Question about Mitsubishi CS-35505 35" TV
Vertical Sweep I have the same problem described by uncledj on my Mitsubishi CS-35505. For a few months there were vertical lines at the top of the screen, then last week I had only the bright horizontal line accross the screen. After turning it off and back on again, there was a clicking noise, the television shut down and will not power up. Is this problem worth the cost of repairing?
The vertical IC is bad this was caused by bad capacitors in the vertical amplifier output circuity.If the ic is only replaced it will most likely fail after a few days. I did this repair and after the caps were replaced still works 2years now.
Posted on Nov 11, 2007
    Sergeant:
  • 337 Answers
If the quality of the picture was good before it failed it is worth repairing,replacing the vertical Ic should take care of your problem and for a service technician is a fairly easy repair and they usually dont charge too much,maybe 100.00 to 150.00,if you take the set to someone is less the charge but I know is heavy and it might not be an option,shop around for the price of an estimate in your house.
Posted on Oct 01, 2006
SOURCE:
White horizontal line middle screen
That means you blew your vertical output transistor. This likely happened because some electrolytic capacitors dried up and nneded replacing.
Nov 26, 2013 | Mitsubishi CS-35505 35" TV
Mitsubishi tv cs 2610r
Absence of vertical sweep. Check the vertical sweep output cicrcuit for the fault.
Jun 26, 2013 | Televison & Video
Mitsubishi cs-27tx1. Only has a thin horizontal line thru middle of screen
Hello
Total Vertical Sweep failure had occured in your TV. That is there is only horizontal sweep there, and the whole picture sweeps horizontally and you see a horizontal nice line across the screen, at the middle of it. In this case, all other buttons will work, and sound output will be Ok.
This fault is normally due to Vertical Sweep Out Ic trouble. You have to open the back cover of your TV, and have to pull the main board out. Locate the Vertical Output Ic. It is easy to locate it. There will be four wires going to the deflection yoke assembly [the coil fitted alongwith the picture tubes' neck]. Amoung them, two will be thick, and is carrying horizontal sweep signals. The other two wire are comming from vertical sweep section. Follow the wires and find out from where it comes from the main board. Somewhere near it orginates from the main board, you will see an Ic usually screwed into a heat sink [ a metal plate or so]; and it is vertical output Ic.
Check first, whether there is input voltage [working voltage] come to it or not. Sometimes an open resistor problem may occur to show this fault. Normally vertical section will have a voltage rating between 18 to 35VDC. If that voltage is there, surely the Ic said above is damaged. Screw it out and desolder it from the mainboard, and go for an identical type and number, replacing it will solve your problem.
Take all precautions when we works with an elctrical equipment. Keep away children and never allow even stand beside you while you are working, and let an adult beside you as a precaution. Never use metal chair. Do wear a plastic of rubber shoes. If can, keep matted the floor also with carpet. Ok
Wish you success.
Gopakumar G.
Oct 25, 2010 | Mitsubishi CS-13104 TV
Vertical bars and lines run up and down the screen. Need service manual or parts outlet
There is no such thing as a "vertical sweep circuit board" in that set. The vertical circuit is part of the sweep module. And BTW that type of symptom is more often a power supply filtering problem anyway.
May 05, 2009 | Mitsubishi VS-50705 50" Rear Projection...
1993 tube 37" mitsubishi
It looks like the vertical amplifier IC401 is defective. If you have soldering/desoldering skills you can change this part yourself. Also you may have to change C471 (.01UF 50V).
Good Luck.
Feb 11, 2008 | Mitsubishi CS-35505 35" TV
My tv have picture 5 inch in the horizontal in the center....
Check the electrolitic capacitors in the vertical section for leakage or dry condition. The vertical amplifier IC may also be defective and check for the solder joints around the high power resistors as well.
Jan 19, 2008 | Mitsubishi CS-35505 35" TV
TV vertical height-Mitsubishi Model CS 35505
If the height has dropped down, you need to first find out why. Most likely there is a bad capacitor in the sweep power supply or the vertical output section. Good Luck
Oct 16, 2007 | Mitsubishi CS-36609 36" TV
Vertical line up and down middle of TV screen
i think this is the called picture in jail. this might be due to 1 power supply reg.poor or filter cap dry. 2 loose or dry joint nera hor. output section or capacitor in eht section.
Sep 21, 2007 | Mitsubishi CS-35505 35" TV
White horizontal line down middle of TV screen
caution whenever you see horizontal line please reduce brightness of your tv for safety of crt. your problem in vertical section only mostly due to loose contact in connector,print or loose components.
Sep 20, 2007 | Mitsubishi CS-35505 35" TV
No vertical sweep
You might be able to take care of it yourself,you are corret when you said no vertical sweep,if you can identify the vertical IC it will be easy,you are looking for loose conections but by now it might have a bad vertical Ic and it needs to be replaced along with the safety resistor that power the IC,the ic should be mounted on a heat sink and the resistor should have low resistance,very straight forward repair and while you are there make sure and check for overheated areas and loose conections specially in the power supply , horizontal drive circuit and convergence IC's.Be careful you still have high voltage witch can be dangerous.
Sep 30, 2006 | Mitsubishi CS-35505 35" TV
Televison & Video Logo
196 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
