mar 27, 2006
techman
  • 3130 Answers
SOURCE: Green Screen!!!
It could be the picture tube but it could also be the drive circuit foir the green tube, and I have fixed many a sony TV sets for this problem.. The best way to see if its the tube falure, is to take off the green crt socket and take off one of the tubes to the left or the right of the green as the green one is in the middle. If that turns green again and shuts down, then you know its the tube. If it does not turn green then you know that is in the green drive circuit. Most likly a bad driver transistor or the video jungle IC is bad. Oh and NEVER bang hit drop or slap your set to fix a problem. Thats the most stupid thing I have ever heard. The tube if its intermittant most of the time can be cleaned internally with a CRT rejuvenator. Who ever suggested driopping it is a fly by night repairer or unskilled or does not have the proper equipment to repair the set properly. you should know, anytime you have to hit or slap a set silly to make it work, most of the time there is a bad solder connection in sidfe on the printed circuit board and should be addressed or repaied asap as not to cause more damage to the set. Im still LOL about picking up the set and dropping it to fix it..LOLOLOL
Posted on Sep 21, 2006
  • 749 Answers
SOURCE: retrace line on monitor
To prevent serious damage and extend the life of your monitor you need to adjust the main brigthness control of it. it is of the LOPT/Flyback transformer inside of your monitor!
check also for cold SOLDER joints on the main pcb and also on the crt neck Board.
Posted on Nov 17, 2007
VOTIT
  • 2071 Answers
SOURCE: tv prob
This is the common symptom of defected IC memory 24COxx,replaced this IC so it will works normal again.
Feel free to ask whatever the result...
Hope this may help you;
DON"T FORGET TO RATE:
Posted on Sep 04, 2008
  • 33 Answers
SOURCE: sony sdm s73 screen black - green light flashing - no amber light
1. If under warranty, take it to the service center immdtly.
2. The display cable might be loose plug it up.
3. Your system might not be giving signal to the display unit. Is the system running, Listen for a beep when u turn on the system. If there is a beep the System Ok for display or the problem might lies in the Tower itself.
Posted on Jan 05, 2009
Uneven backlight
Your set is probable defective
Sep 21, 2017 | Sansui Televison & Video
I need Driver for WIN 7
There doesn't seem to be any drivers supporting (well, specifying they support win7) but you can try this one. It's the only one out there. http://download.cnet.com/SONY-CPD-E220-E220E/3000-2108_4-169549.html
Good luck.
Dec 14, 2010 | Sony CPD E220 17" CRT Monitor
From long run my monitor contract has weaken and I am getting yelloies colour on full brightness and contrast How to increase and how to make it whiten ?
Hey, try to increese the brightness from you display adapter settings on the pc. Sorry to say but its time for a new monitor.
God Luck.
Jan 25, 2010 | Sony CPD 20SF2 (White) 20 in.CRT...
Contrast ratio of tft monitors
Contrast ratio is the ratio between black and white. So low contrast ratio (5000:1) means you can;t see the screen so well in a bright room (where there's a lot of sunlight) A higher contrast ratio (20000:1) means the screen is brighter so easier to see in bright rooms.
Pixel pitch refers to the distance between pixels. The lower the pixel pitch, the sharper the image
Feb 04, 2008 | Audio Players & Recorders
Retrace line on monitor
Nov 16, 2007 | Sony STYLEPRO CPD-E540 (Gray) 21 in.CRT...
Brightness of picture
If you feel good about opening your set then you can try this: Look for the flyback (high voltage) transformer, with the thick red wire which goes to the top of the picture tube. There are 2 controls on the flyback transformer, focus (top) and screen (bottom)Turn the brightness and contrast all the way down and then increase the screen control until you see retrace lines, and then back it down until those lines just vanish. Return the brightness and contrast to normal and adjust the focus control, if necessary, for a nice sharp picture. Let me know if that brings your brightness back.
Aug 21, 2007 | JVC AV-27D104 27" TV
Dark picture (HELP)
Open up the back of the set but be very carefull. Notice a large black block with a large red wire that runs up to the picture tube. on one side of that large block where the thick red wire is comming out of are two controls, one should be marked focus or F and one should be marked screen or S. With the set operating normally and not touching anything else, slowly turn the control marked screen or S clockwish till the picture gets bright enough. If you go too bright the set will shut down or you see small thin white lines so back down on the control. then touch up the focus and your good to go. good Luck.
Dec 01, 2006 | Toshiba 32A42 32" TV
Getting More Brightness/Contrast ?
problem with my monitor Viewsonic E70....Memory recall keep flashing......any help out there.....
Mar 15, 2006 | HP 90 19 in.CRT Conventional Monitor
Strange silhouetting and a vertical strip
If A vertical strip appears on the screen when recording a dark background or the subject is blooming or silhouetting, you need to adjust the BLC. * The contrast between the subject and the background is too great for the camcorder to operate normally. * Make the background brighter to reduce the contrast or use the BLC function while you are recording in a brighter environment. BLC (Back light Compensation) * BLC works in CAMERA/M.REC mode.B * Back lighting exists when the subject is darker than the background: 1. The subject is in front of a window. 2. The person to be recorded is wearing white or shiny clothes and is placed against a bright background; the person?s face is too dark to distinguish his/her features. 3. The subject is outdoors and the background is overcast. 4. The light sources are too bright. 5. The subject is against a snowy background. 1. Set the power switch to CAMERA mode. 2. Press the BLC button. Normal - BLC - Normal BLC enhances the subject. Notes: * When NITE PIX to set to ON, the BLC function does not work. * The BLC function will not operate in EASY mode.
Sep 07, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Sony CPD E220 17" CRT Monitor Logo
51 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Computer Links
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
