Question about Dell Inspiron 9200 Notebook
Difficult boot from cd drive - dell inspiron
Hi. I have a Dell Inspiron 9200. I've just now started to try booting the computer from CD/DVD in order to run various programs, but this does not work. The BIOS appears to be set correctly to check the CD before booting from the hard drive.
The Ubuntu DVD I have has an option to fix this (just for its DVD) in this situation; their fix works and I now have a menu option for "ubuntu" any time I reboot.
However, other seemingly bootable CDs or DVDs will not boot this machine.
Any ideas?
with thanks,
J.
  • 68 Answers
Try to do this, when you see the dell logo, keep on tapping f12 then choose cd rom or dvd rom device, then keep on tapping enter until you will be able to see the setup page of the program/os that you are installing.
Posted on Nov 03, 2008
When pressing F8 on a dell inspiron 1525 I can't get into setup for the advance boot options menu. I am trying to overcome a "NTLDR is missing" issue
HI,
If you're trying to boot from the DVD/CD(OS disc) try tapping on F12 to go to the boot menu and then choose your DVD/CD drive to boot from the OS Disc. From there, you can use the OS Disc to repair your computer. Here's the step by step instruction once you've booted from the OS disc:
1. Insert the Windows bootable CD into the computer. 2. When prompted to press any key to boot from the CD, press any key. 3. Once in the Windows setup menu press the "R" key to repair Windows. 4. Log into your Windows installation by pressing the "1" key and pressing enter. 5. You will then be prompted for your administrator password, enter that password. 6, Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
copy e:\i386\ntldr c:\ copy e:\i386\ntdetect.com c:\ 7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
If this does not resolve the problem, you might need to reinstall windows.
Hope this helps!
Sep 11, 2011 | Dell Inspiron 1525 Notebook
Dell Inspiron 600 - trying to reload, but not
You might need to go into the computer's BIOS and see if it's set to boot from a bootable CD or USB device. If it's set to only boot from the hard drive, it won't even look at other drives. Different computers use different ways to access the BIOS: you might try pressing the F12 key when the boot logo appears. Check your owner's documentation - it should tell you the procedure for your computer.
Mar 31, 2010 | Dell Inspiron 6000 Notebook
HOW TO INSTALL WINDOWS XP ON DELL LAPTOP
go into bios by pressing F2 - change the boot order so the cd / dvd drive is the first bootable device and use the installation / recovery disc you got with it and boot from the cd and re install or install windows xp.
If you do not have the cd then you either need to find it or contact dell and see if they have another one with a key ( which may be chargeable )
Apr 23, 2009 | Dell Inspiron 1525 Laptop Jet Black
I have a dell inspiron 5150 and it won't start up it started with NTLDR is missing I tried to replace these files with new ones didn't work. I have 2 laptop another one is a compaq armada 1750 now the 2...
inset the extrnal dvd drive attch with usb cable and insert the orignal windows cd dell recover cd and boot timepress F12 and select the extrnal drive and start your system setup.............ok
Apr 02, 2009 | Dell Inspiron 5150 Notebook
Dell b130 upgrade to new hard drive trying to boot of from cd-rom but wont..... need help
did you change the order in the bios setinbg?put the 1st device for boot to be the CD/DVD-rom not HARD drive, to get into bios try F2., ESC, ,F12 . and in the bios setup change the order put 1st boot device to be CD/DVD-rom, then try again to setup Windows.
Mar 13, 2009 | Dell Inspiron B130 Notebook
Dell inspiron 7000
check whether the CD that you boot from is a "Bootable CD" . While burning an OS in a CD/DVD the option of "Make the disc Bootable" should be ticked on which makes the disc bootable with its boots records. The system will realise that the disc is a bootable one only if the disc has these boot files in it.  Try setting the boot sequence to Cd drive as first priority and dont forget to save the settings. If all your hardware componets are good, the above things will be the probabilities.
Mar 10, 2009 | Dell Inspiron 7000/7500
No bootable devices on my Dell Inspiron 1150
My Laptop Inspiron 2200 With Windows XP only boot with the C drive when I remove the CD-DVD-CD drive. Otherwise ,I am asked to go to Bios to reconfigure the booting order.
The CD-dvd can not be pick-up by Plug and Play .
As a result I can only use the Laptop without the CD-DVD
When I reconnect the DVD it will not boot.
I have inspected every single pin in the DVD and from the Motherboard I can not see any damages
What do you think is the problem?
Mar 09, 2009 | Dell Inspiron 2200 Notebook
I have a dell inspiron b 130 and my cd rom was pulled out by my son i wanted to know how can i boot my computer from the new cd dvd rom i need to format my laptop
you can configure it on the bios settings of the unit itself (possibly F2 or F11)
Then go to boot sequence then look for the removable device.
Then save your settings and restart your laptop. It should be working now.
Feb 26, 2009 | Dell Inspiron 8200 Notebook
Dell laptop inspiron 1000
Put recovery disk in the CD drive. On reboot, hold down F12 key. You should get a choice of drives to boot from. Make sure the first two are in the correct order:
1. CD-ROM (optical drive)
2. HDD (hard drive)
then press F10 to save and exit.
Now the laptop should boot correctly from the recovery disk.
Jan 06, 2009 | Dell Inspiron 1000 Notebook
Dell Inspiron 9200 Notebook Logo
156 people viewed this question
Alun Cox
