Question about Kenmore Washing Machines
11082683310 kenmore washer leaking
Replaced coupler and still have trouble with spin and leaking somewhere near center of machine during agitation hoses do not appear to be leaking and
  • Anonymous Mar 17, 2014
    washer leaks during agitation
    Genius:
  • 1,122 Answers
Your outer tub seal is leaking,it is a big job to replace,let me know if you want to tackle it-mike
Posted on Nov 03, 2008
  • MIKE major Nov 04, 2008
    please change your rating from helpful to fixya as i have given you everything you need to fix your dryer,plus it screwed up my expert rating,thanks-mike
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
Will not agitate or spin
On Whirlpool brand made machines the drive coupler between the motor and the transmission is probably stripped out or broken and needs to be replaced.
Keep in mind that Whirlpool also manufactures: Estate, Roper, Kitchen Aid, some Kirkland and some Kenmore washers. All have the same coupler that gets stressed and breaks. A cause for this often times is overloading the machine.
After inspecting and finding the problem, make sure you have the model number and call your local appliance parts store or repair center and they probably have your part in stock.
Repairing a stripped out coupler is pretty easy for the doit yourselfer.
I suggest watching this video before attempting the repair:
http://www.youtube.com/watch?v=WLPGs2UMUJc
Apr 10, 2010 | Kenmore 24032\24036 Top Load Washer
I just replaced the transmission on my Kenmore 80. No agitation
your motor turns one way for the spin cycle and the other way for agitate. remove the coupler and test it that way.
Feb 04, 2010 | Kenmore 24832 Top Load Washer
Kenmore top load washer wont spin/agitate.I replaced the coupler
This is either a coupler kit needing to be replaced or a transmission. You will see the broken coupler before you remove the transmission.
Sep 05, 2009 | Kenmore 15864/15862 Top Load Washer
Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
Bad/broken coupler/ http://www.davesrepair.com/DIYhelp/DIY285753.htm
Sep 01, 2009 | Kenmore Washing Machines
Kenmore Washer 90 Series Super Capacity will not agitate or spin.
http://appliancejunk.com/forums/index.php?topic=3437.0
Yes, you have a direct drive coupling problem. Use this video to replace your part.
EZPZ.
Aug 13, 2009 | Kenmore Washing Machines
Won't spin, makes clunking noise, drains fine
If it agitates fine , with normal noise , drains with lid closed , then the problem is probably the transmission .
Aug 02, 2009 | Kenmore 24032\24036 Top Load Washer
Washer will not agitiate or spin
Motor coupler between motor and gearcase.
Mar 30, 2009 | Kenmore 24032\24036 Top Load Washer
Kemore 90 Serieswashing machine fills and spins but won't agitate
Remove the agitator and see if the agitator shaft moves during agitate. If it moves then the agitator spline is worn or the agitator dogs are worn and the top half of the agitator will not work. If no results then the gearcase would have to be replaced
Dec 30, 2008 | Kenmore 24032\24036 Top Load Washer
Agitator not turning during cycle
Well, it sounds like you've done your homework. My first suspect would have been the agitator dogs too, but you said they were fine. Another likely suspect would have been the motor coupler, but you said the washer spins during the spin cycle. If the coupler was bad the unit would fill, but wouldn't agitate or spin. Plus, it would make an awful noise. I would have also suspected a clutch assembly, but you said the wash tub can spin. Normally, when the clutch goes bad, the drum won't spin, or spins slow. Another suspect could have been a bad lid switch, but the washer would have filled and stopped, without agitating or spinning. The only remaining suspect that I'm aware of is the gear case (transmission). Checking under the washer can give you some clues. Normally, when a gear case starts to go bad, they leak an amber colored oil. You may find puddles or drips under the washer. If you see no signs of oil the gear case could still be defective, however. But, before you go through all the trouble, double check the agitator one more time. Completely remove it from the tub and check the under side to ensure the grooves that grip the top of the gear case shaft have not been worn smooth. I hope this may have been some help to you.
Jul 09, 2007 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
67 people viewed this question
Fordexpert
Archaeology
Archaeology
2mikecurtis
