Question about HP Pavilion a620n (PC028A) PC Desktop
Will not power up
Recently opened th a620n to clean out the dust. Took memory out and put it back in. Now all that happens is a buzzing or beeping every 10 seconds or less and on the monitor it says the pc is going into poer saving mode and the screen stays blank while the beeping is going on
    Scholar:
  • 149 Answers
Remove the memory again and make sure there is no dust on the terminals or on the ram chip itself...once everything is dust free replace the memory and reboot
Posted on Dec 30, 2008
Myemachine model EL1360G-UW11P stopped working after I cleaned it I took the back cover off and the fan but after I put it back together it started to have abeeptypenoise butwasntabeepitwascontinuous
Knowing the beep pattern will help diagnose the issue. Power on the computer again and listen for long beeps and/or short beeps. There are other possibilities, but if you just cleaned out the computer, I suspect you might have dislodged a memory stick. Make sure they are seated completely and the white tabs are locked securely in place. The beep code you hear will ultimately help determine where the failure is happening.
Aug 10, 2015 | E-Machines Computers & Internet
My T5026 emachines has a hard time when turned on it makes soem beep noises over and over again and the fans are running , The monitor screen won't come on.. And it doesn't boot into windows ..
Hello, When computers "beep", they're sending the user the signal that there's some hardware problem, sometimes damaged hardware or dirty hardware, first you have to identify the piece of hardware that is giving you problems, I would go after memory in the first place, open your computer an you'll see the internal parts. Remember to turn off your computer first.
This are the memory modules, if you have more than one take only one first, unlock the memory module by pressing the small plastic tabs on both ends of the slot, then take out the memory module. now turn on your pc.
If the pc is still beeping, turn off the pc again, take the second memory module out and put back the one you took out, tu put a memory module remember to force the memory into the slot the right way, if the memory is not fitting into the slot turn it down side up and push it into the slot until you hear two "clicks".
If both memory modules doesn't seem to respond, turn off your PC and take both memory modules off, clean the contacts using a pencil eraser, be gentle while cleaning the contacts as a lot of pressure will damage the memory modules, put them back in and turn back on your PC.
Take the dust off the memory slots by using a paint brush.
I would try cleaning both memory modules first and putting both in once the contacts are clean.
Try this and if you're still having problems I would recommend you to seek for a professional to solve your problem.
Hope this tip helps and have a nice day.
Don't hesitate to reply if you're still having problems.
May 25, 2011 | E-Machines T5026 (RBT5026) PC Desktop
I recently placed my computer into storage. When I took it out and set it up, the CPU seemed to be running but there was nothing on the monitor and the keyboard didn't seem to be functioning. The mouse...
unplug the power cable of the CPU
press the power button for about 5-10 secs
open the tower and reseat the memory
theres 2 white clips on each side press down the white clips until the memory pop out
check the memory if theres any dust and put it back the way it was before
push the memory back in with a small force until the 2 white clips snap in
hope this help
Sep 07, 2010 | HP Pavilion a1410n (ER890AA) PC Desktop
My computer tower wont stop beeping
Re-seat the memory.. more than likely they have unseated themselves during the dust cleaning. Beeping is usually caused by memory.. Beeps are usually a series like Morris code long..short beeps.. if re-seating the memory doesn't work, try swapping and removing different sticks and differnet locations on the motherboard, most motherboards have 2-4 memory banks or known as dimm slots.
Jan 16, 2010 | Ultra Products Ultra M923 Full Tower ATX...
Came back....turin it on....anything on the monitor
sounds like the hard drive is not spinning inside.
Sep 21, 2009 | Dell Dimension E520 PC Desktop
When I turn on my computer it does nothing but make a buzzing alarm sound about every 5 seconds. It doesn't go to the start up screen or anything.
The buzzing alarm is a beep code which indicates a hardware problem.
Try removing the system memory and clean the brass contacts and the slots it goes into, then reseat the memory and try to boot again, the memory looks like this >>>>>>>
What you need is a soft, clean, dry paintbrush.
Remove the powercord from the back of the PC.
Start by removing the ram and clean the contacts with the brush, then clean the brass contacts, reset the memory and the powercord and try booting the computer.
If it still won't boot count the beeps and how long they are and post back here.
Regards.
Aug 01, 2009 | E-Machines W3052 PC Desktop
Dell Vostro 400 Gives 2 Beeps after research it means a memory problem but all this happened after i took the memory out and put it back in so what is the problem?
Because your RAM not sited perfact also some dust there.
First pull out the RAM then clean it from dust also clean dust from its slot on motherbord.
Then refix again try both RAM Memory slot on motherbord.
Jul 31, 2009 | Computers & Internet
When start on asus motherboard 1beep+1beep sound total 2 beep sou
The problem is the system memory, get yourself a clean, dry soft paintbrush, remove the power cord from the back of the unit, remove the memory and clean the brass contacts on the memory modules, next clean the memory slots of any dust that may have built up and reseat the memory.
Put the side panel back on and plug in the power cord then power up.
Good luck
Jun 19, 2009 | Intel Motherboard
(GRA) code on monitor. tower just beeps
Hi there.
GRB means the 3 primary colours and just means the monitor is working and able to receive a signal.
I think in your case it could be related to memory. Remove any new hardware if any and any external devices like printers etc.
Now remove the power cord from the back and remove or open the side panel from the tower so you can get to the motherboard, remove the ram (memory) from the slots and clean the dust from both the memory modules and the memory slots, when they are free of dust just put one module back at a time and restart the PC (if you have more than one)
If it boots up the problem would have been dust, if it doesn't start up at all it well be faulty memory.
Please post back if you need more help or advice.
Good luck and thanks for using FixYa!!
May 24, 2009 | Gateway Computers & Internet
Beeping noise and will not start back up
Hi there.
Open the side panel on the computer case (make sure its turned off and the power cord is removed from the back) take out the system memory (ram), get a clean dry paintbrush and clean the brass contacts on the memory and also clean any dust away from the slots it goes into, once you are happy that all the dust has gone reseat the memory making sure its well seated and clipped into place, close the side panel, return the power cord and turn on the PC, hopefully this will sort the problem out.
Please post back with the results.
May 14, 2009 | Dell Computers & Internet
HP Pavilion a620n (PC028A) PC Desktop Logo
77 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
