Question about Sony MDR-V700DJ Professional Headphones
Change ear pad
Hi!
Is it possible to change the hear pad?
I have the parts, but I do not know how to remove the old parts and put the new pads.
Could you please help me?
Thanks!
(For a so expensive model it's crazy that is so hard to fix it!!)
  • 4 more comments
  • jacob22 Nov 03, 2008
    thank you Welcome jee...
    I'm tryng to understand...
    Still can't see how to install the earpad and then put the screw...
    I's an headache... !!!
  • jacob22 Nov 04, 2008
    Sorry for rating...
    But I really do not know how to proceed...
    Do you know where I can find the service manual... I cannot find mine...
    Thanks
    PS Pls, could you give me the first 2 or 3 moves to do? After I should be able to go on by myself... thanks
    Thanks jee,
    I've tryied, it breaks, but it doesn't come out... it's like if it's fixed from the inside... with a screw or with glue...
    THANKS jee ;))
    Somethimes in life you just need someone who tells you "go ahed, don't be afraid"!
    I was scared to break everything!
    Yes i did it fixit!
    My new part is not original, but I did pay it 75cents for both pads instead of 26$ ;)
    They're pretty much the same... and I'll save the money to buy new headphones when it will be time ;)
    Thanks again!
    PS is there a way to give you a rate higher than blu?! ;)
    Thanks
  • 10,594 Answers
I hope below exploded view will help you how to open Change ear pad - moz-screenshot.jpgMDR-V700DJ headphone.
Posted on Nov 03, 2008
  • 2 more comments
  • Shahid Electronics
    Shahid Electronics Nov 03, 2008
    I think you have enough info from MDR-V700DJ service manual and its pretty easy to open and fix this unit.
    Please reconsider solution rating as yellow stars hits badly my ranking at website.
    Shahid Electronics Nov 04, 2008
    Thanks for rating correction.
    You just pull out pads of headphone as described in below picture. If you have further question, please mark the part in same picture.
    I'm sure there is no screw to hold soft pads. Service Manual shows no screws involve and This can be removed easily but carefully.
    I'm happy that problem has been resolved and there is no rate higher then blue :)
    If you are satisfied, its better then blue diamonds rating.
    Have a nice day.
PS Hi Jee, I really think the original pads are fixed with a screw, because when I did pull them out, they both broken at the same place.
They probably turn the first screw whith the pad inside, then the other 2 screws and then they enter the pad the same way you put a tire on the car... I suppose.
Anyways, the new pads are solid even without screws... Yesterday night I did use them for my DJ gig. ;)
Posted on Nov 07, 2008
EAR CUSHION
Sony parts suppliers sell replacement ear pads. Part no 2-320-280-01 about US$16 each (not pair).
Old ear pads slip off - pull gently to stretch the part that sits in the groove of the headphones until one side slides out.
The creative sewer can remanufacture new pads from thin soft leather by following the pattern of the old ones.
No cost fix is to scrape off the remaining peeling urethane leaving the soft fabric backing. Headphones will still work but the soft earpads should absorb high frequencies.
Sep 12, 2012 | Sony MDRXD400 Professional Headphones
1989 toyota pickup front disk brake pads replaced, now the front calipers wont clear the new disk brake pads! Any solutions, please?
remove caliper, push disc all way home, put wheel nut on to hold home, retry fitting them the disc may be slightly scued. If no go try diffrent brand of pad I had same prob with a diffrent car last week & diffrent brand pad was 2mm thiner. If can't exchange pads get piece of emery paper on flat surface & sand away top part of pad material in round motions both ways till they fit. :-)
Jul 09, 2012 | Toyota Cars & Trucks
I am trying to change the brakes on a 2000 dodge neon and i need directions.
I assume just the front brakes?
You will need brake pads, brake cleaner, a small packet of brake grease, a large 4 inch C clamp, and possibly new rotors if the old ones are bad (abnormal wear or it they are out of spec).
Start by jacking up the car one one side after placing the car in park and putting the parking brake on. Remove one of the front tires. Now spray the brakes/caliper with the brake cleaner so that you won't be breathing in brake dust particles and this will help clean up the parts (try not to get the brake cleaner on plastic parts). The brake caliper holds on the brake pads with two large bolts that will be parallel with the axle. Remove these bolts. You should now be able to pull the caliper and brake pads off of the disc/rotor. Make sure not to wreck the brake line that runs to the caliper. Take off the outer brake pad. Now take the C clamp and use it to slowly depress the inner brake pad and caliper. Make sure you have the old brake pad on so as not to wreck the new one. Once depressed, remove the brake pad and put the new brake pads on. Make sure to then grease the two caliper bolts and reassemble the brake assembly. If you replace the disc/rotor, spray it first with the brake cleaner to clean off anything left from manufacturing. Repeat on the other side.
Make sure to pump the brakes before driving. Let me know how this works out for you.
Benjamin
Dec 05, 2010 | 2000 Dodge Neon
Changing my brakes on a 2008 vic jackpot
Unbolt the 2-3 bolt caliper, remove them which would lead to releasing caliper then removing old pads. Push brake piston back before installing new pads. Reverse removal process to install pads. Make sure no grease or oil substance exist when you put the pads back as this will cause ineffective braking.
Apr 25, 2010 | 2008 Victory Vegas Jackpot
Engine will not turn over
Start with backwheel, do visual check of disk pads, are they stuck to disk?. If yes, try operate foot brake and see if piston moves to press pads and releases. If not, disassemble caliper from disk, remove brake pads, clean exposed area around pistons using WD-40 spray, use clean cloth to wipe clean piston, push piston in using C-clamps until flat with cylinder, watch brake oil servoir not to over flow when pushing pistons in, stick both pads into caliper, push foot brake until it presses both pads.snug, remove pads, push piston back in again. Fit caliper and pads back onto bike, operate foot brake, check brake operations.
Use a 200-320 grit fine sandpaper, clean your disk surface, wipe with clean cloth so no rust dust sticks to disk. Clean pad surface with petrol, wash away any grimes and oils.
Using your hand you should be able now to turn freely the back wheel now..
Squirt about 5-10cc light oil into combustion chambers, ensure oil soaks onto piston rings, put in high gear and try combustion pistons to complete emptying-intake-exhaust-fitring cycle at least twice.
Do oil change oil with fresh new oil, ensure as much as possible old oil are drained out, change filter.
Clean out old fuel from tank + fuel bowl gunks, make sure all needles and float bowl are clean
While having sparkplugs out, spray into combustion chambers reasonable amount of starter spray fuid and put plugs and starter motor into place.
Now if you have kickstart try use it for a couple of turn else just use your electric starter motor, the motor should strat running. Keep it running for abouot 10-15 minutes before doing any riding ensuring oil have circulated properly.
Let me know if any other problem creeps-up.
Apr 14, 2010 | 2002 Suzuki GSF 600 S Bandit
How easy it to change front brake pads on a toyota rav 4
not hard at all.remove tires.then remove 2 screws either 12mm or 14mm that hold the brake caliper in place.remove caliper but DO NOT disconnect the brake line from the caliper.get a C-CLAMP in order to get the caliper piston pushed back in.remove old brake pads and install new ones in the same order as the old ones were removed.you will want to check the rotors to make sure they are in good condition before you install the new pads,then put caliper back on and tighten screws to specs.do the same on the other side and always remember to PUMP YOUR BRAKE PEDAL A FEW TIMES IN ORDER FOR THE CALIPER PISTONS TO ENGAGE ON THE NEW PADS. hope this info helps.good luck and take care, manny
Mar 30, 2010 | 2006 Toyota RAV4
Need earpad replacements for Optimus Pro-100 Wireless headphones
Just flip the headphone pad inside out on the Optimus Pro 100 wireless headphones.
Find the 3 screws on each headphone speaker, you have to push the existing cover back, but you'll find them. Remove the 3 screws. Be careful of the speaker wire that will be attached to the cover plate that has the ear pad on it. Also, look carefully at how the components are assembled inside the headphone, as you might disturb their setting. They are easy to return to their proper place if they move.
Gently remove the ear pad, turn it inside out and you will have a new covered ear pad. GENTLY, re-install ear pad onto speaker plate, be careful not to break the speaker wire that is attached. I found a little flat screwdriver helps to pull the edge of the pad over the plate. The ear pad is actually quite strong and can take some abuse, but don't pull the speaker wires loose.
After you have the cover back on, find the screw holes and put the 3 screws back in. Presto, a little cleanup on any loose pieces of covering from the original side and your done for another couple years or so.
Feb 26, 2010 | Audio Players & Recorders
Change the brakes on 2007 sport trac
it has front and rear disc brakes, disc brakes are very simple to change out. Most disc brakes have two bolts that hold them on, one on the bottom one on the top on the inside of the brake caliper, they may be an allen head, or just a bolt. Remove them counter-clockwise. After you remove the two bolts, lift up and away on the caliper and the whole assembly will come off. Once you pull the assembly off you will see the two pads, one of them is driven by a piston, the other one is fixed. Remove the fixed one, they just pop off (have little metal clips you may have to slide the pad off). Take a C-clamp or something comparable to squeeze with, place it on the back of the caliper and on the old pad thereby squeezing the cylinder back into the piston, once you squeeze the cylinder back into the piston, it will give you room needed for thicker new brake pads. Piston should retract with the c-clamp fairly easy, shouldn't be a whole lot of resistance. Remove c-clamp after you get it to retract and remove old pad. Put new pad on, just like you took the old ones off. All four are basically the same to change out, they all have two bolts holding them on. You pull those, get the pistons to retract and replace the worn pads, put them back on, line up holes, put bolts back in... and your good to go. When you get back in the car and turn the key on, you may have to pump the brakes a few times.
Nov 01, 2009 | 2007 Ford Explorer Sport Trac
Need to replace 1991 chevy astro van break pads and rotors and need a diagram
The following procedure requires the use of a C-clamp and slip-joint lock pliers.
  1. Siphon off about 2/3 of the brake fluid from the master cylinder reservoirs.
CAUTION The insertion of thicker replacement pads will push the piston back into its bore and will cause a full master cylinder reservoir to overflow, possibly causing paint damage. In addition to siphoning off fluid, it would be wise to keep the reservoir cover on during pad replacement.
  1. Raise and support the front of the vehicle on jackstands. Remove the wheels.
When replacing the pads on just one wheel, uneven braking will result; always replace the pads on both wheels.
  1. Install a C-clamp on the caliper so that the frame side of the clamp rests against the back of the caliper and so the screw end rests against the metal part (shoe) of the outboard pad.
  2. Tighten the clamp until the caliper moves enough to bottom the piston in its bore. Remove the clamp.
  3. Remove the 2 Allen head caliper mounting bolts enough to allow the caliper to be pulled off the disc.
  4. Remove the inboard pad and loosen the outboard pad. Place the caliper where it will not strain the brake hose; it would be best to wire it out of the way.
  5. Remove the pad support spring clip from the piston.
  6. Remove the 2 bolt ear sleeves and the 4 rubber bushings from the ears.
  7. Riveted style brake pads should be replaced when they are worn to within 1/32 in. (0.8mm) of the rivet heads; bonded style pads should be replaced when they are worn to no less than 1/32 in. (0.8mm) of the backing plate.
  8. Check the inside of the caliper for leakage and the condition of the piston dust boot.
To install:
  1. Lubricate the 2 new sleeves and 4 bushings with a silicone spray.
  2. Install the bushings in each caliper ear. Install the 2 sleeves in the 2 inboard ears.
  3. Install the pad support spring clip and the old pad into the center of the piston. You will then push this pad down to get the piston flat against the caliper. This part of the job is a hassle and requires an assistant. While the assistant holds the caliper and loosens the bleeder valve to relieve the pressure, obtain a medium pry bar and try to force the old pad inward, making the piston flush with the caliper surface. When it is flush, close the bleeder valve so that no air gets into the system.
Make sure that the wear sensor is facing toward the rear of the caliper.
  1. Place the outboard pad in the caliper with its top ears over the caliper ears and the bottom tab engaged in the caliper cutout.
  2. After both pads are installed, lift the caliper and place the bottom edge of the outboard pad on the outer edge of the disc to make sure that there is no clearance between the tab on the bottom of the shoes and the caliper abutment.
  3. Place the caliper over the disc, lining up the hole in the caliper ears with the hole in the mounting bracket. Make sure that the brake hose is not kinked.
  4. Start the caliper-to-mounting bracket bolts through the sleeves in the inboard caliper ears and through the mounting bracket, making sure that the ends of the bolts pass under the retaining ears of the inboard shoe.
  5. Push the mounting bolts through to engage the holes in the outboard shoes and the outboard caliper ears and then threading them into the mounting bracket.
  6. Torque the mounting bolts to 37 ft. lbs. (50 Nm). Pump the brake pedal to seat the linings against the rotors.
  7. Using a pair of slip-joint locking pliers, place them on the notch on the caliper housing, bend the caliper upper ears until no clearance exists between the shoe and the caliper housing.
  8. Install the wheels, lower the vehicle and refill the master cylinder reservoirs with brake fluid. Pump the brake pedal to make sure that it is firm. If it is not, bleed the brakes.
Oct 11, 2009 | 1991 Chevrolet Astro Extended
How can i change the rear brakes pads?
1.Remove the cap from the brake fluid reservoir
2.Loosen the wheel nuts then raise the vehicle and remove wheel
3.Push the piston back into the bore to provide room for the new brake pads.A C-clamp can be used to accomplish this As the piston is depressed to the bottom of the caliper bore the fluid in the master cylinder will rise.Make sure is doesnt overflow.If necessary drain off some of the fluid. 4.Before removing anything,spray the disc,and brake pads with brake system cleaner dont use compressed air 5.remove the caliper mounting bolt,the banjo fitting for the brake hose shouldnt be disconnected unless you are removing the caliper or hose replacement
6.Swing the caliper up and secure the caliper up towards the spring with a piece of wire then remove the lower and upper anti-rattle springs.Remove the outer brake pad and shim then remove the inner brake pad ans shim(s)
7.Remove and inspect the upper and lower pad retainer clips,the pad retainer clips should fit snugly in the caliper mounting bracket;if they dont,replace them.Apply thin film of high-temperature grease to the retainer
8.Apply anti-squel compound to the back of pads install the new inner pad and shim(s) make sure the "ears" on the upper and lower ends of the pad are fully engaged with their respective grooves and the pad retainer clips
9.Install the new outer pad and shim if new pad has no shim take the old shimoff the old pad and install it on the new outer pad.Install the upper and lower anti-rattle springs
10.Clean off the caliper pin and coat it with high-temperature grease.Lubricate the lower caliper pin with grease too thenswing the caliper down over the disc and new pads (if the piston hits the inner pad depress the piston further into the caliper bore with your c-clamp
11.Install the mounting bolt and tighten it to the torque specifications (44-63) 99 and earlier models (51-55)00 and later models
12.Put the wheel back on and tighten lug nuts
Oct 05, 2009 | 1998 Hyundai Elantra
Sony MDR-V700DJ Professional Headphones Logo
3,598 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
