Question about LG VOYAGER VX10000 Cellular Phone
Trouble with ear jack and speaker, lg voyager VX10000
Making a call or reciving a call, Im not able to hear the other person and there not able to hear me. I know its my phone Im thinking maybe the settings? Also when trying to listen to music, Im not able to hear anything?Only when Im reciving an incoming call my ringtone plays!
  • 5 more comments
  • lexxipooh47 Nov 09, 2008
    I have the same problem, i can hear the ringtone, i can hear it when it turns off, but when i receive or dial a call i cant hear the other person and they cant hear me talk! i know the speaker works because i can hear all these things, i just cant hear anything when i get or dial a call. i tried taking off the battery the first time and it worked, but now it doesnt. help please and quick, its been like this for 4 days, i can only text.
  • Anonymous Nov 21, 2008
    I too have the same problem..... i went to the store to get help and they said the phone thinks there is something plugged into the ear piece jack... no idea how to fix... i've tried to reset all settings but so far it has not helped
  • pannier2 Feb 10, 2009
    Tried the headphone thing. Couldn't ever get it to work. It seems permanently stuck like this. Anyone know of a way to disable the headset jack altogether?
  • Spider563 Apr 22, 2009
    My girlfriend just had this same problem. She was talking to me on the phone on her drive home and diconnected the headset and it got stuck in headset node. I did this quick google search for her cuz she freaked out and tried taking the headset and kept plugging and unplugging the headset over and over again, repeatedly. It took a lot more than 10 times though and at a fairly rapid pace. Thanks!!!
  • glendarn Apr 30, 2009
    i went to make a call, the phone dialed out but I could not hear the dial tone or the person on the other end,  the phone was silent.  I could receive calls but when I answered them I could not hear a thing.  I did even use the ear jack.  I get sound when I power up the phone and ringtone when I receive a call.  but no sound otherwise.  I also can not get the speaker  button to engage????
  • Anonymous May 24, 2009
    yeah, I was on the phone talking and then all of a sudden the head jack thing came on and i don't know how to get it off. i couldn't hear the person on the other line
  • Anonymous Mar 19, 2014
    when ever someone trys to call me all they hear is a siren sound and the call does not reach my phone
If you look in the bottom of the phone (where the charger plugs in) you will most likely see that at least 2 of the far right pins are bent over or bent to the side. This happened on my wifes phone. I found that if I took the data cable and plugged it into the phone on one end and nothing on the other, it would work. She is taking it to get a warranty replacement tomorrow.
When you plug the data cable in, you should here all of your normal sounds etc. It might trigger the voice command thing, but it usually only does it once.
Posted on Jul 09, 2009
  • metalstill Jan 04, 2011
    This did it for me! I have had problems with the pins and charging my phone never occured to me it would have to do with the sound? THANK YOU SO MUCH
  • blwatson704 Jul 27, 2011
    Thanks! Same problem - phone thinks there is a headset plugged in. I had been to 2 Verizon stores, and neither of them had a clue how to fix it. Found 1 or 2 pins on the right side were bent. I used a needle to move them back, and it works for now. At least maybe this will buy me some time to decide on a new phone.
Agreed, the problem does seem to be these pins, I would guess it's something to do with the charger moving them when placed and removed. Which would explain the issue if you've never used a headset. I bought a headset trying to fix this issue, I tried plugging and unpligging it with no result, I did hear sound through the headset, though it didn't fix it when I unplugged it. I was able to fix it by taking a fine sewing needle and carefully move these pins on the side, but if you do this proceed with caution as they are fragile. Hopefully this page helps, because I know the frusteration of trying to figure it out and fix it.
Posted on Jan 26, 2010
  • NiEmPo213 Apr 10, 2011
    I've got an LG KM570 and I had the same problem as you guys. My phone "thought" that there's a headphone plugged in but there wasn't so the sound didn't work :S
    I tried the plugging and unplugging method and it actually worked!! :D:D:D
This just happened to me and I read the posts below. It was the ear jack that had been mistakenly activated (I didn't use it, it just enabled and thought a headset was plugged in...) So - I plugged one in, and was able to make a call. I unplugged it, and the phone returned to normal. It was pretty easy to fix in my case. Good luck - hope this isn't common!
Posted on May 26, 2009
Hey i have a solution this happen to me last night after reading what you guys said i took a head set and called voice mail and just kept unpluging and pluging in the headset until it worked. it took about 10 times
Posted on Dec 24, 2008
Yep its those bent wires. i took a pin and unbent them. very delicate. Its fucked up how companies built items to break.
Posted on Dec 04, 2009
When i call i cant hear anything. but when my ringtone plays i can hear it. how can i fix my calling one?
sounds like your ear-piece is out most phone have external speakers on the phone which will allow you to hear the ringtone but if the ear piece is out you wont be about to hear you callers
May 12, 2011 | LG VOYAGER VX10000 Cellular Phone
LG voyager cell phone
Sounds like her phone has a bad mic and that is why she can hear other party but they cannot hear her.
Jun 15, 2010 | LG VOYAGER VX10000 Cellular Phone
I cant hear anything on my phone whats up with it? its a voyager
check if the mute is on and off it or change the ear speaker
Apr 07, 2010 | LG VOYAGER VX10000 Cellular Phone
Cannot hear in the ear piece when trying to talk when the phone is closed.
your speaker needs to be replaced.
we do this repair for $30.
CommCentral
Mar 28, 2010 | LG VOYAGER VX10000 Cellular Phone
When phone is used I can hear other person talking, they can't hear me even on speaker.
i'm having the same problem - do you use a blue tooth handset with yours?
Feb 11, 2010 | LG VOYAGER VX10000 Cellular Phone
Headphones are only working in one ear.
This is a common problem. All stereo adapters will only play in the right ear. What you should do is send back the headset adapter and get a stereo headset that plugs directly into the 2.5mm jack, without going through an adapter. That should solve the problem.
Aug 03, 2009 | LG VOYAGER VX10000 Cellular Phone
LG Voyager Audio
you need to take the phone to a mobile service center and have them replaced the microphone and the ear piece.
May 31, 2009 | LG VOYAGER VX10000 Cellular Phone
Earjack
Yeah, I had the same problem. There isnt really a fix, but when you unplug the jack, make sure the speakers work, by turning on speakerphone (The little speaker symbol will appear) or try calling someone. If it isnt working just wiggle the jack in the port a little bit and try plugging and unplugging it. I just think the port gets stuck or something so it thinks that the jack is still in there when it isnt, thus leading to the speakers not working. This is a really annoying problem. Pretty poor design, but an easy enough fix I suppose.
Apr 18, 2009 | LG VOYAGER VX10000 Cellular Phone
Lg voyager. i can hear others but they cant hear me
you must have a broken mic, take apart the front of your phone and solder the wires from the mic on the bottom back to the leads then it will work again, if not send it to verizon if it is under a year old thay are obligated to fix it.
Apr 04, 2009 | LG VOYAGER VX10000 Cellular Phone
Volume on calls
you need to have the ear piece speaker replaced on the phone....take the phone to a mobile center and have them replace it for you.
Sep 21, 2008 | LG VOYAGER VX10000 Cellular Phone
LG VOYAGER VX10000 Cellular Phone Logo
2,817 people viewed this question
Top LG Cell Phones Experts
IT Solution
IT Solution
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
