Question about Singer Featherweight 140Q
Singer 140Q Jammed!
While changing the stitch pattern, the sewing needle was not in the highest postion. Now the machine is jammed! How do I fix this?
SOURCE: Elna 6003Q Sewing Machine won't snap out of bobbin winding mode
I had the same problem and fixed it myself. Remove the portion of the housing that coincides with the bobbin winder. You will need to remove two screws to do this--one is just to the upper left of the bobbin winder itself, and one is hidden under the handle on the left side of the machine (lift the handle, and look on the machine on the left side.) It takes some coaxing to remove the housing, but it can be done--be gentle. If you need to, remove the housing on the left side of the machine that covers the needle assembly. This will make it a bit easier, but still, be gentle.)
After removing the housing, you will see a black metal piece with a elongated slot and a screw adjacent to the bobbin winder mechanism. Unscrew the screw a turn or two, and slide the piece to the other side. Tighten gently. Turn your machine on, and move your bobbin winder back and forth and watch the screen change from bobbin winding to the main straight stitch screen. Now, do a brief Dance of Joy. I hope this helps.
Posted on Jan 23, 2009
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
SOURCE: singer stylist sewing machine 534 is not stitching
Feed dog drive gear(2) are plastic and are probably stripped. Always replace them in pairs. While you are at it replace both hook drive gears as well. It will run as good as new.
Posted on Mar 28, 2009
WonderTech
  • 268 Answers
SOURCE: my sewing machine keeps getting jammed when
Here are a couple of things to try.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin
There could be a nick along the edge of your bobbin spool that’s catching your thread as you
sew.
* When you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope this helps.
Posted on Sep 15, 2009
  • 96 Answers
SOURCE: jams
I make flannel square quilts for babies, it is a nightmare itself. It makes a lot of lint in the bobbin case and under the face plate, try prewashing the fabric before using it and clean out the bobbin case frequently while sewing. When i dont prewash it, i just open the bobbin area and blow the cotton dust out with my breath or i use the small brush to clean it out
Posted on Dec 13, 2009
Testimonial: "Thank you -- excellent suggestions. I had prewashed the flannel and cleaned the lint out frequently-but didn't help this time. Thnx for valuable ideas"
Not making stitches
Check to make sure that your needle is all the way up in the needle clamp, and the flat part of the needle is towards the back of the machine, if your bobbin loads in the front, either vertically or horizontally.
If the top thread is still not catching the bobbin thread, your timing is off and needs to be adjusted. ANY sewing machine technician can do that for you; it does not have to be a Singer technician. If you cannot find one, or they don't work on Singer machines, I understand Sears will repair any model of sewing machine. I don't work for them, and they don't know me, by the way.
Jul 11, 2014 | Singer Featherweight 140Q
My singer sewing machine is jammed. it sewed awhile, the bottom tension too loose, I adjusted it a tad, now its jammed again
try changing the needle
adjust the top tension one number or letter higher till the stitch looks
normal
clean under the needle plate & in the bobbin area for lint
make sure the bobbin is not warped
make sure the bobbin is inserted correctly into the bobbin case
try rethreading the machine top & bobbin
it's also possible that the machine could be out of time & needs
to be checked at a repair shop
Aug 23, 2012 | Singer 3116 Simple
It's new. I threaded the bobbin but now won't sew at all and knob will not move needle up and down. Acts like it wants to move and you can hear something in the housing trying but won't sew. Knob acts...
You may have jammed it, or you haven't picked a stitch pattern, read your manual because I am sure that it is something simple. If, you still can't get it, call Singer at 1-800-4singer. Good luck, Do you have your dvd, play that and read your manual really close.
Sep 07, 2010 | Singer 3116 Simple
Inspiration 4205 stitch length won't change
Are you certain that the pattern selector is set for straight stitch and not buttonhole?
Turn the handwheel so that the needle is up and the take-up lever is in it's highest position. Then turn the pattern selector knob through all of the patterns back and forth a few times. Finally, select straight stitch and see if the length works. If not, need to take it to a repair person to determine the course of action.
Feb 21, 2010 | Singer Inspiration 4206
Jams
Dec 12, 2009 | Singer 2250 Tradition
My 140Q Singer sewing machine jammed when I was stippling.
MAKE SURE THERE IS'NT THREAD WRAPPED AROUND THE SHAFT OF THE HAND WHEEL
Apr 30, 2009 | Singer Featherweight 140Q
Singer Featherweight 140Q Logo
57 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
