Hi, Hope this helps. 1st, take the screen off by putting a sharp edged tool like a knife in the slight gap and pull off gently. 2nd, with rim off, you will see 4 holes around the screen with 4 torx screws size ""6"" take the 4 screws out, be gentle not to round them off you can then pull the screen off by just lifting separating it fro the dome back . 3rd with screen face down you will see the speaker held by two screws take these out then lift the speaker gently to the side.. 4th this is the tricky bit, gently pull the silver casing and foil gently not off - but temporarily sort of hanging, 5th with the screen still face down turn it gently so the the part where the reser hole and dock connection faces you, if you have taken the foil off you will see two holes one at each end at the very bottom take the right hand screw out and pull casing to you so you can pull battery out of holder and unplug the very small plug and you can put new battery in.. lastly gently wrap the casing and foil back to its position.. then the rest speaker - dome back - and screen rim.. just to add its like a bake bean tin casing really shodily made not worth half the price.. hope this helps its easy enough. lastly was your green light on but no power up possible as mine was, i changed battery and it is still the same with new battery.. Rob let me know what happens
Fixed, thanks.
