How to replace color wheel for hlp6163w - Televison & Video
  • Terry C
    Terry C May 05, 2009
    I need instructions on how to replace the color wheel.
Slinteriors
  • 8617 Answers
SOURCE: people on tv are blue
you will need to index the color wheel in order for it to have the correct tints
Posted on Sep 26, 2008
premtech
  • 934 Answers
SOURCE: mixed colors
Color wheels in that unit were updated to remedy a flaw in their initial manufacturing. I suspect you have one of the updated wheels and now the dmd board is having a problem distinquishing relative speed etc. Pull dmd jumper to fix it. Remove the jumper pin on the dmd board, metal shield has a cut-out so you can just reach in and grab it with a pair of needle nose pliers and pull it out.
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Posted on Nov 04, 2008
lukster
  • 217 Answers
SOURCE: Hlp6163w Color Wheel Settings for
if you replaced the color wheel and are experiencing some strange colors on the tv, then check the dmd board, you may need to remove the jumper underneath the shield on the dmd board, you should see a small sticker noting this
Posted on Dec 26, 2008
SOURCE: How to replace color wheel part BP96-00674A for Samsung 61" HLP6163W model
Here is step by step process to do the color wheel. Its really quite simple.
http://www.youtube.com/watch?v=Cx4pbNjsxfU >> Replacing the color wheel in a Samsung DLP Television
http://www.youtube.com/watch?v=4fGgpR-DEXY&feature=channel_page >> Replacing the color wheel in a Samsung DLP Television Part 2
The bulb is even easier. Also you do no need gloves if you don't touch the glass bulb. So just use a towel and be very careful while putting your new bulb into the old housing.
Posted on Mar 11, 2009
I have a benq projector which has a very noisy color wheel can I stop it or how do I replace it
Jan 12, 2014 | Samsung HLP6163W 61" Rear Projection...
Replace color wheel on samsung HLP6163W
that needs experience of electricals first
Jun 10, 2008 | Samsung DLP HL-P5663W 56" TV
I have no jumper on my samsung dlp to change colors back after changing the color wheel.
hi,,
after the color wheel replacement you need to get the restore sequence procedure using button combination of your remote..
try to to this link www.fixya.com/users/chester_pendilton0
and get any of my services..
thanks
Feb 03, 2012 | Samsung HLP6163W 61" Rear Projection...
My Samsung HLP6163W started making a loud buzzing sound and the picture is distorted. I've read around and have come up with two possible solutions: replacing the lamp or replacing the color wheel. ...
100% this tv problems it is the tv colors wheel it is defective require replacing.The loud tv buzzing noises sounds are the sounds came from the tv wharp colors wheel it is spinning out control wildly and off of it motor axis and by hitting it to the wall of it steel box holding it.The tv distorted colors pictures are came from out of the reflections of a badly worn out of the tv colors wheel.
Jul 08, 2011 | Samsung HLP6163W 61" Rear Projection...
I changed the color wheel in my HLP6163w. Now the color is off. I looked at the delay index and tried to adjust it but it won't work. The colors are just not right. How do I get the colors right?
Check if instructions with color wheel show a jumper on DMD board for an upgraded bearing-type of color wheel. Jumper hole would be on rear-facing shield of DMD board. (Standard 2-pin jumper used on computer boards.) Probably would have to remove jumper; not insert it.
May 02, 2010 | Samsung HLP6163W 61" Rear Projection...
I changed the color wheel and the blub the picture is fuzzy and the colors look out of place a lot of green need help!!!!!!! hlp6163w
Are you sure that you have the good color wheel for the LIGHT ENGINE install in your tv. Samsung use different version of light engine who had their own color wheel.
Apr 27, 2010 | Samsung HL-P6163W 61" TV
MY SAMSUNG DLP MN HLP6163W PICUTURE HAS FADED
If you have had this unit for awhile it could just be the lamp. If the image does'nt brighten up you may have an issue with the light path. The color wheel produces the color. If there was an issue with the color wheel you would most likely have a black and white image.
Jan 24, 2010 | Samsung HLP6163W 61" Rear Projection...
Hlp6163w Color Wheel Settings for part # BP96-00674A
Dec 17, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
People on tv are blue
Sep 26, 2008 | Samsung HLP6163W 61" Rear Projection...
Televison & Video Logo
424 people viewed this question
Top Televison & Video Experts
Electro Med Services...
