Samsung LE40M868D lcd tv does not recieve any channels and the screen has gone abit darker? please help
Astrobyte
  • 110 Answers
SOURCE: Picture gone from TV Model LE46M51B
I suspect that your backlight has gone out. If you shine a light on the screen can you see remnants of the picture that should be displaying? If so, it's definitely the backlight, and most likely the power inverter for the backlight. You can probably find a replacement inverter, but you may need a repair manual to install it. I'd recommend checking the warranty status first and sending it in for repair if you can.
Posted on Feb 17, 2008
SOURCE: LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
I unplugged the TV and now the picture is back.I read that the LCD's are vunerable to static build up so unless my daughter is using her TV I unplug it.
I was thinking about getting a large LCD for the family room but I'm not going to until they improve on this technology.
Good luck to everyone!.
Cheers.
Posted on May 08, 2008
welcomejee
  • 10594 Answers
SOURCE: 32LG3000 LCD TV shows no picture when resuming from standby
It seems just channel stored data issue.
Please perform Auto Preset / Auto Channel / Auto Tuning (mentioned menu items) and store all channels again.
Hope problem will resolve.
Posted on Dec 18, 2008
  • 718 Answers
SOURCE: how hard it is to replace by yourself main board Samsung LN-T4065
You need to do some more diagnosing of the problem. If you get sound and change channels take a bright flashlight and place it again the screen. Look for an image around the edge of the flashlight.
If you see an image that means the LCD controller board (TCON) is probably good.
The problem is probably one of three causes;
1) Inverter board is bad
2) CCFT (cold cathode fluorescent light) are bad.
3) Power to the inverter board is bad. You can also check the connectors.
Posted on Mar 30, 2009
  • 10 Answers
This should be repairable. It may be the LVDS Cable or the Main board problem. The only other problem is the T-Con Board.
Posted on May 23, 2009
Samsung LED TV has dark area on top
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Nov 19, 2015 | Samsung UN55D7000 55 in. 3D LCD TV
I have a 46" flat screen samsung TV which I bought
change your tv configuration channel type is probably cable instead of air
Nov 09, 2011 | Samsung LN-T4661F 46 in. LCD HDTV
Does this TV have built in Freeview ?
Yes,all tvs that are a LCD or a Plama tvs that are a flat screen tvs picture panels can recieving Free over the AIR DTV broadcasting incomming tv channels.Buy and used a Digital design tv Atena for a long and strong recieving incomming tv free signal DTV channels.
Aug 15, 2011 | Philips 26PF8946 26 in. HD-Ready LCD...
Trying to hook up converter box to Westinghouse flat screen the converter is magnavox sdtv. I get autoscan but no channels are found. I do not have an antennae. Do I need one? Help!
If ur tv a LCD tv it is a digital tv.U do not require a Digital converter box to get the new DTV free air signal broadcasting tv channels stations.But u do require a good digital antenna for it to recieve a long an strong signals to recieve a DTV free air broadcasting tv channels stations.
Dec 07, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Cant access the digital menu since the digital change over. Still recieve analogue channels 1 to 5 samsung lcd tv model LE32N73BDX
Hello Gregor_69
Lets see if we can get you sorted out. Please follow my steps and you will be back up and running in no time.
with you samsung remote make sure you press the TV button so that we are on a TV channel and not one of the other inputs.
Then press MENU
down to CHANNEL
go to AUTO STORE
you should find two option on there 1. air 2. cable
You want to highlight the air and START.
it will now give you 3 option
Digital & Analgue
Digital
Analogue
highlight the Digital option and START.
This will auto tune just your Digital channels. Once this progress bar has finished. You should find that all your Digital channel have returned to normal.
I hope that this has helped you out. If so then please leave a thumbs up
Cheers
Little Dish Fitter.
Oct 11, 2009 | Televison & Video
42 inch samsung lcd tv darker on one side
Its one of two things, bad lamps in the panel or bad Tcon board
Dec 24, 2017 | Televison & Video
I have a Samsung LCD HDMI 37inch TV series 5 do I need a set top box
You have a really nice TV, you have a built in ASTC tuner(digital).
If you want to recieve OTA(over the air) signals, all ypu will need is an antenna.
Visit this site for some great info on digital TV.
http://www.antennaweb.org/aw/welcome.aspx
Let me know if I can provide further assistance
Please rate this solution.
Lone99star
Apr 16, 2009 | Samsung LT-P1745 17 in. EDTV-Ready LCD...
Channel displaying on Samsung 32"LCD TV
Most remote controls have a "display" button. Pressing that is what gets that channel number on the screen. Try pressing it again and the display should turn off. On some brands the display may cycle through various combinations (channel number only, channell and time, etc.) before it goes away, so it may take more than one press of the button.
Dec 03, 2008 | Samsung 32 in. LCD Monitor TV
Feb 17, 2008 | Televison & Video
Televison & Video Logo
114 people viewed this question
Top Televison & Video Experts
