Question about Canon PowerShot G3 Digital Camera
Dim Photos My G3 has begun to take very dim photos, all iso speeds are affected plus Auto mode. It can barely focus, even with the assist light on. If it was the light meter (setting too high an aperture?) it would probably be able to focus, right. When I take a picture it always sets f2.0 1/60 sec, even at iso400. Is it the image sensor?
    Genius:
  • 1,690 Answers
Put the camera in to the full auto mode. If the pictures are still dark, it is possible that the apature inside of the lens is not working. There is a micro-motor, gear assembly, iris leaf assembly, and a servo amp circuit that drives the apature. The servo amp is referenced from the uPC according to a routine that uses light and speed evaluation.
In actual fact, anything that has to do with the light measurement, lens apature control, or the main picture processing can make problems.
It is a common problem that people sometimes damage the lense from banging or dropping the camera, or it just fails.
You will most likely have to send the camera to Canon service to have it fixed.
Jerry G.
Posted on Apr 13, 2008
SOURCE:
How to shoot pictures of the moon
About this result
How to photograph the supermoon: an easy way to shoot moon ...
www.techradar.com/.../photography.../how-to-photograph-the-moon-an-easy-way-to-...
  1. Cached
4 days ago - Taking pictures of the moon is one of the more popular subjects in night photography - but it's also quite tricky to get right. Use this tried and ...
How to Photograph the Moon - Photography Life
https://photographylife.com > Photography Tutorials
  1. Cached
  2. Similar
Jun 11, 2015 - Aperture: Set your aperture to f/11. Shutter Speed: Set your shutter speed to 1/125 on cameras with base ISO 100, and to 1/250 on Nikon DSLRs with base ISO 200. Lens Focus: Set your lens to manual focus (either through a switch on the lens or on the camera) and set your focus to infinity.
How To Take Stunning Pictures Of The (Super) Moon :: Digital Photo ...
www.digital-photo-secrets.com/tip/779/how-to-take-stunning-pictures-of-the-moon/
  1. Cached
  2. Similar
Aug 7, 2014 - Start with ISO 200, f11 aperture and 1/125 second. Try a test shot. Then use trial and error by changing the shutter speed until you can find the best exposure that works for your composition without overexposing the moon. Turn off auto focus.
How-To: Photograph The Moon ' Popular Photography
www.popphoto.com/how-to-photography-moon
  1. Cached
  2. Similar
4 days ago - Planning is a big part of all photography, and shooting the moon is no ... that much money on a lens like this to take impressive moon photos.
How to shoot pictures of the moon Google Search
Nov 15, 2016 | Cameras
Why are my photos washed out when taken outside?
Check that your settings are on auto - to get the best in/out pics
Sep 20, 2014 | Canon PowerShot G3 Digital Camera
Why is sports mode not working?
If you are trying to take photos in very dim light the sports mode may not work. Sports mode selects a fast shutter speed to freeze the action and in very dim light with some lenses the aperture may not open wide enough to allow enough light to hit the sensor.
Aug 18, 2014 | Canon EOS 60D Digital Camera
How to fix slow shutter speed?
When in Any auto mode or P or A your camera automatically will adjust your shutter speed for ambient light conditions. So if your having issues where your camera is choosing to slow a shutter speed and you photos are coming out blurry then there isn't enough light either because other settings in the camera are limiting light or where ever you are taking photos is poorly lit. Setting your ISO Higher should allow the camera to increase the shutter speed, but will often introduce noise to your photos. The more you play with your camera and learn digital photography the more you'll understand how to make your photos the best they possibly can be. For the time being if getting a no blurr shot is key put your camera in S mode which means shutter priority this will allow you to control and lock your shutter speed and set your ISO to auto this will force the ISO and Aperture to change instead of your shutter speed to get a good photo.
Jul 21, 2014 | Panasonic Lumix DMC-FZ30 Digital Camera
Hi, the photos i take are getting blurred and the image is not at all clear no matter how shot the distance may be i click the image.the only new icon i see on the screen is vibration warning symbol along...
If you are shooting in Auto mode with flash, this should solve your problem. Make sure you are not dictating any of the settings, i.e. choosing a longer shutter speed, a very small aperture setting, or a very low ISO (sensitivity) setting.
Typically the vibration warning icon will appear when the camera is trying to use a long shutter speed without flash in order to get the right exposure for a darker scene. Your outdoor (bright light) photos are probably OK.
In dim light with a point and shoot camera, you can have your choice between 1. blurry (using a relatively slow shutter speed), 2. dark (using a shorter shutter speed but no flash), or 3. a good photo with flash (which uses a medium shutter speed and added light from the flash)
Mar 12, 2011 | Cameras
Horizontal lines appear in newly saved images
the only thing i can think of is the sensor being misconnected or kaput. are you viewing them on the camera screen or a pc? it could also be camara screen...
Jul 05, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
Nikon D40x flash will not go off
I have the D40x. Only thing i can think of is the little sensor thing on the front down and to the left of the release button. If you have your finger over it, the flash don't work and the focus won't work right. "Infrared assist" in the manual. Myself, I use the sb400 strobe flash cause the popup flash uses too much power from the camera battery.
Jun 28, 2009 | Nikon COOLPIX L3 Digital Camera
Can't get the camera to auto focus in dim light
you can maybe set the camera to manual focus, or override the autofocus so that you can take the picture.
Jun 13, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Can't take pictures in low light/no flash with my Nikon D40X
First of all you need a tripod to cut down on the movement . Next use the mode dail and select a nigt setting .
You can even use a shutter speed in Aperature Prioity .Ypu might want to use exposure comp .
This should work for you.
Apr 07, 2009 | Nikon D40x Digital Camera
My photos are coming out slightly grainy in low light. Have played around with ISO and aperture etc but no luck. All modes have the same problem. Camera= canon powershot S5 I5
When you use auto mode on most point and shoot digital cameras ( which includes the F717) the camera software gets to choose aperature, shutter speed, and ISO setting. When the ISO setting is used at the faster ISOs, the images get digital 'noisy' very quickly. There is a much higher noise level in consumer digicams at the higher ISOs, because the sensor chip is much smaller than in the digital SLRs. F2.0 suggests yoiu are shooting at the maximum aperature of your lens and that the light is pretty dim.
If you learn to use your camera in the Av ( aperature preferred) mode at ISOs of 50 or 100, most of the noise you are describing will disappear. The camera should take very nice images at ISOs less than 200.
Consult your manual on aperature preferred or manul setting of the ISO speed
Nov 20, 2008 | Canon Cameras
Canon PowerShot G3 Digital Camera Logo
69 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
