Question about Hitachi 50V500 50 in. HD-Ready LCD Television
The picture has a double image.
All pictures on all channles have a double image. it is not the cable box or in line coming into the tv. thanks m
    Sergeant:
  • 337 Answers
All conections to the set need to be check very carefully starting form the cable to comes into the cable box from the outside and the cable that goes from the box to the tv,eliminate the cable box and conect the wire from outside direct in the tv and and see how it looks bring a small portable and conect the cable to it to see how it looks,once all the possibilities have eliminated then consider a problem inside the tv in the tuner area starting at the very conector where the cable conects.All this can help if the double image is not related to misaligned convergence.
Posted on Oct 01, 2006
SOURCE:
Upgraded to Hd and tv started messing up. Double images for first 10 minutes and sometimes tv picture goes off and lines up and down.
Your HDTV is capable of up to 1080P resolution. SDTV (standard def) signals are 480i; EDTV (enhanced def) is 480P; HDTV are 720P, (there is no 720i) 1080i and 1080P. Generally, those modes ending in "P" look better than those ending in "i". 1080i is the highest possible for broadcast TV, but BluRay disks and Directv have 1080P display capabilities.
The double picture you're describing sounds like the TV is set to display only standard or enhanced def signals while the Dish Network box is supplying it with HD signals. You should locate the control for the TV's resolution and make sure it is set to "1080P" and then set the output of your Dish Network set top box to the highest output it offers. Do the same for your BluRay player and any other devices, too.
Once set correctly, you should have a great picture once again. I hope this helps & good luck!
Sep 04, 2012 | Sony KDL-40XBR4 40 in. LCD HDTV
I have a DX-L26-10A that has problem with the A/V inputs. The picture is fuzzy. All the other inputs on the TV have a good picture. Both A/V1 and A/V2 are fuzzy.
AV1 and AV2 are Composite signals. What this means is that the Image signal and the Image color are combined into a single feed... or a composite or signal and color. Other than using CH3 from the cable box, this is the poorest performer in regards to signal quality. Additionally, the signal only has 480 lines of resolution and your TV has 720.
What all this means is that 480 lines of poor image quality are being blown up (think magnified) to fill 720 lines of resolution on the screen. What you end up with is a blurry image when compared to other inputs (ie: HDMI, COMPOSITE). The Dynex TV does not have some of the more advanced video processing of other manufactures. It will perform the image doubling, a bit of filtering, but not much more.
I suspect you TV is fine. A transition to an HD display can be shocking to some. After all, the VCR looked better on the old analog TV (not a joke, it did).
I hope this was helpful, best wishes.
Mar 06, 2011 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
Picture on Samsung lcd LNT5271F is blurred sometimes lines color distortion double images then goes away and will come back. Part of the screen will go completely lines then come back. Starting to happen...
Had this exact problem diagnosed by a local repair shop as a bad LCD panel. According to the technician there's a loose ribbon cable on the panel and it would cost as much to replace/repair as a new TV.
May 12, 2010 | Samsung LN-T5271F 52 in. LCD Television
Just want to know were the cords go for the swann wireless camera into the wireless box and the tv not gettin a picture thanks
The yellow cable goes to your video in on the tv
The red rca cable goes to audio in on tv.
Select the video1 or 2 on tv to get picture.https://images-na.ssl-images-amazon.com/images/G/01/00/00/03/25/09/78/325097870.pdf
Oct 01, 2009 | Lorex LW1020 Color Wireless Remote...
Tv not working with cable box
Insure your TV is set to channel 4. Then go into your TV's menu and make sure it's set to CABLE and not AIR. There is no need to program your tv, as long as it's on channel 4 and set to recieve Cable it will be fine.
Mar 26, 2009 | RCA F27665 27" TV
I HAVING PROBLEMS WITH MY CABLE TV. MY DVR WILL NOT COME UP AND ALL MY CHANNLES IS SHOWING NOT AVAILABLE AND MY ON DEMAND DISPLAYS AN ERROR MESSAGE AND I PAY MY BILL 2 WEEKS AGO AND NOTICE THAT THE POWER...
Good Day, albertgaw;
Since TV is showing an image I would suspect the cable/sat box. Try rebooting box again, unplug or hold power button in for 5-8 seconds, be patient and allow several minutes to allow box to reset. If no fix call your provider to resend the signal, or arrange to have box replaced.
Good Luck, big IRISH.
Jul 15, 2008 | Televison & Video
HD channles
Hi Scan 1080: Enables you to receive the 1080i, 720p, 480p and 480i digital TV formats. By using the VIDEO 5/6 IN jacks, you can connect a DTV (digital television) receiver to view DTV programs. q DRC Multi-Function: Unlike conventional line doublers, the DRC feature doubles vertical and horizontal lines, resulting in four times the density for quality sources such as DVD, Satellite and Digital camcorder. q CineMotion: Using the 2-3 Pull-Down technology, the CineMotion feature allows you to obtain a smooth picture movement when playing back movies or other video sources on film. q Twin View: Using Multi-Image Driver (MID-X), Twin View allows you to watch two programs side by side with the ability to zoom in one picture and listen to selected window. You can watch pictures from two different sources (1080i, 720p, 480p or 480i) simultaneously. q 16:9 Enhancement: Vertical Compression technology that maximizes picture resolution on “anamorphic” or “enhanced for wide screen” sources, including selected DVDs. q Steady Sound: Equalizes volume levels so there is consistent output between programs and commercials. q Parental Control: V-Chip technology allows parents to block unsuitable programming for younger viewers. q Component Video Inputs: Offers the best video quality for DVD (480p, 480i) and Digital Set-top box (1080i, 720p, 480p, 480i) connections. q S-VIDEO Inputs: Provides a high-quality image for connected equipment. q Favorite Channel Preview: Preview up to eight favorite channels
Jun 02, 2008 | Sony KP-61HS20 TV
HAVIN A CHANNEL PROBLEM, I JUST WANT REG-CABLE CHANNELS I HAVE CABLE BUT NO CABLE BOX WHERE I HAVE THE TV AT.THE TV IS A 20 INCH TV/DVD. IM GETIN CHANNLES ON THE TV BUT I ALSO GET A LOT OF NO SIGNAL...
well first thing to do is this the only tv thats connected to the cable?
if it the only one
i would call the cable company and have them up the db level.
if you have more than one, you'll have a splitter that splits the cable that could be causing your problem, change it out will a new lower db one.
another thing could be happening is the cable connector on the end could be failing so have the cable guy replace all those too.
Dec 06, 2007 | RCA 20F510TD 20 in. TV/DVD Combo
HV-175 LCD
Picture quality problems (such as lines, fuzzy image, or wrong colors)
  1. Check the cables and connections: Make sure that cable connections are securely fastened to the connectors and try reaseating the connectors. If connecting a device using component cables, make sure all three color-coded cables are connected correctly into the corresponding connectors. Check the condition and length of the cables. Cables that are longer than 3 meters (10 feet), become more susceptible to promoting signal degredation (small dots "sparkling" on the screen and image ghosting). Cables that have been bent or pinched may also cause picture quality problems. Replace the cable or try a different cable type.
  2. Check the  display issue with  a different channel. Picture quality problems on a single channel or on all channels may be caused by the TV station signal (antenna) or the cable signal source.
  3. Make sure that the image quality issue is not coming from your source signal. For example: if the image quality issues occur while viewing TV , switch the source to a DVD player to see if the image quality problems go away. If selecting a different input source (using the remote control) causes the problem to go away, troubleshoot the source device causing the problem - adjust aerial antennas, call the cable company for assistance, and . If a picture quality problem occurs on all sources, the TV or its settings may be the cause of the problem. NOTE: Higher resolution TVs will make it much easier to view signal problems coming from source signals - especially TV signals. For example, if your TV cable company experiences heavy load on their system, you may be able to detect small miscolored squares that briefly scatter across the screen (macro-blocking). On a smaller standard TV, this type of quality problem is much less noticeable on a standard TV, but can become very annoying when viewed with greater detail.
  4. Try to Reset the TV ( LCD) quality options. Please look in to User Guide to make the TV to factory Defaults..
  5. Unplug the TV from its power source. With the power cord unplugged, press and hold the power button for five seconds. Turn on the TV . If the image quality problems still exists across all types of signal sources, the TV should be serviced.
I hope that this should resolve the issue. However, if the issue still persists then please contact LCD manufacturer for further more on the issue.
Bye.
Oct 17, 2007 | Proview HV-177 17 in. HD-Ready LCD...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
583 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
